jonescg's E-max 110s lithium conversion
whereswally606   100 kW
Re: jonescg's E-max 110s lithium conversion
Post by whereswally606 » Jul 22 2016 7:21am
did you ever get chance to get that DVT file off your scooter controller?
Distributing "Lebowski" FOC Controller PCB (Through hole) since 2016
Moped: Emax 110s 2009
jonescg   1.21 GW
1.21 GW
Post by jonescg » Jul 22 2016 7:27am
Nah, my friend has the laptop with the software and dongle-cord thingy. I might try and get him to email the file to me if possible.
Post by whereswally606 » Jul 23 2016 2:56am
Thanks jonescg
Sent from my ALE-L02 using Tapatalk
jonescg   1.21 GW
1.21 GW
Post by jonescg » Jul 24 2016 7:34pm
I've PM'd you the dcf file. Hopefully you can upload the settings!
Cheers,
Chris
Post by whereswally606 » Jul 25 2016 6:04am
file received thanks Chris. Will be a while before I get any result with this but I have a plan.
DarylMc   100 mW
Post by DarylMc » Jul 29 2017 10:35pm
Hi everyone
I just got a used VMoto 110S.
My first electric vehicle project.
Many thanks to Chris Jones for his help so far.
Thread is here
https://endless-sphere.com/forums/viewt ... 10&t=89788
jonescg   1.21 GW
1.21 GW
Post by jonescg » Jul 30 2017 2:28am
Hi Daryl,
Might be easier to start your own thread; there's a few E-max 110S threads here now.
DarylMc   100 mW
Post by DarylMc » Jul 30 2017 3:48pm
Thanks Chris
Done.
jonescg   1.21 GW
1.21 GW
Post by jonescg » Sep 05 2017 8:23am
10,000 km and going strong. GBS LiFePO4 is pretty solid stuff for longevity.
Rube   100 W
Post by Rube » Sep 06 2017 4:38am
Cool rig, I've been looking at getting an electric scooter to replace the second car.
No idea about makes and models, I'll need to do a bit of research.
DarylMc   100 mW
Post by DarylMc » Sep 06 2017 7:07am
Hello Rube
I bought an EMax recently with help from Chris.
I'm in Brisbane and I am thinking of selling it.
It has no batteries and I just don't think I have the time to get it all going.
You are welcome to come and have a look if you are interested.
jonescg   1.21 GW
1.21 GW
Post by jonescg » Nov 06 2017 4:00am
So after 11,000 km the scooter suffered a failure.
My wife took the bike to work one morning and after about 1 km it suddenly felt very heavy and unresponsive to steer. She nursed it home and took the car. I had a look at it, suspecting a flat tyre but to my horror, the lower steering head bearing race was slopping around :shock:
So it appears that the headstock was machined to accommodate the bearing race, but with about 2 mm of metal to hold it in place! I tried tightening it but it simply refused to stay put. After every ride up the road it would kick out, increasing the trail to the point where it was completely unresponsive to input. So I put a jack under the bike, lifted the front wheel up and gave the race a whack with a hammer. It seemed to be centrally located so the next step was to weld it up. I'm sure I accidentally welded the bearing race to the headstock, but whatever, I don't want it coming off again.
Repair headstock.jpg (166.6 KiB) Viewed 2268 times
Stick welding FTW.
Now it feels much better, but still less responsive than it used to be. I suspect it will just take some getting used to. If it still drives me nuts I can always pull the forks through the clamps and shorten the trail that way. Back on the road at least. Batteries are doing just fine.
Post by whereswally606 » Nov 06 2017 4:22am
:shock: wtf... will be a bit more wary when getting mine to go quicker now.
DarylMc   100 mW
Post by DarylMc » Nov 06 2017 4:30am
Thanks for the tip Chris.
I might give mine a check and perhaps some loctite.
jonescg   1.21 GW
1.21 GW
Post by jonescg » Nov 06 2017 7:00am
Yeah, if you guys don't mind checking, I'd love to see a photo of what it looks like when its not broken.
I'm trying to work out if it was just weak to begin with, or if it was just tacked in place with a couple of lousy welds...
Either way, it's certainly something you should keep an eye on. I suspect it was just poor design, and they never suspected that 90 kg fatties like me would ride it flat out everywhere I go, for 11,000+ km
DarylMc   100 mW
Post by DarylMc » Nov 06 2017 7:42am
DarylMc   100 mW
Post by DarylMc » Nov 06 2017 7:43am
I don't think you should be riding it like that Chris.
Do you reckon yours just had a cup inserted in the frame tube?
The cup and or the frame tube must be really flogged out if it moves enough to alter the fork angle.
jonescg   1.21 GW
1.21 GW
Post by jonescg » Nov 06 2017 6:28pm
Yikes!
It's worse than flogged out, it broke off!
The welds will hold it in place for now. But yeah it sure seems like this bike won't get the 30,000 km I was hoping for.
ecross   1 kW
Post by ecross » Oct 12 2018 2:52am
Hi Chris,
I have a question regarding the emax.
The older emax scooters are now here inexpensive, like from +600 Euro, so a build with 18650 cells are interesting.
How many place is into the emax for a new battery? Do you think a fast version with 72V is possible and make sense?
BR
ecross
NC 2805 mod.
H4080 mod.
4504 mod.
4503 mod. with watercooling
LiIon 24S16P from Sony, Sanyo, Panasonic
Siemens 2000W travel charger
Post by whereswally606 » Oct 12 2018 4:42am
Here is a sketchup8 (free version got to oldversion.com) file to help visualise what you can do with the older emax frame. I have one on ebay now if you want to bid on it. it is only at £82 so far.
calb pack.jpg (120.84 KiB) Viewed 1257 times
emaxBatteryMockups.zip
(1.25 MiB) Downloaded 39 times
ignore the batteries on racks that was my poor mans power wall.
jonescg   1.21 GW
1.21 GW
Post by jonescg » Oct 12 2018 6:31am
In my honest opinion, find 60 Ah of the most garden variety LiFePO4 and use that. Any more than 3 kWh is a waste - the scooter is not much fun to ride long distances anyway. I spent about $1600 on a new battery for my scooter, so that's good value. I can't begin to thing of how sore my bum would be after more than 65 km of riding...
Post by whereswally606 » Oct 12 2018 8:55am
as luck would have it I bought 60ah calb blue cells and put them in my scooter I bought 26s from Latvia and kept the parcel case. I would have to look into how much they would be to post to you. looking for about £600 for the lot. currently 16s are in my emax 90s as I never got round to changing out the controller so I could use the remaining 10. Let me know if you want to do a deal.
reason for selling is that I now have two babies and don't get time to ride the scooter.
you can see the ones in the sketchup file I am talking about. And how the 16s fit in the bottom of the scooter. The extra 10 should fit in the near the steering column
