WHAT DOES $600 BUY?
2old   10 kW
WHAT DOES $600 BUY?
Post by 2old » Dec 07 2015 8:06pm
Read enough by wesnewell about YESCOM's 48V, 1000w kit that it seemed appropriate to try one. Finally got around to mounting it on a Tidal Force frame that was laying around doing nothing and coupled it with a Luna Cycle 52V, 10 ah battery. Assembly was easy with the only glitches revolving around mounting the battery since the frame's triangle wasn't adequate with the controller mounted there. Ended up strapping it on a front rack. Anyway, couldn't be happier with the conversion; speed must be close to 30 mph; 170 pound rider, flat road, no wind; 50 - 60 pound bike (no speedometer yet). So for $250 (kit) and $350 (battery), you can make a pretty nice conversion to an existing donor bike. My photographer is ill, but pictures when she recovers.
tipsy13   1 mW
Re: WHAT DOES $600 BUY?
Post by tipsy13 » Dec 09 2015 7:55am
Good on you. Tried any Hills? Rear motor?
2old   10 kW
Post by 2old » Dec 13 2015 7:58pm
Rear and I've yet to try it on any steep hills, but it has enough pickup that I think it'll be good. Will get out to a local fairly steep hill in the next week and report on it.
tipsy13   1 mW
Post by tipsy13 » Mar 14 2016 4:33am
Any updates?
2old   10 kW
Post by 2old » Mar 14 2016 11:04am
Local hill about half mile long (but I don't know grade; probably 400' elevation change, but that's a WAG); climbs well with no sign of overheating. Really happy with this system for a very reasonable price. Look at others who use it; maybe they have better data. It ascends anything around my burg.
motomech   1 GW
1 GW
Re:46V/10Ah battery w/ charger for $200
Post by motomech » Mar 14 2016 12:35pm
I'm putting together the lowest possible cost useful battery pack possible for a friend with no money. This what I have come up so far; (prices include shipping)
http://www.hobbyking.com/hobbyking/stor ... _Pack.html
$130
http://www.hobbyking.com/hobbyking/stor ... duct=74030
$30
http://www.hobbyking.com/hobbyking/stor ... T_XH_.html
$3.50
http://www.hobbyking.com/hobbyking/stor ... allel.html
$3.00
http://www.ebay.com/itm/HP-Proliant-DL3 ... 86529369?h
$35
Obviously, the pack would have to be broken down for charging, a real pain. But he has more time than money.
Motomech
'03 Rocky Mountain Edge 2WD 260 Q100H frt and Ezee V1 rear 2 Elifebike 20A & 25A 9-FET controllers 12S/10Ah Multistar Lipo rear 4Ah Turnigy frt Luna Cyclops Extra lite Alex 24DM rims, Crazy Bobs run ghetto tubeless. 25 mph. Mean Well HLG-320H-54A
https://endless-sphere.com/forums/viewt ... =3&t=83430
'07 GT Idive 4 4.0, Q100C 201 14S LiPoly elifebike 9-FET 20A controller. 23 MPH.
https://endless-sphere.com/forums/viewt ... 4#p1378484
terminus   100 mW
Post by terminus » Mar 14 2016 4:55pm
I'm not real good at math but aren't those lipo packs 22V? How does that equal 46V when you build the pack? And is there a way to change the LVC on those cheapo motor kits so it doesn't cut off at 46v, or 44v, or whatever it is?
Jon NCal   1 kW
Post by Jon NCal » Mar 14 2016 5:59pm
terminus wrote:I'm not real good at math but aren't those lipo packs 22V? How does that equal 46V when you build the pack? And is there a way to change the LVC on those cheapo motor kits so it doesn't cut off at 46v, or 44v, or whatever it is?
On lipos 50% capacity is about 3.85 volts per cell, 12S = 46.2V. Controller Low voltage cutoff is usually 42V; 42/12S = 3.5V per cell, which is correct for lipo.
Also see the Multistar 10000mah 6S are about $50 on sale now.
Hodie Doe   1 µW
Post by Hodie Doe » Mar 14 2016 8:02pm
the build
As far as the yescom rear hub motor and hills i have 793 miles 40hrs 18mins average 19.73 MPH and the hills range from 4% grade 2 23% a few steeper but i do not run those routes often . 0n 4% to 10 it maintains 22 to 18 mph steeper hills the speed drops but most with minimal peddling you can maintain 15 to 20 MPH . Mine and the bikes weight is 320 Lbs battery is 48v 30ah bike is a reused currie CB 24V450 . Battery will carry me with little peddling on a full charge 64 miles . and with peddling i have not found out yet. Battery was purchased from Koyochen on ebay . Hub motor was purchased from JET with discount for 209 and battery was 600 the bike i purchased in 2006 at Walmart for 275 and hadn't used it since 2010 .
the build
Zeusless   100 µW
100 µW
Post by Zeusless » Apr 07 2016 10:33am
Do you notice any kind of stress / overheat from going up those hills?
Hodie Doe   1 µW
Post by Hodie Doe » Apr 08 2016 10:11pm
one hill down from my house puts some stress on the motor and it gets warm but most hills it is cruising at 16 to 20 mph and stays pretty cool . now the temps when i have ridden have been between 55 to 78F so when the summer months come i will know if it gets hot or more stressed . have even ridden it in a strong storm that i got caught out in with no damage to any of the parts . also head winds will slow you down a few mph . have had no overheat problems though .
2old   10 kW
Post by 2old » May 26 2017 8:11pm
18 month update and both the motor and battery (doing double-duty in a BBS02 conversion) are performing perfectly. Top speed (before I shut it down was 32 mph (gps system). Wish that I'd achieve wes' or mci's mileage, but doubt it.
2old   10 kW
Post by 2old » Oct 26 2018 10:49am
Three years and system still functions well, although traffic in Orange County has minimized running errands (I moved to a more urban area sometime ago). Battery has been used for the same interval powering a BBS02 off road. Probably has 400+ charges and still functions adequately although I have no quantitative data.
Reggy   1 µW
Post by Reggy » Feb 18 2019 12:25pm
Is there any rating of TOP e-bikes under 1000$? Top 3-5 the best ones for newbies? Thank you.
2old   10 kW
Post by 2old » Feb 18 2019 8:04pm
This site caters to the DIY crowd, so lots of good information for building your own which has a lot of advantages since you'll have the satisfaction of the project as well as knowing how to troubleshoot. The only thing I can suggest for your needs is to define them (speed, distance, terrain, your weight etc). I looked at a few sub-$1000 on Amazon and was amazed that some had been highly rated by verified purchasers.
Reggy   1 µW
Post by Reggy » Feb 19 2019 6:41am
Thanks for your advice! Continue reading DIY articles
2old   10 kW
Post by 2old » Feb 19 2019 10:56am
If you're interested in a 30+ mph, inexpensive e-bike, look up what wesnewell and mcintyretj (sp?) have constructed. Personally, I would purchase a better donor bike (Craigslist), but their bikes have impressive mileage.
Reggy   1 µW
Post by Reggy » Feb 20 2019 12:14pm
Yeah, thanks I am reading this guide https://endless-sphere.com/forums/viewt ... =3&t=66302 - right now
2old   10 kW
Post by 2old » Feb 22 2019 12:19pm
BTW, recently took this motor (with a 52V mini battery) and added it to a conversion with a 350w front hub PAS. Always wanted to see what a 2WD with separate dedicated systems would be like. Really good acceleration, but impractical for me because the weight, while nicely balanced, didn't appeal, and the extra acceleration was a little out of bounds. Now it's on a 1985 Schwinn High Sierra for its fourth year and running smoothly
