Speedict neptune lite
speedict   10 kW
Re: Speedict neptune lite
Post by speedict » Jul 26 2017 11:09pm
Neptune 15 ship now with speed sensor, temperature sensor and 15s balance connector ...
Speedict Technology - Drive . The . Future http://www.speedict.com | http://www.facebook.com/speedict.technology
strepto   1 mW
Post by strepto » Mar 14 2018 11:17pm
So... trying hard to find a review or even detailed specs on this. Anyone here got any experience/links?
mchammer   1 µW
Post by mchammer » Mar 19 2018 7:11pm
I'm installing one today on a 14s6p. Will let you know how it goes.
zro-1   1 kW
Post by zro-1 » Mar 19 2018 9:15pm
Subscribed. I'd love to get some current impressions on the features of this BMS.
~01~
zro-1   1 kW
Post by zro-1 » Mar 19 2018 9:20pm
Will the speed sensor feature work with a speed sensor built into a hub motor if it's using a single magnet and coming from a separate wire?
~01~
speedict   10 kW
Post by speedict » Mar 19 2018 10:35pm
zro-1 wrote:
Mar 19 2018 9:20pm
Neptune 15 use simple magnet on / off type Speed Sensor
up0   10 mW
Post by up0 » Jun 01 2018 5:44am
Hello Speedict,
Comparing the schema from the manual to the picture above:
I have a question: In the schema Charging and Motor-Controller Wires are connected where they enter the Neptune.
On the photo this is not the case.
I assume they are connected on the inside, and there is no logical difference between charging and dis-charging wires.
The reason I ask is Regenerative breaking: This would provide charging-energy coming FROM the Controller-Wires, and not via the Charging wires.
I am 90% sure you will tell me that they ARE connected and regen-breaking is fine,
but I wanted to make sure that was really the case!
A few more questions:
* I assume you can run the Neptune without connnecting it to Bluetooth?
* Does the unit wake up automatically somehow when the Bike is used? Or will there be no power on the Load-Wires until the button on the device is pressed?
* What is the roadmap for the Neptunes? ( = Any new models coming out soon?)
Thanks, Ulli
speedict   10 kW
Post by speedict » Jun 01 2018 6:24am
hi Ulli,
please focus on neptune15-real.jpg, wire pairs of CONTROLLER(discharge) and CHARGER(charge) are connected differently inside Neptune, the DISCHAGE path is bypass CHARGE MOSFET (see pic "current flow diagram (split)").
they are not connected together inside, so the answer is "yes" and "no", you can still get regenerative current which is forward diode of DISCHARGE control MOSFET, that's mean Neptune couldn't control over-cell voltage cut-off, in the event of cell-over-voltage Neptune just simply turn OFF CHARGE MOSFET but discharge current still flow in reverse direction, sorry about that :(
If you want to control regenerative current, we can solder wire to CHARGE path (current flow diagram (non split).jpg ) and provide different firmware for upgrade as we did for one of our customer who are going to participle long trip from Lyon to Canton(china) powered by solar panel ...
yes
turn on or off via POWER SWITCH, no power on Load-wires while switch off, that's good for inrush current protection.
Neptune 20 cell version
Neptune 15 + Throttle control (like Mercury)
should you have any more queries, please don't hesitate to post question here !
Danny
current flow diagram (split).jpg (45.07 KiB) Viewed 7928 times
current flow diagram (split) - all path.jpg (65.93 KiB) Viewed 7928 times
current flow diagram (non split).jpg (45.99 KiB) Viewed 7928 times
handbaked   100 W
Post by handbaked » Jun 30 2018 4:02pm
Is the Neptune 15 available to buy still? Can't see buy button on website.
Also what are peoples opinions on this BMS now it's been out for a little while?
I have had multiple failures of cheap BMS where they have allowed individual cells to drop way lower than the rest, without turning off the power.
Cheers.
speedict   10 kW
Post by speedict » Jun 30 2018 9:11pm
the check out button still there, on website menu -> SHOP -> select Neptune 15 -> ADD TO CART -> and CHECK OUT
so far so good, we are still improving Neptune 15, 6 firmware and 5 android upgrades since last year, a new request from customer 2 days ago was put realtime temperature reading on Dashboard page.
On Neptune 15, you can set Cell under voltage cut-off, e.g. 2.5v for Li-Ion :)
handbaked   100 W
Post by handbaked » Jul 01 2018 5:58am
What is the difference between Neptune lite and Neptune 15?
speedict   10 kW
Post by speedict » Jul 01 2018 6:08am
Neptune Lite display / monitor cell information only without charge / discharge / balance features.
Danny
handbaked   100 W
Post by handbaked » Jul 01 2018 12:48pm
Thanks for the info. What is the maximum current of the Neptune 15. I just bought one without checking! I am running high current, so it may not be usuable on this particular project.
speedict   10 kW
Post by speedict » Jul 01 2018 12:52pm
it is 60A
handbaked   100 W
Post by handbaked » Jul 01 2018 1:43pm
Ok great. I'm running peaks of 50A, so that's good. I look forward to receiving and trying this out. I will be running it on a 15S4P HG2 pack. Currently out of balance due to a previous BMS letting me down. I intend to give this battery quite a thrashing, so will post my findings here.
speedict   10 kW
Post by speedict » Jul 01 2018 8:40pm
handbaked wrote:
Jul 01 2018 1:43pm
in the mean time please download Neptune 15 user guide and focus on page 25, 26 and 27 when received your Neptune 15 next week ...
1. solder the 15s balance connector to your battery pack.
2. make sure polarity (red wire solder to your 15s terminal, since your pack is 15s) and adjacent cell do not excess 5v.
3. no rush to connect / test charge discharge function by connect battery pack's discharge wire to Neptune 15.
4. just connect balance connector to Neptune 15, switch on, pair and connect with Android device.
5. get familiar with Android client interface, you can start with BALANCE only feature to reduce your cell delta to mV level.
Danny
Ivanovitch_k   10 W
Post by Ivanovitch_k » Jul 07 2018 6:41am
I just got a Neptune 15, here is what I intend to do with it + mini review of the BMS itself:
I'm currently designing a custom logging and control board with all the connectivity you can get ( 3G / 4G / Wifi / BT / GPS ) embedded in the bike. The end goal is to access it with a website, possibly extended to iOS and watchOS apps in the long run.
I searched a good BMS to get infos on the battery health and runtime stats. It also needed to be more reliable than the generic Chinese BMS.
The Neptune fitted the bill but with one small problem, it doesn't exposes it's data any other way than through BLE and it's Android app.
Fortunately, it uses the popular HM-10 BLE module to which it sends and receive data through AT commands over an UART link.
I will need to reverse engineer all the AT commands and replicate them with my board. Not hard but a bit long :D
I plan on installing the Neptune in a Reention downtube-integrated battery , mounted on a Frey AM1000 bike where my custom board will sit. This battery uses a discharge connector with 4 auxiliary data pins so I will forward the UART and BMS on/off lines through them.
An obvious benefit is that the main board will be able to automatically switch on the BMS only after the battery connector is firmly seated, hence no more arcing !
A nice upgrade I'll probably look-into will be to tie the BMS on-switch with the battery key lock. A proper ingition switch :mrgreen: !
Let's go on with the BMS hardware review:
The clear shrink-wrap was removed. I noticed those 4 hex screws were barely tightened.
@Speedict: a bit of thread-locker would be welcomed.
CONTROL PCBA
nice board, STM32L brainbox, the aforementioned HM10 module running a Ti CC2541, a very good TI BQ7694 monitor & balance chip, connectors for the on/off switch, a speed sensor and a pack temp sensor.
There is also a Spansion / Cypress SPI Flash chip (128 Mbit ? cannot find datasheet) the neptune uses for logging.
POWER PCBA
only brand-name parts, they sure didn't skimped on the BoM:
Charge mosfets are International Rectifiers IRFS3607, discharge ones are Infineon OptiMos 054n08n, rectifiers are On-Semi and Diodes INC. Charge traces are beefy and tin-plated. Discharge ones have brass (?) bus bars.
Overall, a very nice BMS.
Still, there are a few points I have mixed feelings about:
  • No conformal coating. Easy to add DIY, but I reasonably expected one on a high-end part like this,
  • The power wiring is surface soldered. No pulling and lead-securing away from vibrations mandatory !
    Selastic or a clamp would have helped.
  • The distance between the battery leads is VERY SMALL !!! Why not have them at the opposite end of the board like on many other bms ? With the lack of coating, less than a millimeter is protecting the pack from an dead short :roll: . I will add a fuse on the pack lead (+ polyfuses on the balancing leads).
What @Speedict could look into for future Neptune modules is to make cutouts in the thermal backplane to allow through hole soldering. It would probably good to do it also on the charge / controller side.
Similar to this (minus the crappy soldering job :mrgreen: ):
And an even better approach would be to have the leads crimped with eyelets ends and have them screwed in.
BBS'ed Radon ZR Team 8:
BBS02B 750W - DPC750C - 48V 17.5Ah GA shark - 11 spd 11-40 Shimano XT, 42T N-W Precialps CW, KMC X11e chain, Gearsensor, XT RD, XTR Shifter, F Saint Brake, R XT Brake, RT99 200/160 Discs, magnetic shutoff, DT Swiss X1900 QR9 wheels, Manitou M30 air fork, 2.4" slick balloon schwalbe Super Moto X tires @2 bars, Suntour NCX suspension seatpost, ergon SFC3 saddle, ergon GP3 grips, Supernova M99 Pro + E12 Taillight
Bg-electric-cycle   10 W
Post by Bg-electric-cycle » Jul 14 2018 3:49am
Excellent thread and thank you to the above poster for that insider data.
I fast charge 8 amp 13p 10s battery and that latest charger I requested a voltage cut-off of 40.5 volts. The charger was meant for use only when was out and about visiting various people and far flung villages.
Short from the long cell voltages.
Readings from BMS balance lead. Actual cell voltages
cell 1. 3.65 3.65
2. 6.13 2.48
3. 10.20 4.07
4. 14.27 4.07
5. 18.30 4.03
6. 22.30 4.00
7. 26.30 4.00
8. 30.00 3.70
9. 34.00 4.00
10. 38.10 4.10
Without any want to dismantle this pack and on the basis all the cells are good.
Question.
Will the Neptune BMS, resolve the unbalanced cells?
Noted 2.48volts below 2.5. I will in a few hours check the pack again and charge for a short while via a charger: 2 amp 36 volt 42 volt cut-off.
rosich   100 mW
Post by rosich » Jul 14 2018 11:20am
Bg-electric-cycle wrote:
Jul 14 2018 3:49am
cell 1. 3.65 3.65
2. 6.13 2.48
3. 10.20 4.07
4. 14.27 4.07
5. 18.30 4.03
6. 22.30 4.00
7. 26.30 4.00
8. 30.00 3.70
9. 34.00 4.00
10. 38.10 4.10
Question.
you can use Neptune 15 as standalone balancer or discharge all cells except cell #2 to reduce cell delta of pack and then charge it up and standalone balance again, repeat these steps until cell delta voltage to acceptance level.
offpist1   10 mW
Post by offpist1 » Sep 29 2018 11:24am
My application is for an 13S Lithium Ion with 10A charge and 200A peak discharge.
Instead of using the "controller output" on the Neptune 15 directly to the controller, can use this output to control an relay instead?
I understand i will not be getting current readings this way but that is less important.
I see the chage port can handle 20A so that should be ok.
aaron_mason   100 mW
Post by aaron_mason » Oct 18 2018 11:53pm
Hi Speedict - Just curious if you guys have a 20s, higher amperage version of the Neptune in the works. There was mention on your FB page of a 20s version in the works. Thanks!
offpist1   10 mW
Post by offpist1 » Oct 19 2018 1:38am
offpist1 wrote:
Sep 29 2018 11:24am
To answer my own question, yes this works well.
I now let the Speedict BMS controll an 500A rated relay.
speedict   10 kW
Post by speedict » Oct 21 2018 10:04pm
aaron_mason wrote:
Oct 18 2018 11:53pm
sorry I didn't receive any notification from this thread !
yes we did 20s working long time ago but now we are focusing on other project, since recently we have received more 20s enquiries, we should consider build some units and start recruit beta tester :D
speedict   10 kW
Post by speedict » Oct 21 2018 10:07pm
aaron_mason wrote:
Oct 18 2018 11:53pm
could you send your message to us ? at least I can put you to our beta users list first, thanks for your help !
7tronics   100 mW
Post by 7tronics » Oct 26 2018 5:04pm
Thank you for the review of the Neptune 15! We would like to incorporate it into designs where the individual cell leads may not be available.
Can this Neptune 15 be setup without connecting anything to the battery pack but the + and - discharge terminal leads?
How can a separate charge and discharge connections from a battery packs own BMS be connected?
Best, Mark
Ivanovitch_k wrote:
Jul 07 2018 6:41am
Mark Smith, @W4CHL W4CHL Wiki
Triad Electric Vehicle Assn
eBikes: 2001 Currie eFolder, 2001 Currie Mtn, 2005 Giant LaFree Lite, 2008 & 2010 Currie Trailz, 2010 iZip Via Rapido, 2011 Powabyke Shopper, 2007 Optibike 600, 2010 Marin Bikes BionX MTB
Other LEVs: 2007 Currie Tech eZip 500 eScooter, 2013 OT ELF, 2014 OT Naked ELF, 2019 Segway/Ninebot GoKart, 2021 CycleBoard Elite Pro, 2021 CycleBoard Rover
