GCinDC's Zooma Ty Rod II go kart conversion
Electric cars, trucks, ATVs, NEVs - things bigger than a motorcycle.
GCinDC   10 GW
Re: GCinDC's Zooma Ty Rod II go kart conversion
Post by GCinDC » Aug 29 2015 7:32am
so here's the pelican case after adding:
- main on off switch, which also turns off watt meter (on top out of view)
- 8s cell meter with HV/LV alarm and simple 'fuel gauge' meter (needs to be unplugged to deactivate)
- ON (full throttle)/OFF/ON (lower throttle) switch
from top:
- watt meter
- Pot control dial (looks like antenna, lol) for adjustments in the field (my testing)
- the wire is temp, to keep from case from wobbling back and forth - still need stabilizer bar on front side, esp if someone tries to push the go kart by pushing on the case
light and switch (barely visible red switch on front of batt case, just above brake line)
next order of business is sorting out the chain guide/chain length. the original motor sprocket was in a higher position, so the chain angle around the guide was less acute. this is where i've had it w/ new motor, but rubs the tire too:
here's another position that works w/ existing chain guide, but must cause a lot of unec friction:
seems logical that more of the chain that goes AROUND the sprocket, the less of a strain it is on the chain and the more efficient, right?
am i better off w/o a chain guide and shortening the chain? it's guaranteed to start popping off w/o a guide, isn't it?
i think the previous owner hit something w/ the rear wheel as well, cause it's got a bit of a wobble too, which affects chain ring and brake disc. :roll:
this position might be a happy medium, plus i could drill a hole to pop another bolt through the slot:
come on guys, give me some help!
the last little thing will be welding a band aid on the front end to strengthen the frame where the previous owner wrapped it around a tree. i straightened it out most of the way, but needs more. without a rider, the right wheel is slightly off the ground:
i anticipating needing to reweld that inside corner, so taped it when i last painted, but i'm thinking instead of welding 4" of angle iron on the bottom of the frame there after bending it into position...
Youtube channel, 2013 Highlights vid. Ebike Nerdcast.
Giant DH Comp: 20s lipo (11.6Ah), hs3540, Adaptto Mini-E, 900W BMSBattery charger.
GT I-Drive (sold), 20s lipo, 9C, 72V 45A 12FET.
nicobie   10 MW
Post by nicobie » Aug 29 2015 1:20pm
How long do you think it will be until your boys figure out the switches? :mrgreen: :mrgreen:
May your tote always stay tight and your edge eversharp :wink:
my eTownie build thread: http://endless-sphere.com/forums/viewto ... =6&t=23701
The fingers   100 GW
Post by The fingers » Aug 29 2015 5:35pm
You get my vote for ES Dad of the Year. :D
Black Schwinn High Sierra
Blue Schwinn Cruiser 5
Blue Schwinn High Plains
Black Fiore Cruzer 5: Amped Warp Drive 26" Front DD/SLA kit
http://ghostbikes.org/
http://www.rideofsilence.org/main.php
Hebrews 9:27
nicobie   10 MW
Post by nicobie » Aug 29 2015 5:41pm
The fingers wrote:You get my vote for ES Dad of the Year. :D
Yep, me too. As soon as he makes them wear real shoes and not flip-flops when riding the cart. Looking at their front feet when under power makes me cringe.
GCinDC   10 GW
Post by GCinDC » Aug 29 2015 10:30pm
thanks guys! happy to make it w/o any duct tape, except around batts! very unlike me. :P
as for the flip flops, yeah, i agree. but i was making sure they rode it only in the open. and as for the speed switch, hopefully they won't find it till they've learned how to ride it.
that reminds me, i need another big switch for REVERSE!
anyway, it's done for now.
the batt case stabilizer bar:
after welding and painting:
bolted to case and frame:
inside of batt case (8s4p for 23Ah):
oh yeah, removed to chain links and bolted guide thru slot for add'l strength:
ready for action:
GCinDC   10 GW
Post by GCinDC » Aug 30 2015 1:53pm
took the kart to the park for the first time w/ new motor. running 32V and controller drew max 41.5A. :twisted:
motor was cool as a cucumber even after hauling me around. thought i took a lot more vid but must not have turned the camera on.. :roll:
i flipped the switch when i rode, but then forgot to turn it back for kids...
they did a couple doughnuts on the basketball court but i told them to stop. haha
dnmun   100 GW
Post by dnmun » Aug 30 2015 3:14pm
can you make the steering tube collapsible so that a full on front collision doesn't push the steering rod back into their chest or face? maybe a piece of tubing for the center section of that rod so there is space to collapse before being pushed all the way back. split the tubing on the ends with a hacksaw and then use gear clamps to clamp the tubing around the rod on each end.
Hillhater   100 GW
Post by Hillhater » Aug 30 2015 6:37pm
Ideally, you should remove that chain tensioner and shorten the chain to give you more links in contact with the motor sprocket to reduce wear and prevent chain skip.
You will probably have to find a way to make small adjustment to the motor mount to get ideal chain play (tight chains lose power !)
Lurkin   100 kW
Post by Lurkin » Aug 30 2015 9:51pm
Similarly, a guard round the chain to avoid cut off fingers and an overhanging bar at the back might be an idea to avoid the battery box/motor being the first point of contact.
A kill switch immediately available to the driver is also a good idea.
More skids!
GCinDC   10 GW
Post by GCinDC » Sep 01 2015 12:39pm
dnmun wrote:can you make the steering tube collapsible so that a full on front collision doesn't push the steering rod back into their chest or face?
yo d, it maxes at 20mph or less, so can't imagine the steering rod doing that! interesting idea tho. easier to add a bumper?
Lurkin wrote:Similarly, a guard round the chain to avoid cut off fingers and an overhanging bar at the back might be an idea to avoid the battery box/motor being the first point of contact.
More skids!
yeah, a chain guard is a top priority! the batt box is solid, and i'll only need to push it if something breaks in the field.
the brake lever acts as an ebrake, so kindof a kill switch, right?
next mod is a reverse switch! :twisted: arrives tomorrow. i'll mount it near the motor, then run the mini rocker switch to the handlebars or somewhere.
and here's from last night:
GCinDC   10 GW
Post by GCinDC » Sep 02 2015 11:54am
anyone know if any stock chain guards exist for the my1020 motor or similar mounting bolts?
The fingers   100 GW
Post by The fingers » Sep 02 2015 3:20pm
Might be able to cut a Frisbee in half and attach it somehow as a temporary chain guard if it fits. :wink:
Hebrews 9:27
GCinDC   10 GW
Post by GCinDC » Sep 03 2015 8:37am
frisbee, huh? yeah, i guess it's gotta be diy.
latest vid:
motor doesn't get too hot:
40A controller has been awesome too:
dequinox   10 kW
Post by dequinox » Sep 03 2015 8:54am
That is a pretty cool build, and I love that you got your kids right in on the project. I'm waiting for my daughter to get a little bit older before I start letting her around motorized objects. She's 3 1/2, and has been helping me build her play structure. Wood today, metal and magnets tomorrow! :D
On a dusty pew in a vestibule sits the Devil playing pocket pool, he's waiting for the next poor fool who forgot that it was Sunday
STABLE:
HI-V (Retired); Sun Cruiser w/ Hill Topper Kit; Giant Simple Cruiser w/ Amazon 1000W Front Hub.
Parts donated by Rassy and Greenerwheels have made many of my builds possible, THANK YOU!!!
GCinDC   10 GW
Post by GCinDC » Sep 21 2015 8:13am
Hillhater wrote:Ideally, you should remove that chain tensioner and shorten the chain to give you more links in contact with the motor sprocket to reduce wear and prevent chain skip.
advice taken.
also beefed up the motor support with add'l bars. savage welding, lol:
nice peek at my swollen foot in the background. lol. swelling has gone down, but here it is at ripest a week ago. (sprained it playing basketball...)
oh yeah, the prior owner wrapped the front end around a tree or something so i also fixed this:
i cleaned up the area, and put a bead over it (forgot to take a pic afterward)
thanks to thud for real time tech support. :wink:
GCinDC   10 GW
Post by GCinDC » Oct 21 2015 8:27am
kart's been great. but with winter coming, i'm starting to think about the fun we could have in the snow, with certain modifications...
such as large snow blower tires like:
kinda like this vid i found:
and it won't make sense to have only one wheel driving, so i'd need to somehow install a live axle. not sure how to do that yet.
and of course we can upgrade the power as necessary. :twisted:
was thinking skis on the front, but we'll see..
SlowCo   100 kW
Post by SlowCo » Oct 21 2015 1:00pm
GCinDC wrote: and it won't make sense to have only one wheel driving, so i'd need to somehow install a live axle. not sure how to do that yet.
Maybe use a second motor on the other wheel. No need for a live axle and twice the power!
Hillhater   100 GW
Post by Hillhater » Oct 21 2015 5:56pm
Live axle is standard on all track karts, so plenty of parts and know how around.
Handling will be very different though, you really need correct front end geometry ..king pin angles, castor, etc etc to give "weight jacking" on the frame and enough power to help with throttle steering, and good weight distribution.
It can be quite a learning experience to drive a live axle kart...especially on a low grip surface.
Two motors may be a better idea !
The fingers   100 GW
Post by The fingers » Oct 22 2015 12:26am
Just go for 4 motors and 4WD. :twisted:
Hebrews 9:27
GCinDC   10 GW
Post by GCinDC » Nov 17 2015 9:37am
Lurkin   100 kW
Post by Lurkin » Nov 17 2015 4:02pm
bumpers might be in order :D
JerryH   1 µW
Post by JerryH » Jun 20 2016 6:05pm
Hello.
I've read this thread with great interest. I purchased a used Zooma Ty Rod II and am doing an electric conversion very much like yours. This will be the chassis for my son's vehicle in the Power Racing Series race in September. We purchased a 48V motor with a controller and plan to use a 16s 12AH headway pack to power it.
I found the reverse switch that you purchased on Amazon. Did that reverse switch work out for your build?
GCinDC   10 GW
Post by GCinDC » Sep 22 2016 2:56pm
hey jerry, sorry i never replied. the answer was no, i never installed the switch but i have no reason to think it wouldn't work... how's your project going?
in other news, this vid is fairly recent..
maydaverave   10 kW
Post by maydaverave » Sep 23 2016 1:29pm
I had one of those 24volt scooters which I ran at 36volts with no problems. That's a third more power! That looks like a blast.
e-bikekit 50v 9.2ah cellman pack
GCinDC   10 GW
Post by GCinDC » Jan 07 2018 4:08pm
tires needed to be replaced anyway, so why not stud them up (hasty last min job) to give it a go on the iced-over canal?
