Madin, can you please place a link where i can buy this stand, thanks.madin88 wrote: Now i am using the stands from the chinese EEB frame which costs less than half (25USD vs 55USD the crap from vetcor), have felt like half the weight and so far they handle the weight well![]()
Vector bike and frame owners.
Re: Vector bike and frame owners.
My rides: https://www.youtube.com/channel/UC4rx5u ... yCxNPJNpkw
Vector 16kW QS205 +hubsinks+ferro, Sabvoton 72150, Merida 1.5kW Magic Pie 4
when is the new website up?
https://endless-sphere.com/forums/viewt ... 9#p1284149miunchy wrote: Madin, can you please place a link where i can buy this stand, thanks.
as mentioned in this topic i asked C&N ebike on Alibaba. it's not listed in theire assortment.
https://leilicn.en.alibaba.com/?spm=a27 ... 0.0.qd8sb7
- 10kW belt drive with Neumotor 8057: [url]viewtopic.php?
- KTM Hardtail Pedelec / eZee V2 6T / 27,5" / Kelly KBSX @ 1,5kW / Torque PAS / CA-V3 / 13s4p Sanyo GA in Shark case
Vector Typhoon v2.0 e-bike 10kWt - http://endless-sphere.com/forums/viewtopic.php?t=61259
Our web site: http://www.vectorebike.com
Nice Artur!
When do you have some more detailed information about the new mid drive? Like final specs, price and when we can put in our order?
here we go
new motor on the vector bike:mxus 3k turbo 3T topspeed 19inch wheel:75kmh-gps on the 18s Sanyo nmc 25Ah VW e-up cells.
Sabvoton controller 125 battery amps-250 Phase goes crazzy
volt drops maximum 2V on the total 18s pack(0,11V cell) so these cells can take 100Amp easy.
Upgrade the battery wires to 7awg,upgrade the rear brake 203mm disc.
On/off switch+volt display no more extra wires and big displays on the bike
range 40-70km....a lot hard riding gives me 45km range.
I have a 3 speed freewheel and waiting for the chain parts(wider size for the 3speed).
just a pic how the bike looks.
Finally chain+chaintensioner wurks perfect,pedal easy 20kmh no motorpower.
Mount a compleet Magura MT5 4 piston 203mm brake kit front-rear.Very strong brakes
Front suspension Magura usd old spring style,no oil leaks verry hard and wurks perfect on the heavy bike
The front+back wheel i like to make them mat-black for the compleet good look(chrome to shiney and the front doesnt match)
Tires 3.0 give the bike a real steady feeling@speeds above 40kmh.
The only thing i hat now is the sound of the freewheel
the motor/controller are super quiet.
Vector bike is ready and i am happy with the look,wheels front+back black looks good to me
dubbel shrink the vw e-up 25Ah cells,smal holes on the terminals to check the ballans.
Joachim, how much money di you have in your ebike ? Looks nice.
Not to much i start with the frame and put the rest on the frame step by step.
Frame 600Euro.
Brakes magura mt5 203mm 200Euro.
Fox rear schock 150Euro.
front fork magura-second hand 125Euro.
steering-bar-progrip grips etc 100Euro.
Mxus 3k turbo 3T 19inch mc wheel 400Euro.
rims-tubes 3inch rear+front 130Euro
Chain-freewheel 30Euro.
controller sabvoton 96150 200Euro.
Battery 18 big li-nmc vw e-up cells 18s 25Ah 1.6kwh 400Euro.
Total like 2400Euro....
Frame 600Euro.
Wooohow thats cheap as hell... I have spend about <twize that much... Well.. But I also use a better battery(3kWh; 18kW max), some more motorcycle parts and an Adaptto..Joachim wrote:Not to much i start with the frame and put the rest on the frame step by step.
Frame 600Euro.
Mechatronics-Engineering Student
-Built own ebike: ✔
-Built own 3.2kWh LiIon battery (300Amps): ✔
-Overtake Porsche with own Ebike: ✔
-Take off with ebike: ✖
~14kW, 3.2kWh LiIon, QS 205 8ml ff, hubsink
-Built own ebike: ✔
Yes a good battery from 18650 cells cost a lot...3kwh for sure
( bigger and better are not the same
I think the sabvoton is a great controller for the money,runs very cool and silent/smooth.
Cool, I will try the Sabvaton next time. <Thumbs Up>.Joachim wrote:Yes a good battery from 18650 cells cost a lot...3kwh for sure( bigger and better are not the same
Yes, really 3kWh. 20s15p. 20×15×2,67Ahx3,7 ~ 3kWh. And 16Ax15x20x3,7 ~ 18kW. (16,6kW continuous)
-Built own ebike: ✔
-Built own ebike: ✔
20s 15p-300 cells...big battery 14 kilo? 2.88kwh
Yeah something about that.. I guess its about 15kg but never gets hot as its overpowered as much as possibleJoachim wrote:20s 15p-300 cells...big battery 14 kilo? 2.88kwh
-Built own ebike: ✔
-Built own ebike: ✔
Yes thes cells never got hot never see max amp drawn,long live battery
I have build some of these vw cells in a 2 person pedal assist duo bike a view weeks a go:the guy cald me this week and the bikes range is 400km
i put 10s 2p on the duo van raam bike so 18kwh
i have to make a second battery for a 3 wheel van raam bike 10s 1p 36v 25Ah.order already 1 module....12 cells so i have 2 cells left,i can go to 20s in the Vector( i have to check the used cells and the new cells first).
Haha, you mean that one? LolJoachim wrote:Yes thes cells never got hot never see max amp drawn,long live batteryI have build some of these vw cells in a 2 person pedal assist duo bike a view weeks a go:the guy cald me this week and the bikes range is 400km
-Built own ebike: ✔
-Built own ebike: ✔
Yes...they are not cheap:4000-7000Euro
Joachim,
I will be building one almost exactly like yours, hope you don't mind if I ask a few questions for guidance. How did you paint the wheels, just rim or spokes and all. I want to paint just the rims on mine. Any prep advise would help.
Rims are hard to paint, or rather they are tough to get a lasting paint job. All kinds of scratches, dust from brake pads, sand, rocks and stones always working the finish of the rims. I would either do it cheap as possible, like plasti dip. Or powder coat. I tried to paint a set of 19" mc rims. Even with proper prep work, sanding, base coat, paint and then clear to seal it all didn't last. When I swapped for a lighter and smaller 19/18"rim set I opted for powder coating. Tough as nail. No more chipping.
You need the right paint.i have paint alluminium car wheels with the same mat black paint....winter summer stil holding strong and looks good-easy to clean. Use the special motip allu paint for alluminium wheels,first sanding waterproof 2000 and 4 layers paint will hold good and the looks are perfect.
Thanks. Yours look great. What fender is that? Just the right size.Joachim wrote: ↑Dec 10 2017 5:16pmYou need the right paint.i have paint alluminium car wheels with the same mat black paint....winter summer stil holding strong and looks good-easy to clean. Use the special motip allu paint for alluminium wheels,first sanding waterproof 2000 and 4 layers paint will hold good and the looks are perfect.
Awesome pics! I like the mudguards of these.. Are they a different sort then you sell? Where to get them?
-Built own ebike: ✔
-Built own ebike: ✔
