JP spot welder
BYqSXt8Z   100 W
Re: JP spot welder
Post by BYqSXt8Z » Aug 29 2019 1:02pm
riba2233 wrote:Cmon guys, still available! :)
Pmed you
Sent from my CLT-L04 using Tapatalk
riba2233   1 MW
Re: JP spot welder
Post by riba2233 » Aug 30 2019 7:15am
Ok guys, I've just sold out DIY kits, so I have only about 6 assembled units left.
Get it before it's all gone! :mrgreen:
My electric moped: http://www.evalbum.com/4966
My electric car: http://www.evalbum.com/5364
riba2233   1 MW
Re: JP spot welder
Post by riba2233 » Sep 05 2019 12:54am
One more gone, now 5 units left, hurry up! :)
tomjasz   10 GW
Re: JP spot welder
Post by tomjasz » Sep 06 2019 8:05am
riba2233 wrote:
Sep 05 2019 12:54am
Is two enough, or three too many! What’s the closeout price again? <VBG>
Just sold my unused KWeld needing updates and a fix. With the case and parts I’m eating around $100 of air. That left a bad taste. Kinda unclear how the JP is so simple and still serves users well. Or maybe the KWeld has enough upgrades to keep busier builders a step ahead.
Do you have a set of probes/weld tips? Or maybe I can collect commissions on previous sales and get a deeper discount on one of the 5? <wink>
Cowardlyduck   100 MW
Re: JP spot welder
Post by Cowardlyduck » Sep 08 2019 5:09am
I'm tempted to grab another one as my existing one has been so useful, but the problem is Jakov, you've made it so well it's so reliable, I don't see my existing one breaking anytime soon. :lol:
That being said, the SLA I've been using for the last 4 years was getting pretty tired in my last pack build. I propped it up with some old LiPo, which worked for a time, but eventually killed the LiPo.
I had some old NiMH cells lying around from when I changed over my 04 Prius battery a few years back, so I put them into a 2S2P configuration and paralleled with my SLA.
This should boost the amps noticeably and extend this old SLA at least another year till I am due to get a new SLA in my car. :)
I also made some new tips out of copper rod as was suggested by others. Using my steel pencil sharpener and drill worked great to get them nice and pointy as you can see above.
Cheers
My stuff:
Ebike Garage - My YouTube Ebike ramblings.
Cowardlyducks - Videos - Ride videos
BikeE recumbent commuter - 9C, 6Fet Grinfineon, internal 17AH, 52V, + on-board solar.
For Sale:
Custom made 18650/21700 battery packs - Australia only
High Power LiPo wiring harnesses - 4P - XT90, HXT4mm, 5.5mm. 200Amp+ capable. Global shipping.
tomjasz   10 GW
Re: JP spot welder
Post by tomjasz » Sep 08 2019 12:04pm
Cowardlyduck wrote:
Sep 08 2019 5:09am
Cheers
Because they're so budget-priced, and reliable I DID add a backup. I'd rather use it then the KWeld I sold for $50.
If I wasn't so short $$'s at the moment I think I'd have pulled the trigger for a third.
BYqSXt8Z   100 W
Re: JP spot welder
Post by BYqSXt8Z » Sep 08 2019 12:20pm
Yup, I bought the last 2 diy kits and I'll upgrade those heatsinks... I'll get amazing duty cycle :D
tomjasz   10 GW
Re: JP spot welder
Post by tomjasz » Sep 08 2019 3:06pm
BYqSXt8Z wrote:
Sep 08 2019 12:20pm
Which heatsinks will you use?
cr4west   1 µW
Re: JP spot welder
Post by cr4west » Sep 08 2019 3:11pm
Enjoyed reading this form. You all saved me from taking my chances on a used Sunkko 788+ welder.
I'm interested in buying one. Looks like the JP KIT versions may be all gone now. If so I will go for a JP assembled version.
I plan to use lead acid batteries.
Couple questions. (Forgive me if this has already been discussed):
1. Can enough supply batteries be attached to weld copper strip or layered nickel on top of copper strip?
2. Later on could the JB controller be modified to use an AC/DC pulse tig welder as a power supply? The reason I am asking is I saw that video about the guy welding copper strip on Y-tube using a JASIC WSE-200P TIG200P AC/DC TIG/MMA Square Wave Pulse Inverter Welder.
Currently resurrecting a very abused Schwinn Stealth 1000 (Ezip 1000)
BYqSXt8Z   100 W
Re: JP spot welder
Post by BYqSXt8Z » Sep 08 2019 3:49pm
tomjasz wrote:
BYqSXt8Z wrote:
Sep 08 2019 12:20pm
I'll be putting in copper bars where the aluminum bars currently are.
BYqSXt8Z   100 W
Re: JP spot welder
Post by BYqSXt8Z » Sep 08 2019 4:03pm
tomjasz wrote:
BYqSXt8Z wrote:
Sep 08 2019 12:20pm
I'll be putting in copper bars where the aluminum bars currently are. Maybe with some slots in there too.
riba2233   1 MW
Re: JP spot welder
Post by riba2233 » Sep 10 2019 10:34am
Thank you for kind words guys, the whole idea behind the welder was that is simple, robust and reliable.
cr4west wrote:
Sep 08 2019 3:11pm
Hey, thank you for your interest!
1. Yes, you can stack nickel strips without any problems! It can weld copper strips up to 0.1 mm, but it's very stochastic and I strongly don't recommend it.
2. I really don't think so. Maybe with some modification on the logic side.
riba2233   1 MW
Re: JP spot welder
Post by riba2233 » Sep 13 2019 7:35am
Only two pieces left! They are packed and ready to ship immediately after receiving payment! :bigthumb:
tomjasz   10 GW
Re: JP spot welder
Post by tomjasz » Sep 14 2019 5:34pm
Buy two get a discount on the third? :wink:
riba2233   1 MW
Re: JP spot welder
Post by riba2233 » Sep 17 2019 3:18am
tomjasz wrote:
Sep 14 2019 5:34pm
PM me! :)
riba2233   1 MW
Re: JP spot welder
Post by riba2233 » Sep 25 2019 3:41am
All the welders have been sold, big thanks to all of you who have supported me in this last few years!
As a thank you to community I will give you a little surprise later :)
BYqSXt8Z   100 W
Re: JP spot welder
Post by BYqSXt8Z » Sep 27 2019 3:20pm
riba2233 wrote:Depends what polarity, of 12V logic supply no, it has protection diode (if it doesn't work, just reverse the polarity), but don't mix the polarity from the welding battery. Welder goes to the negative pole. If you have any doubts please ask before trying, thanks! :)
And once I've screwed that up, what do I do?.... Asking for umm.. For a friend Image
riba2233   1 MW
Re: JP spot welder
Post by riba2233 » Oct 05 2019 9:36am
Hi guys, just wanted to let you know that I have open sourced the welder design:
viewtopic.php?f=14&t=102681
So this thread can be closed :)
