Welcome to the Electric Horsemen
Willow   10 kW
Re: Welcome to the Electric Horsemen
Post by Willow » Nov 08 2015 4:29am
This is the Mayor of old Hobart Town, and I, and the GT - from the recent Sustainable Living Festival.
Samd   1.21 GW
1.21 GW
Post by Samd » Nov 08 2015 4:27pm
What gauge is that chain fella? 8)
http://ballaratebikes.com/
Willow   10 kW
Post by Willow » Nov 08 2015 4:33pm
Samd wrote:What gauge is that chain fella? 8)
missing in action... will be there, I promise.
Willow   10 kW
Post by Willow » Nov 08 2015 4:34pm
Willow   10 kW
Post by Willow » Nov 09 2015 3:40am
Willow   10 kW
Post by Willow » Nov 09 2015 3:58pm
SlowCo   100 kW
Post by SlowCo » Nov 09 2015 4:29pm
Amazingly beautiful build with fantastic details.
Did you keep a record of all the man-hours that have gone into this bike?
Willow   10 kW
Post by Willow » Nov 09 2015 4:33pm
SlowCo wrote:Amazingly beautiful build with fantastic details.
Thanks Slo. man hours -can't say, but in the 100's of. A lot of time spent in preparation - making templates and molds. Could do it second time around now fairly quickly.
still some to do though before I deliver it.
Sean9002   1 kW
Post by Sean9002 » Nov 09 2015 11:23pm
Definitely the most complete cruiser on the sphere!
Is that the standard barrel housing on the key switch? its the only one I've seen that doesn't look like it belongs on an elevator switch panel.
OSET 20+ - Custom frame and swingarm, Motorims - 66V
Ruff Cycles Porucho - MXUS 3000w - whitewalls - Gloss black/Pearl blue/copper leaf - custom tanks - bobber saddle
Giant Glory 00 - Clyte X5404 - Hubsinks - 18FET Sinewave
Fuji Nevada S - MXUS 35mm- Hubsinks - 12FET Sinewave
39inch longboard Dual 50mm, 12s lipo
Willow   10 kW
Post by Willow » Nov 10 2015 5:19am
standard barrel... it's a motorcycle key switch - switches the 12V circuit.
SkyknightJohn   100 W
Post by SkyknightJohn » Nov 10 2015 7:44am
This is what my bikes want to be when they grow up. 8)
Great photography, too.
Willow   10 kW
Post by Willow » Nov 12 2015 4:37pm
...a shot of the charging interface. Charger is on-board.
front wheel first.jpg (156.32 KiB) Viewed 3309 times
Samd   1.21 GW
1.21 GW
Post by Samd » Nov 12 2015 5:46pm
How's the pedelec rego coming along Willow? I am really in awe of you going down this road - its a much needed step methinks.
Willow   10 kW
Post by Willow » Nov 12 2015 8:13pm
Samd wrote:How's the pedelec rego coming along Willow? I am really in awe of you going down this road - its a much needed step methinks.
Thanks Sam.. will be heading to the Engineer next week with paperwork in-hand. I've got it running, and put the chain on. Pedals clear the ground but not by a lot... if you go round a corner with pedal down it will hit (...scratches on pedals now - with a new set to put on before the new owner gets it) but you can effectively pedal it. 27km/h mode still pulling 1500W - heavy bike, and big hills. 250W is just stupid... speed limiting is the only way. I've no concerns about the other stuff - all covered. Brakes work very well, and the speed limiting is very effective. Feels great at high speed - had it to 80 down a hill and felt comfortable doing so.
Filming a clip next week. Post it when done.
S.
Willow   10 kW
Post by Willow » Nov 12 2015 11:56pm
been testing the bike again today...
Mini-E driving a Cro-motor on a very heavy bike. It fails to make it up the last pinch (very steep section) of a long hill - power cuts back as the controller warms up. Controller has some ventilation but could do with some sort of cooling... next time use the Midi-E or Max-E for heavy builds. 30Amp Charging coil gets very hot (hold your finger on it for a while but you can't keep it there)... I'll see if I can fit the 70Amp in there.... not much space though. Might need to put a fan inside the tank to draw some more air me thinks.
After a lot of tweaking I'm still yet to tune it 100%... think I'm close now though. Does anyone know what the WIre PHC - Yes or No option does in the advanced settings??
Samd   1.21 GW
1.21 GW
Post by Samd » Nov 13 2015 1:12am
Any chance to heatsink the mini to the frame, with FET bar touching directly? Thats a lot of surface area you gained if you can....
Willow   10 kW
Post by Willow » Nov 13 2015 4:27am
the FET side is hard up against the fiberglass.... which is not ideal. There is some space below it for cables to run through, so might drill some holes to mount the controller the up-side down so FETS were in the void, and get some alu. angle to lay over the controller as a heat sink.
The controllers have a very fine temperature operating range, but saying that if they are running properly they should run more efficient and cool. Think I've nailed the tuning after a ride just then. I think.
But the heat from the charging coil is quite surprising... have turned it down from 1.5kw to 1.0kw charging to err on the side of caution.
Willow   10 kW
Post by Willow » Nov 16 2015 5:07am
"80 x 6mm aluminium angle, cut down to fit, with thermal paste on contact faces. will be much better."
Not the case, in fact trapped the heat as a large thermal mass and effectively kept the controller hot and would not cool... Need to have lots of surface area ie. fins, rather than mass.
so, I try again. This time I'm going to do the opposite, by suspending the controller, and getting an air gap all around it.
....so DON'T do this.
Willow   10 kW
Post by Willow » Nov 24 2015 6:00pm
Clip from "The Axis of Epic" crew of an e-bike event earlier in the year... Tak'n over the streets on some charged up steeds. Thankyou Willie. Epic.
Willow   10 kW
Post by Willow » Nov 26 2015 4:18am
pic of the torque arm and the chain tension-er. er. er. Chain slackens on lower side when pedaling though with the tension on-top allowed to spring upwards when the chain is under tension. No dramas though.
Bike is now fully functional, tweaked and complete. Bought a box of cold (really good heat sinks) and the mini-e is now covered in them and running cool. er. er. er. and very smooth.
Did the braking tests required for Engineer - from 50km/h bike will stop in 11.2m - got to trust in the front brake. Put new vented pads on the Zee's for the new owner - resin pads held up extremely well after 300km of testing... and would be good for a few thousand km more.
Willow   10 kW
Post by Willow » Nov 27 2015 5:34am
Battery pack - enclosed in the big blue heat shrink, then cased in foam-backed polypropylene. A robust and simple method for casing. The fiberglass tape makes for some simple handles too.
Main plug has the emergency disconnect tag, and has the BMS and pre-charge plug - pre-charge resistor is on the bike side.
bunya   100 mW
Post by bunya » Dec 06 2015 10:29pm
Incredible work Simon, it will be an impressive feat getting this bike registered as a Moped, all the best with testing!
Willow   10 kW
Post by Willow » Dec 09 2015 3:40am
Have made the delivery run to Canberra to the GT's new home at the National Science and Innovation Center.
Keep your eyes out if you are ever in Canberra - you might see it overtake you.
Handover day_s.jpg (203.05 KiB) Viewed 3108 times
voicecoils   10 MW
Post by voicecoils » Dec 09 2015 8:21am
Congratulations, amazing work!
Willow   10 kW
Post by Willow » Jan 02 2016 10:32pm
New year, new bikes, clean stables.
Giddy up.
