Charging/ Balancing through the balance leads only
mybike   100 W
Post by mybike » Apr 30 2015 7:10am
I have a bulk lipo pack set-up as in the pic. I would like to balance my pack when need be but don’t want to break the pack a part to do so.
I am running 3x18.5v lipo packs in series and 6 more in 3x series then in parallel and bulk charging to 62.25v. I have wrapped the lipo in cling film as one fat pack.
Q1. Can I balance my pack using just the balance lead each pack one by one when they ever go some what out of balance and leave the pack in series and Parallel?
Q2. If the answer was yes what charger will do that? (I am from the UK).
Battery Pack.JPG (18.89 KiB) Viewed 3477 times
wesnewell   100 GW
Re: Charging/ Balancing through the balance leads only
Post by wesnewell » Apr 30 2015 9:15am
They make chargers that charge through the balance leads, or you can make a simple adapter to charge individual packs with any balance charger.
mybike   100 W
Post by mybike » Apr 30 2015 10:13am
Wesnewell thanks for your reply.
Just to be clear as I don’t want to miss understand this… :oops:
Are you saying I can use a JXT lead and plug it in to the balance port of my Imax charger and run the negative and positive of the main charge leads from the charger to the JXT leads as in the picture you have shown, then plug the JXT in the lipo packs individually charge and balance charge them in lilo and lipo mode and I can leave my pack in series and parallel :D like in the picture below?
Balancing And Charging Through Balance Leads.JPG (23.15 KiB) Viewed 3474 times
dnmun   100 GW
Post by dnmun » Apr 30 2015 12:30pm
make sure to take pictures before, during, and after.
mybike   100 W
Post by mybike » Apr 30 2015 1:54pm
dnmun wrote:make sure to take pictures before, during, and after.
Im lost…what are you trying to say. :?:
wesnewell   100 GW
Post by wesnewell » Apr 30 2015 2:54pm
Yes, that's what I'm saying. Just make sure you don't feed it more amps than the small balance wires can handle. Most are 5A max. 3A should be perfectly safe. Unlikely, but if they are 26awg, don't go over 2A. 22awg is good for 7A. I think most are 24awg which is good to 3.7A.
mybike   100 W
Post by mybike » Apr 30 2015 3:05pm
Thanks wesnewell much appreiate it helping me on this! :)
John Bozi   1 MW
dc - 4s bulk charging in series
Post by John Bozi » Aug 21 2015 6:41pm
Hi guys,
I am going to bulk charge 9 x 4s packs as 12s 3p where they are paralleled first then in series. Although I plan to use my satiator most the time these 4s chargers are so cheap that I am interested in using for balancing occasionally without pulling apart the pack. So I'd buy 3 of these...
Do any mods need to be made to use them?
and
Could I use the satiator at the same time as using them?
I've heard somewhere something along the lines that there is a common negative problem.....
http://www.hobbyking.com/hobbyking/stor ... ouse_.html
Hobbyking® DC-4S Balance Charger & Cell Checker 30w 2s~4s, simple to use Lipoly charge unit that will balance charge 2s~4s lipoly batteries via the balance lead, complete with overall & individual cell voltage display.
Features:
Sturdy alloy case
LED Display showing overall and individual cell voltage
1000m/A~1500m/A balance charge output
9v~16v (30w) input
Power lead supplied
Compact size ideal for field box
Dimensions: 80mm x 50mm x 21mm
Weight: 71g (without lead)
Suitable for JST-XH balance plugs
thanks
skoleskibe   100 mW
Post by skoleskibe » Aug 30 2015 3:23am
There is a common ground problem, just blown up my own 3 chargers HK chargers..... Shite
dnmun   100 GW
Post by dnmun » Aug 30 2015 8:47am
boost converters always have the ground of the DC input tied to the ground of the output. that cannot be changed or hacked. they are not the same as a switch mode power supply.
John Bozi   1 MW
Post by John Bozi » Aug 30 2015 3:13pm
sorry to hear they blew up, were you doing something along the lines I described above?
I asked HK chat help a while ago about this and they said it would work, I didn't trust them as they don't know enough about seriesed packs.....
thanks for confirming that I can't do this.
SjwNz   100 W
Post by SjwNz » Aug 30 2015 6:52pm
wesnewell wrote:Yes, that's what I'm saying. Just make sure you don't feed it more amps than the small balance wires can handle. Most are 5A max. 3A should be perfectly safe. Unlikely, but if they are 26awg, don't go over 2A. 22awg is good for 7A. I think most are 24awg which is good to 3.7A.
Also, when charging via the balance leads, if you charge current is to hi, this can cause an error in the 1st and Last cells voltage that the charger will see. The resistance of the balance lead with the charge current will cause a voltage to be formed which will add itself to the cell voltage.
dnmun   100 GW
Post by dnmun » Aug 31 2015 12:54am
no, the balance current does not build up a significant deltaV over the sense wire. it can be considered identical in voltage. the sense wire is copper conductor and current is in the range of mA so the delta V is in the nanovolt range. essentially 0V.
SjwNz   100 W
Post by SjwNz » Aug 31 2015 3:59am
dnmun wrote:no, the balance current does not build up a significant deltaV over the sense wire. it can be considered identical in voltage. the sense wire is copper conductor and current is in the range of mA so the delta V is in the nanovolt range. essentially 0V.
Yes I agree 100%, I should of stated that the issue I was talking about is when you put the main charge current through the balance plug , So charge and Balance through the balance plug.
dnmun   100 GW
Post by dnmun » Aug 31 2015 8:10am
no, you charge from each terminal of the battery. the BMS inside the balancing charger will send the proper balancing current through the sense wires. it does not charge through the sense wires in any case, only through the terminals since the sense wires can only handle the balancing current and not the charging current.
SjwNz   100 W
Post by SjwNz » Aug 31 2015 8:58pm
dnmun wrote:no, you charge from each terminal of the battery. the BMS inside the balancing charger will send the proper balancing current through the sense wires. it does not charge through the sense wires in any case, only through the terminals since the sense wires can only handle the balancing current and not the charging current.
I know this, but this thread is about Charging/ Balancing through the balance leads only . I have done a diagram to show what I am talking about
what could happen if charging at to high current using the balance plug only. Charging via the balance plug is fine as long as you keep the current down,
MyBike just wants to balance his cells every once in a while. but because the main battery leads are connected to the other packs in series/parallel he only has access
to the balance plugs to do his balance charge.
Graphic1 (Medium) 800x600.jpg (142.86 KiB) Viewed 3162 times
dnmun   100 GW
Post by dnmun » Aug 31 2015 10:10pm
well then his laziness is just gonna make his battery even more unbalanced.
TheBeastie   1 MW
Post by TheBeastie » Aug 31 2015 11:48pm
I think the best way to build a dodgey balance charger is just via a bunch of powerpacks and dc step downs.
get a bunch of these either one for every cell in P or split your pack in half for charging and get half the amount
http://www.ebay.com/itm/US-Plug-AC-100- ... 21015c1c24
Then a DC step down converter of 24watts size to feed it 4.2 or 4.1volts etc
http://www.ebay.com/itm/5A-Adjustable-P ... 1e89ef4c78
Then build it into a suit case like this guy...
https://endless-sphere.com/forums/viewt ... d#p1045777
Then operate it with a muslim headscarf in your garrage witth the door open, then get raided by swatt then sue for a million dollars like this guy.
http://mobile.abc.net.au/news/2010-12-2 ... nt/2382174
Speed Kills Range, 10mph = 46 miles range, 20mph = 20 miles, 30mph = 8 miles rangehttps://goo.gl/1JNL53
Over Charging Kills ur battery bit.ly/1hzWKl4
Consider PAS as your only throttle https://goo.gl/Kg1F8F
Fuel-Cell is the ultimate battery coupled with 4th-gen Nuclear
https://goo.gl/TcKtHs https://goo.gl/ZhFFot https://goo.gl/gfa215
10 Square Miles of solar panels = 0.12GW average power! https://goo.gl/Ub1S39
TheBeastie   1 MW
Post by TheBeastie » Sep 17 2015 1:25pm
TheBeastie wrote: Then build it into a suit case like this guy...
I think my weird ending of this post is now quite vindicated..
http://www.washingtonpost.com/news/morn ... to-school/
I guess the only thing that's left to do is get left wing political folks to find and fund this boy with the best lawyers possible to sue the government, well that's what I think would happen in Australia these days.
So anyone going to build one of these with a headscarf on or what? :mrgreen:
You got to imagine it with x 12 LED step downs flickering away etc, would look pretty badass/dubious.
$_12 (1).JPG (20.07 KiB) Viewed 3085 times
