Crystalyte Controllers - Repair and Modification information
fechter   100 GW
Post by fechter » Apr 19 2007 9:49am
Here's information I've gathered by reverse-engineering a couple of controllers.
The information is based on the examples I've worked on, but there are variations in the models, so individual components and wire color codes may vary.
The ones I'm working off were apparently 24 - 36v, 35 amp models.
The basic circuit board seems to be the same on all the 35 amp models.
For starters, here's the owner's manual. I don't necessarily agree with everything in there, but it's a good reference:
Crystalyte_Owner_Manual.pdf
(3.82 MiB) Downloaded 2045 times
fechter   100 GW
Post by fechter » Apr 19 2007 10:08am
The basic building blocks of the Crystalyte controller are the uPC1246C brusless motor commutator chip, the KA3525A PWM chip, the IR2101 gate driver, and a dozen IRFB4710 output FETs.
Here's a block diagram of the C1246 commutator chip:
The hall sensors are supplied with power from the controller (I measured 6.8v) and the ouputs from the sensors go to the C1246.
C1246 commutator.pdf
Here's the complete datasheet
(1.74 MiB) Downloaded 1034 times
uPC1246 commutator block diagram
uPC1246C block diagram.jpg (27.96 KiB) Viewed 27479 times
fechter   100 GW
Post by fechter » Apr 19 2007 10:11am
The output from the commutator chip goes to three IR2101 gate driver chips, one for each phase. The IR2101 provides the proper timing and voltage requirements for the FET gates.
fechter   100 GW
Post by fechter » Apr 19 2007 10:18am
The ouput stage is really three identical sections, one for each phase. The FETs switch the phase wires to the battery +, the battery -, or stay open, depending on what part of the cycle they're in.
The FETs that switch to the battery + are called the high side FETs.
The FETs that switch to the battery - are called the low side FETs.
The high side FETs need to have the gate voltage driven 10 volts higher than the supply when they are on. This is done by a "bootstrap" circuit, that supplys the elevated voltage from a capacitor that gets recharged during the off part of the cycle.
Here's a reverse engineered schematic of one output stage.
Keep in mind there could be some mistakes in the drawing.
Brushless Controller Output stage.jpg (17.95 KiB) Viewed 27455 times
fechter   100 GW
Post by fechter » Apr 19 2007 10:21am
To control the speed of the motor, the high side FETs are pulse width modulated (PWM). The PWM is done with a KA3525 chip.
A block diagram of the KA3525 is below:
KA3523 block diagram
KA3525A pwm block diagram.jpg (29.84 KiB) Viewed 27370 times
KA3525A.pdf
(84.09 KiB) Downloaded 622 times
fechter   100 GW
Post by fechter » Apr 19 2007 10:26am
The battery current is measured by measuring the voltage drop across a shunt that goes between the battery - wire and the bank of FETs.
The shunt has a resistance of around one milliohm. This means for every amp of current, the voltage across the shunt will be one millivolt.
The shunt is made from four wires of a special alloy that does not change resistance much with temperature. It is located on the bottom side of the circuit board.
Current measuring shunt
Shunt Resistor.jpg (74.34 KiB) Viewed 27345 times
fechter   100 GW
Post by fechter » Apr 19 2007 10:32am
The signal from the shunt goes to a section in the KA3525 to form the current limiter circuit.
The low voltage cutout is combined into the same part of the circuit.
When the current tries to exceed the limit (35 amps), the comparator in the KA3525 starts to reduce the duty cycle of the PWM to keep the current at the limit.
If the battery voltage drops enough, the same comparator will reduce the duty cycle to prevent the voltage from dropping further. This results in a loss of power when the battery hits the LVC.
Here's a reverse engineered schematic of the current limiter / LVC part of the circuit.
Current limiter circuit
Brushless Controller Current Limiter.jpg (41.1 KiB) Viewed 27287 times
fechter   100 GW
Post by fechter » Apr 19 2007 10:36am
The current limit is determined by the values of the resistors.
If we want to vary the current limit, a resistor network and variable resistor can be added to allow the current to be adjustable.
This drawing shows how to make the limit adjustable downward.
Adjustable current modification
Brushless Controller Adj Current Mod2.jpg (26.82 KiB) Viewed 27181 times
Location of the IC pins on the board
Brushless Controller Adj Current pcb.jpg (73.15 KiB) Viewed 27143 times
fechter   100 GW
Post by fechter » Apr 19 2007 11:15am
The stock FETs are IRFB4710's in most controllers. They're rated for 100v, 75 amps each, with an on resistance of 14 milliohms.
In the output stage, the FETs are in pairs, so the total current rating would be 150 amps.
At low throttle settings and a 35 amp current limit, the current in the FETs can be over 100 amps due to the current multiplying effect of the PWM.
The stock FETs have a poor track record as far as failures and I suspect they are being pushed close to the limit in the stock configuration.
If we want a higher current limit, new FETs would be advised. There are a number to choose from.
Below is a spreadsheet of many possible replacements. The best ones on the market today are the IRFB4110's. They seem to be in short supply these days, but have a much lower on resistance and much higher current capacity.
FET selection guide.xls
(20 KiB) Downloaded 937 times
fechter   100 GW
Post by fechter » Apr 19 2007 11:17am
If we just change the FETs, the current limit will still be 35 amps. If we want a higher current limit, the best procedure is to "beef up" the shunt resistor.
I found that if you fill in between two of the shunt wires with solder, the new current limit will be around 60 amps.
You could also leave the shunt alone and change the limiter circuit resistors, but the stock shunt might overheat and melt at a higher current, so it's better to solder up the shunt.
fechter   100 GW
Post by fechter » Apr 19 2007 3:18pm
Below is a picutre of the board with the connectors labeled.
The fat black and red wires go to the battery. The fat yellow, green, and blue wires are the motor phase wires.
Yellow= A
Green= B
Blue= C
The hall sensor wires have corresponding phase colors, the black and red wires are the hall sensor power feed.
The throttle wires as shown are
Red= +5v
Black= ground
White= signal
Brushless Controller Connections.jpg (70.62 KiB) Viewed 27062 times
fechter   100 GW
Post by fechter » Apr 19 2007 3:21pm
The low voltage cutoff circuit is made up a three resistor voltage divider and a diode. When the voltage at the high side of the 5.1k resistor gets low enough for the diode to conduct, it starts reducing the output.
You can change the value of the resistors to get any low voltage cutoff you want. You could install a variable resistor to make the cutoff voltage adjustable.
fechter   100 GW
Post by fechter » Apr 20 2007 9:22am
On the bottom of the board, we can see all the FETs and two other similar sized devices. One is an overtemperature thermostat, which will kill the power if the heatsink temperature gets above 70C.
The voltage regulator transistor takes the battery voltage and steps it down to around 15v. The transistor has a 400v rating. The 15v powers the control circuits and also feeds a 5v regulator.
Brushless Controller backside.jpg (75.4 KiB) Viewed 26939 times
fechter   100 GW
Post by fechter » Apr 27 2007 12:21pm
One weakness in the design is the way the FETs are insulated from the screws. There's a thin piece of heat shrink tubing that surrounds the screw along with a fiber washer under the head.
FET insulator standard.jpg (70.43 KiB) Viewed 26662 times
fechter   100 GW
Post by fechter » Apr 27 2007 12:27pm
The stock heat shrink tubing has a very thin wall and is easily punctured.
One way to improve on this would be to use thicker tubing to insulate the screw. I found some nice Teflon tubing that barely fits in the hole. The wall thickness of my tubing is more than the depth of the threads, so there's not much chance of cutting through.
The "downtown" way to handle the insulation would be to buy a set of specially made washers that have the sleeve built in. These come in different sizes, so it would be good to find some that had longer sleeves.
FET insulator improved.jpg (88.67 KiB) Viewed 26514 times
Heatsink Washer.jpg (33.02 KiB) Viewed 26557 times
fechter   100 GW
Post by fechter » Apr 27 2007 12:29pm
FET REPLACEMENT
Here's our test subject; a Crystalyte 36v - 72v, 35A immediate start controller.
Before picture.jpg (44.57 KiB) Viewed 14728 times
fechter   100 GW
Post by fechter » May 02 2007 3:02pm
Start by removing all the screws on the end plates and on the bottom.
I like to keep some zip-lock bags around to put the screws into so they don't get lost.
fechter   100 GW
Post by fechter » May 02 2007 3:04pm
After removing the screws, the guts will slide out in the direction of the wires.
The wires going to the reverse switch will need to be disconnected. Just cut them off. If you need a reverse feature, the wires will need to be reconnected later. If you leave them cut off, the controller will be permanently forward.
fechter   100 GW
Post by fechter » May 02 2007 3:08pm
The next step is to remove all the screws holding the FETs onto the heatsink. The screws for the regulator and thermostat must also be removed.
The screw for the voltage regulator will hit the circuit board before it can be fully removed. Remove all the other screws first, and then the regulator screw can be removed.
Be careful with the voltage regulator and overtemp thermostat. Bending the legs can cause them to break off.
Brushless Controller backside.jpg (75.4 KiB) Viewed 14703 times
fechter   100 GW
Post by fechter » May 02 2007 3:21pm
I like to remove the FETs intact so they can be reused. For newbies, it's best to use a small wire cutter and snip off the FET legs close to the FET body. Leave as much leg sticking out of the board as possible.
BE SURE you don't snip off the thermostat or voltage regulator. :oops:
Before unsoldering, I recommend using a wire brush to clean the connection points. This will help the heat transfer when soldering.
fechter   100 GW
Post by fechter » May 02 2007 3:25pm
It's real handy if you have a circuit board vice to hold the board while working on it. Adequate lighting and magnification help us older, visually impared types.
fechter   100 GW
Post by fechter » May 02 2007 3:28pm
Getting the old FET legs out of the holes and clearing the holes is the hardest part of the whole job.
There are many techniques for removing the parts. I'll show a few here, but use what works best for you.
I'll start by attempting to de-bulk the big pile of solder around the leads with a solder sucker.
fechter   100 GW
Post by fechter » May 02 2007 3:41pm
When desoldering anything, you must limit the amount of time you heat the connection to avoid damaging the board and lifting traces.
Heavier connections take longer, but I would limit heating time to less than 15 seconds on even the heaviest connections.
The idea is to heat the joint, suck, and get out as quickly as possible.
To speed up the heating process, good thermal contact is a must.
I wipe the iron tip with a wet sponge, then apply a tiny amount of fresh solder to the tip to get better heat transfer. Once you tin the tip of the iron, you have about 20 seconds before the solder oxidizes to the point where it needs to be redone.
Another important point: The traces with heavy solder buildup take a lot of heat to melt. It works best to heat from the heavy side.
fechter   100 GW
Post by fechter » May 02 2007 3:48pm
With the tip freshly tinned, press the tip into the intersection of the FET leg and the solder trace.
You want to make physical contact with the leg so the heat can follow it down through the board until it melts to the other side.
As soon as the leg moves or the solder looks melted for a few millimeters around the hole, bring the solder sucker right down on the intersection of the leg and the board, opposite of the iron.
Hit the suck button and remove the heat.
fechter   100 GW
Post by fechter » May 02 2007 4:00pm
Here's an attempt at a video:
<embed src="http://www.youtube.com/v/SPGTI29RZro" type="application/x-shockwave-flash" width="425" height="350"></embed>
I was having camera problems, so please excuse the poor quality.
