5-16S Smart Tiny BMS preorder - 30/150/750A rated
circuit   100 kW
Post by circuit » Feb 29 2016 1:52pm
Finally we are ready for some action. Here is what's up for sales:
More pictures: viewtopic.php?f=14&t=76011&start=50#p1153207
We call it Tiny BMS. Because it's obvious.
The BMS has been discussed in depth on this thread: viewtopic.php?f=14&t=76011
Please keep all the technical Q&As there.
There are two models available:
1. "30A"
2. "150A"
Both models include:
- open protocol USART communication, USB and bluetooth available (BT module and USB-USART converter available separately)
- fully configurable settings: cell count, capacity, voltages, temperatures, etc.
- event log, statistics, encrypted bootloader for firmware updates
- 100 mA balancing current
- one internal and 2 external temperature probes (external probes available separately)
- status LED and warning buzzer
- 5V output
- CycleAnalyst v3 compatibility: periodic data broadcast using CA v3 protocol (there are Android apps available! here and here)
150A model adds some more value:
- obviously includes bidirectional 150A hall sensor
- includes additional connector for bidirectional 750A LEM sensor (sensor available separately)
- Includes aluminum plate for heatsinking and better mechanical protection
- includes two additional connectors with programmable universal inputs and outputs:
- - inputs: digital 0-70V;
- - inputs: analogue 0-70V;
- - outputs: digital active low (open drain) with PWM ability
This all gives the ability to:
- speed input: measure speed and predict remaining operating time or distance
- control the contactors (in future, 24V and 12V as well, thanks to PWM/DAC hardware)
- wakeup/ignition signal input
- drive of motor controller's "enable" input, so no need for large, heavy and expensive contactor in many cases (up to 600A at the moment, limited only by current sensor).
Please note that, while the product was tested and showed good results, it is still quite fresh and there could be some small bugs and some features might need some tweaking. Especially programmable IOs on 150A model. But firmware upgrades will be provided regularly and many new features will be available in time, and for free.
smart and Tiny BMS solution
Visit my blog. Personal projects: Clean Peugeot conversion | Ultralight enduro
Any and all information, such as texts, specifications, drawings or other material that I post are to be used only as a reference for personal, non-commercial projects ONLY. Any republication for personal or commercial needs must be agreed on individually. Use of any information, that I post, for commercial purposes is strictly prohibited.
circuit   100 kW
Re: 5-16S Smart Tiny BMS preorder - 30/150/600A rated
Post by circuit » Feb 29 2016 4:03pm
I'm happy to see the inquiries rolling in.
18 pcs. left.
circuit   100 kW
Post by circuit » Mar 03 2016 7:46am
13 pcs left.
The BMS and accessories can be ordered directly on our website: https://www.energusps.com/shop
Expected dispatch date is 20th April.
madin88   100 MW
Post by madin88 » Mar 06 2016 10:58am
does the 150A version have the same size as the 30A BMS?
- 10kW belt drive with Neumotor 8057: viewtopic.php?f=30&t=91144&start=50#p1377787
- Fully road legal (L1E approval) e-bike based on Votec V-FR frame
/ MXUS 3T / 17" Mitas MC11 / Adaptto Max-E / 20s12p 25R
- KTM Hardtail Pedelec / eZee V2 6T / 27,5" / Kelly KBSX @ 1,5kW / Torque PAS / CA-V3 / 13s4p Sanyo GA in Shark case
circuit   100 kW
Post by circuit » Mar 06 2016 11:06am
Same board + aluminum cooling plate.
okashira   10 kW
Post by okashira » Mar 10 2016 11:48am
Ordered two 150A for testing + extras
401 euro total
"Peace out - I'm done."
-- Bernhard Riemann, 1859
edisonmotors.net
Tesla Model S 18650 cells - like new - and custom packs from Tesla cells for sale. Any shape Any power Any capacity.
PM me or search my threads.
circuit   100 kW
Post by circuit » Mar 10 2016 11:53am
Thanks John.
11 pcs. remaining. :)
okashira   10 kW
Post by okashira » Mar 11 2016 6:47pm
What kind of temperature sensor does it use? 10k ntc thermistoer?
Does it include the programming cable?
edisonmotors.net
fechter   100 GW
Post by fechter » Mar 11 2016 7:05pm
Can we see what the 150A and 600A parts look like?
I like the hall effect current sensors.
ecobully   1 mW
Post by ecobully » Mar 12 2016 12:33am
Hi circuit.
I submitted an order for 150A BMS + USB + BT. Could I also have the temp sensor added to my order when the product is ready to ship?
circuit   100 kW
Post by circuit » Mar 12 2016 2:27am
okashira wrote:What kind of temperature sensor does it use? 10k ntc thermistoer?
Yes, 10K NTC.
Programming cable is available separatelly.
fechter wrote:Can we see what the 150A and 600A parts look like?
600A (actually 750A) is achieved with the same 150A part, but with external current sensor and contactors.
ecobully wrote:Hi circuit.
Just updated your quotation. Should receive it by email.
macribs   1 GW
1 GW
Post by macribs » Mar 12 2016 9:39pm
Not seen this before, great work getting this ready. Tons of great features, I like a lot. I hope you sell out quickly. Reliable BMS is hard to get by I've been told.
Can you explain the 600A rated? It seems you have written specs only for 30A and 150A. Nothing for 600A.
Have you done this BMS design and prototyping all by yourself? Impressive work man.
Edited: Put the rest of my ranting in the other thread where it belongs.
okashira   10 kW
Post by okashira » Mar 12 2016 10:56pm
Yes, 10K NTC.
Please change my order to a single 150A unit, usb cable only.
Also, please advise alternative payment method. Not gonna spend $30 on a wire.
edisonmotors.net
circuit   100 kW
Post by circuit » Mar 13 2016 4:24am
okashira wrote:Please change my order to a single 150A unit, usb cable only.
Updated quotation sent.
circuit   100 kW
Post by circuit » Apr 20 2016 3:04am
Time is flying by. Today is the day, when BMS'es should have been shipped out.
As promised, we completed all testing on time. Started packing and are shipping these out today to those, who have already sent their payments.
There are few more BMS boards remaining, both 30A and 150A. Feel free to order them online: https://www.energusps.com/shop
Now we accept PayPal as well.
Merlin   1 MW
Post by Merlin » Apr 20 2016 7:32am
wonder why no one ask about "why only 16s"
maybe i try to ask: a 18/20s BMS would be a burner :D
anyway, ill take one for my wifes bike. :D
circuit   100 kW
Post by circuit » Apr 20 2016 7:41am
I knew there will be questions, and added a disclaimer on first post :) Short answer is: >16s not available for now.
Merlin   1 MW
Post by Merlin » Apr 20 2016 8:24am
read it....also your "building" topic.
beside that 48v is enough meaning, i was thinking last years, more voltage, less amps, less heat, less energy losses.
in the last 12month where the Big-Buddy-Steal Frames come popular (Qulbix,EEB,Stealth,Vector etc) they are anyway not legal
(so theres no need to be at a max of 60v)
...none of them are running 12s. sure. these are 8-10KW bikes.
If they have to go with 50v, they have to buy a better battery, bigger controller, bigger wires.......etc.....
iam not an electric engineer. iam just the guy who sells 4 times more 4 quality stuff and nice "helpfull gadgets" to see whats going on with my battery.
youre right. for the oem market you have no options above 60v.
But as you are long enough here, you know there are hundreds of "us" :D
Please build a >20cell BMS :D
How many Users do you need to buy a 20s BMS for a first batch / exploring market ;D
did i have to order on your website, or is a pm also ok?
circuit   100 kW
Post by circuit » Apr 20 2016 8:58am
Merlin wrote:If they have to go with 50v, they have to buy a better battery, bigger controller, bigger wires.......etc.....
Actually you would only need slightly thicker wires. Battery is the same (cells arranged differently), controller is the same (lower voltage mosfets hold more current). Also less issues picking DC/DC, charger etc.
The only thing why bike DIYers go for high voltage is slow motors. Somehow making it all non-standard, instead of rewinding or choosing other motor, seems easier way for many. But this has been discussed in depth already.
Merlin wrote:How many Users do you need to buy a 20s BMS for a first batch / exploring market ;D
1000 pcs could be a considerable starting point... Development of such product is quite expensive, too expensive to just explore the market, for small company anyway. We are keeping an eye on it, but there should be a real demand, that we don't expect from DIYers.
Merlin wrote:did i have to order on your website, or is a pm also ok?
Website would be much faster, as all order processing and accounting is done there anyway.
Merlin   1 MW
Post by Merlin » Apr 20 2016 9:25am
thanks.
- what "box contents" are coming with your 150A bms?
connectors for the bms?
- i want to use Lipos with it. they have JST-XH connectors. can i order some from you?
- did i have to cover the bms to prevent shortings on the board? how can i cover it when this bms have to placed in a hardcase bag with lipos together?
circuit   100 kW
Post by circuit » Apr 20 2016 9:44am
It comes with JST PH connectors and wires for cells.
These items can (and some should) be ordered separately: temperature sensors, bluetooth, current sensor, USB cable.
For JST XH you would need an adapter (probably could be found pre-made).
Bottom side of 150A model has an aluminum plate, while top side should be covered. Use whatever is convenient and prevents things from shorting. Note that aluminum plate should be mounted on metal surface to reach full current handling specification.
Merlin   1 MW
Post by Merlin » Apr 20 2016 9:51am
thanx again. i will solder some adapters.
- what maximum peak current did you suggest without air flowing and not mounted to metal?
- will heat shrink be ok to cover complete bms?
- i will go the bluetooth way. the app is in the playstore? did i had all features configurable in ths app?
circuit   100 kW
Post by circuit » Apr 20 2016 11:01am
I would say 40A average is a maximum for "150A" model without cooling. Heatshrink should be OK for that.
If you need more current, there are several options:
1. mount it on cool surface
2. add a heatsink
3. use external switch/contactor (it is supported)
App is under development still, but since the BMS supports protocol of Cycle Analyst v3, you can use one of several apps made by ES members:
1. https://endless-sphere.com/forums/viewt ... =2&t=45661
2. https://endless-sphere.com/forums/viewt ... 47#p895147
First one I have not tested
Second one works fine. But it is not public - you have to contact the author for invitation to download it from google play.
These apps are only for info display, as dashboard.
To configure and check all values, you will need a USB cable and do that on a Windows PC.
madin88   100 MW
Post by madin88 » Apr 20 2016 11:39am
circuit wrote:I would say 40A average is a maximum for "150A" model without cooling. Heatshrink should be OK for that.
2. add a heatsink
according to the pics, the BMS has the FET's on top side and the cooling plate is attached on bottom side (with a gap between).
i wonder if this is enough thermal flow?
about the FET's: what resistance value they have (or what type)?
3pcs on 30 and 100A board as well, right?
I'm interested because i'd like to use a programmable and reliable BMS for my 13s4p battery. the 30A version would be perfect.
circuit   100 kW
Post by circuit » Apr 20 2016 11:51am
Mosfet are these: PSMN3R3-80BS
http://www.nxp.com/documents/data_sheet ... 3-80BS.pdf
120A max, 3.5mΩ, 80V. Short peak up to 760A.
There are thermal vias under mosfet pads, and the gap between PCB and aluminum plate is filled with thick silicone pad.
Same mosfets and amount for 30A and 150A boards, only difference in current path is added cooling and current measurement (shunt vs. hall).
