Vector bike and frame owners.
Artur   100 kW
Post by Artur » Apr 06 2015 4:59pm
I think it is time to create independent forum thread for Vector bike/frame owners on Endless Sphere.
Let me introduce myself: My name is Artur, I'm 23. I am Master of Science of Computational Mechanic in Technical University of Munich.
Me and a team of enthusiasts have been working on developing an electric bicycle, more powerful than standard 250W.. We ended up with something we could not imagine at the beginning, partly because of unbelievable fast science and engineering progress development, partly due to success of Vector in e-bike community. It let us work passionately and develop our new ideas about Frames, Bikes, Components, Logistics, Services and many more.
At this moment over 300 Vector frames were produced and delivered to the clients.
Endless number of improvements was made in original frame design to make it better, stronger, lighter. Our bike can overtake supercars in power-to-weight ratio!!
This thread is created to let Vector owners communicate about anything connected to our passion - e-biking!
Welcome guys!
The Vector sales thread is here: http://endless-sphere.com/forums/viewto ... 31&t=61259
litespeed   100 kW
Re: Vecor bike and frame owners.
Post by litespeed » Apr 06 2015 6:13pm
Looking forward to this thread.
Tom
macribs   1 GW
1 GW
Post by macribs » Apr 07 2015 4:34am
*subscribed*
moonshine   1 kW
Re: Vector bike and frame owners.
Post by moonshine » Apr 07 2015 9:36am
Ok. So i guess Chris king headsets are top of the line. But since I don't really want to spend 125 on a headset (maybe I'll change my mind) the cane Creek 40 is good? Is everyone getting a regular height headset or zero stack?
Has anyone found any nice square cranks without 2 or 3 rings?
Current Build: Vector, MXUS 4T in 19" moto, Max-E, 20s8p Samsung 25R http://endless-sphere.com/forums/viewto ... =6&t=67752
Torque Raptor, Cromo V3 in 19" prowheel, Kelly KBL96251, 24s4p (SOLD) http://endless-sphere.com/forums/viewto ... =9&t=56342
Giant DH Comp, X5404/Cromo V2 in 26" rim, Kelly KBL96251/Lyen 18fet, 24s4p (SOLD) http://endless-sphere.com/forums/viewto ... =6&t=40031
Artur   100 kW
Post by Artur » Apr 07 2015 4:25pm
GiantEV   100 W
Post by GiantEV » Apr 07 2015 10:24pm
What is the largest diameter front chainring that can be used without hitting the frame?
striker54   100 W
Post by striker54 » Apr 08 2015 1:45am
GiantEV wrote:What is the largest diameter front chainring that can be used without hitting the frame?
Whatever you want. The chainring doesn't hit the frame (if you don't use spacers).
moonshine   1 kW
Post by moonshine » Apr 08 2015 5:50am
Do the frames come with head tube bearings? Conventional, integrated or semi integrated headset?
striker54   100 W
Post by striker54 » Apr 08 2015 6:03am
moonshine wrote:Do the frames come with head tube bearings? Conventional, integrated or semi integrated headset?
No, you have to buy and install them (unless you negotiate that with Artur).
They are conventional headset 1.1/8" Ahead (34mm)
I bought this: http://www.bike24.com/1.php?content=8;n ... 12;mid=229
moonshine   1 kW
Post by moonshine » Apr 08 2015 6:32am
Yes! Finally! Thanks striker.
Artur   100 kW
Post by Artur » Apr 15 2015 12:06pm
One Vector owner had problem with 135mm motors and brakes caliper (was too far from the frame and to close to motor side cover). There is a solution- spacers for rotor, and spacers for rear caliper:
welcome :)
br0m   1 µW
Post by br0m » Apr 15 2015 6:27pm
Those vents are also aesthetic, very well designed frame
maxRpm   10 W
Post by maxRpm » Apr 18 2015 5:40am
Did anybody make of there vector bike build yet besides the one I seen on YouTube from russia?
Artur   100 kW
Post by Artur » Apr 18 2015 8:33am
maxRpm wrote:Did anybody make of there vector bike build yet besides the one I seen on YouTube from russia?
In russia now around 100+ bikes on Vector frame :) 50+ in Ukraine :) In europe and america by this time should be around 50+ :) I will post here my next build.
Boestin   100 W
Post by Boestin » May 01 2015 1:50am
I see that most of the Vectors are equipped with a springshock.
Is this FOX RP23 going to work on the frame? I am about 82 Kilo's
maxRpm   10 W
Post by maxRpm » May 01 2015 2:52am
I am curious to know what kinda of battery setup is everybody going with. I had planed on using multistar 6s 16000 battery's but seem like there on back order and will be for a while.
Boestin   100 W
Post by Boestin » May 01 2015 3:12am
maxRpm wrote:I am curious to know what kinda of battery setup is everybody going with. I had planed on using multistar 6s 16000 battery's but seem like there on back order and will be for a while.
Yup, I expect a waiting time of a month :(
moonshine   1 kW
Post by moonshine » May 02 2015 5:24am
I'm going with 20s8p Samsung 25r. I have plenty of room left for more but want to keep it light. I'll also put the controller inside.
Routybouty   100 W
Post by Routybouty » May 04 2015 2:01pm
I would have liked to go with those but they are never in stock! I went the "cheaper" route, x25 Turnigy 20C hardcase 4s 5000mah packs. Gives me 20s 74V @ 25Ahr.
Waiting for that perfect ebike.
moonshine   1 kW
Post by moonshine » May 04 2015 8:37pm
Is anyone having issues with running a single speed setup? The front chain ring is so far away from the rear free wheel. I might have to add a cassette in the back to get the chain to align right
maxRpm   10 W
Post by maxRpm » May 05 2015 1:44am
I can help you on this issue...but I don't have my frame yet :D I am gonna be running same setup hope you can figure it so I can copy if you don't mind. :D
striker54   100 W
Post by striker54 » May 05 2015 1:51am
moonshine wrote:Is anyone having issues with running a single speed setup? The front chain ring is so far away from the rear free wheel. I might have to add a cassette in the back to get the chain to align right
I can't help you out because my motor uses the 150mm dropouts. your motor is 135mm so that will cause a lot of misalignment. You will need to use spacers on the other side to get more alignment in the freewheel side.
GiantEV   100 W
Post by GiantEV » May 05 2015 8:20am
I went with the Turnigy 4s hardcase packs as well. I'd like to use 18650 cells, but the Turnigy packs are cheap and easy to wire up to the Adaptto BMS.
I only have 20 packs now, but I'd like to bump my pack size up to 25, or even 30 packs if they will fit!
Routybouty, I'd like to see pictures of how you fit your batteries in your Vector frame.
maxRpm   10 W
Post by maxRpm » May 06 2015 3:57am
Just got done putting her together but having a slight problem
maxRpm   10 W
Post by maxRpm » May 06 2015 7:19am
Mostly put together.
