Good 14s R/C charger?
Allex   1 GW
1 GW
Post by Allex » May 20 2016 6:21pm
Do we have any good out there? I need the functionality like in any ichargers out there but with the ability to charge up to 14s batteries.
What can you recommend?
Is Graupner Polaron Pro someting to look at or are they overpriced - I dont need touch screen.
I sometimes need to wake up half dead cells and right now, using Hyperion charger is very annoying, if a cell is below 2V it refuses to charge it so I need to switch over to Ni-Mh, charge it up to 2.5V and then switch back to li-ion program.
Do we have chargers that does not care about this?
Mikebergy   1 W
1 W
Re: Good 14s R/C charger?
Post by Mikebergy » May 20 2016 7:49pm
I've never seen a 14s- capable RC charger, but it looks like you found one from Graupner. Most would say they are overpriced, but Graupner and Hyperion are the Mercedes and Maybach of the RC world, whether you think they are worth the money is up to you.
Allex   1 GW
1 GW
Post by Allex » May 21 2016 11:48am
Yeah most of them are 6s or sometimes up to 8 or even 10s
But here are the ones that can do 14s - what I found:
-Graupner Polaron Pro
-for up to 14S
-Robbe Futaba E-1, or Eternity
-for up to 14S
-Schulze 14-801
-for up to 14S
TP1430C
-for up to 14S
migueralliart   10 kW
Post by migueralliart » May 27 2016 12:41pm
hyperion 1420i is the one I've been using for 4 years. No problems whatsoever.
I think the model has been discontinued thou.
dafex   1 mW
Post by dafex » May 27 2016 2:36pm
I use a Graupner ULTRA-DUOPLUS 45 it is also 14s charger.
Wheazel   10 kW
Post by Wheazel » May 27 2016 4:16pm
Allex wrote: I sometimes need to wake up half dead cells and right now, using Hyperion charger is very annoying, if a cell is below 2V it refuses to charge it so I need to switch over to Ni-Mh, charge it up to 2.5V and then switch back to li-ion program.
All "intelligent" chargers I have came across over the years, (altho only the hyperion capable of 14s), have been picky about low voltage charging.
Every time I either had to use nimh settings as you mentioned, or use a "dumb" lion charger.
Would a 1cell dumb charger be a hassle to use? Its pretty much "plug and play".
