Kona mid drive with tidy battery and enclosure
mushymelon   1 kW
Post by mushymelon » Nov 16 2015 2:06am
I would like the thank my friend Chris for creating such an awesome battery box, amazing craftsman and good friend!
Heres some pics of my build I'm gonna start with the battery and enclosure because that whats really special about this build.
I first started with used cells and a Styrofoam prototype to make sure everything is going to fit.
My welding station
I would like to thank JP, member riba2233 for creating an amazing welder for the diy crowd.
Affordable battery welder that works fantastic and runs on 12v batteries pure genius.
Heres a link to his sale thread
https://endless-sphere.com/forums/viewt ... 31&t=68865
Drilled holes in the desk to hold the welding rods. Safe and accessible
Battery Tester
Created a battery jig to keep the dimensions of the pack when gluing them together.
Worked out well.
Battery
14S 5P Panasonic NCR18650PF cells
The cells for this build are from member tumich, Thanks
https://endless-sphere.com/forums/viewt ... 31&t=61608
Each cell is wrapped at the bottom and top with filament tape to prevent chaffing they also have stick on paper insulators on the positive ends these are highly recommended.
The Battery Box
Constructed out of 1/8 inch board, tacked together with hot glue then Fibreglass overtop.
On goes the fibreglass
Grommet hole
Nobody likes a sloppy hard to install grommet that falls out after the first ride.
Metal reinforcement inserted into the box, this is where it will be bolted to the water bottle nutserts.
Filled, filed and sanded smooth
Primer
Paint
This shot really shows off Chris' skills you can see the channels where it slips into the frame on one side and locks up into place.
There is also a channel for all the shift and brake cables to run hidden above the box. A real work of art.
Grommet hole came out nice
Watertight seal inside the lid
Tidy cables routed stealthily above the box
Batteries a perfect fit too I can remove the panel and swap out a battery in under a minute without any fuss.
Built up shoulders and one layer of foam to prevent squeaks and to fully lock the box into the frame
Front
The Bike
Thats Chris' sweet Kona Stinky on the right
Slim
Thanks for checking out my build
Matt
fesanand   10 W
Re: Kona mid drive with tidy battery and enclosure
Post by fesanand » Nov 16 2015 3:48am
I wasn't going to expect that result specially seeing the first pictures. Wow! the result is impressive, best detailed-shape enclosure seen so far. Congratulations. :D :D :D :D :D
Do you know the final weight of the enclosure, net without batteries?
Lurkin   100 kW
Post by Lurkin » Nov 16 2015 3:53am
Super tidy, well done. Especially a fan of the custom battery welding man bench and testing unit. Awesome!
mushymelon   1 kW
Post by mushymelon » Nov 16 2015 4:08am
fesanand wrote:I wasn't going to expect that result specially seeing the first pictures. Wow! the result is impressive, best detailed-shape enclosure seen so far. Congratulations. :D :D :D :D :D
Haha ya the prototype battery and box was just to make sure the battery would fit the way I planned.
It also served as a good reference point when constructing the real enclosure.
I didn't weigh it but its very light around a pound i think.
Thanks for the kind words.
Matt
mushymelon   1 kW
Post by mushymelon » Nov 16 2015 4:10am
Lurkin wrote:Super tidy, well done. Especially a fan of the custom battery welding man bench and testing unit. Awesome!
Thanks Lurkin
The first of many battery builds I hope.
