12F Sine/Silent 36-100v/45A Controller iOS/Android,GPS-$139
madin88   100 MW
Re: 12F Sine/Silent 36-100v/45A Controller iOS/Android,GPS-$139
Post by madin88 » May 20 2018 1:41pm
Powervelocity.com wrote:
May 07 2018 2:11pm
PAS is available on most controllers - you can try to tap into the TA pin on the board.
I tested it early in the days and it worked.
Ok thanks i will hook up the sensor to GND, 5V and the TA input, but how can PAS be configured or programmed?
Alternatively, the latest/external version of BT module can control throttle and there are extra inputs available that can be used for PAS.
It would take a software update to make it work as the hardware is there already.
sounds great 8) looking forward what the future brings!
btw:
the new BT modules should arive soon, but i have no idea how to wire up the necessary program connector.
Are the wires included with the module, or a description how it needs to be soldered?
- 10kW belt drive with Neumotor 8057: viewtopic.php?f=30&t=91144&start=50#p1377787
- Fully road legal (L1E approval) e-bike based on Votec V-FR frame
/ MXUS 3T / 17" Mitas MC11 / Adaptto Max-E / 20s12p 25R
- KTM Hardtail Pedelec / eZee V2 6T / 27,5" / Kelly KBSX @ 1,5kW / Torque PAS / CA-V3 / 13s4p Sanyo GA in Shark case
Powervelocity.com   10 kW
Post by Powervelocity.com » May 20 2018 10:31pm
In regards to wiring, check this thread: viewtopic.php?f=31&t=89847
Scroll down a couple of screens.
You can set the top speed for PAS via programming. I'll add the setting in the software in a few days.
madin88 wrote:
May 20 2018 1:41pm
May 07 2018 2:11pm
btw:
madin88   100 MW
Post by madin88 » May 21 2018 4:04am
May 20 2018 10:31pm
Nice!
But should the sensor be connected to the Reserved 3-pin input of the new BT module than, or to the TA pin of the controller board?
And i could not find any info about how the missing programm connector needs to be wired.
thats what i mean:
i found a pic from the pinout of the programm connector of EB3xx controllers. Is it compatible?
EDIT: there is a white color wire instead of the black one which is GND so i think it's not compatible.
Any help would be highly appreciated.
Post by Powervelocity.com » May 22 2018 6:25pm
The reserved pins on the external module are not for pedal assist, even though they can be used for that in theory.
If you have a cadence sensor, I would just go ahead and connect it to TA pin. That's the fastest way to get it going. Connect and pedal - see how it responds. Settings for PAS are not yet exposed in the app, but I'll add those soon (this is the first time someone is asking for it). If I want to pedal with assist, I would spin the motor to the speed I need and set cruise. Then pedal as much as I like. Simple and I can easily turn off "PAS" when I don't want it to assist. There a number of situations where I don't want assist.
Regarding programming connector wiring, it's pretty simple. Wire them this way;
- Black (sometimes white) - Ground
- Red - 5v
- Blue (TX on the controller side) - match the pin location on the modules side per my pictures
- Yellow (RX on the controller side) - match the pin location on the modules side per my pictures
- Green (Reset on the controller side - NOT SDA) - match with green on my pictures
If you are talking about the loose white wire currently coming out of your controller, that's an input for motor temperature (so you can track the temperature on the phone).
madin88 wrote:
May 21 2018 4:04am
May 20 2018 10:31pm
Nice!
thats what i mean:
madin88   100 MW
Post by madin88 » May 23 2018 1:02am
May 22 2018 6:25pm
Thanks for answering Vadim. I will do so than.
It would be nice if you could add the PAS settings to the app. How can it be programmed otherwise (eg. the setting for max speed during assist)?
I think nobody is asking for PAS as long as they had no problems with the cops or law :)
Not that i personally had troubles, but in my country pedal assist is a must on ebikes (throttle only isn't allowed).
I was talking about the white wire on the middle pin of the program connector. Everything is clear now and i'm looking forward to do the module upgrade.
Aeron   100 mW
Post by Aeron » Jun 18 2018 8:45am
Jan 15 2018 3:52pm
30A is the max rating for 6F.
You mention 25A on the 6F thread, I must admit I'm a bit confused.
I'm hesitating between the 12F and the 6F, but BT module is 45$ option with 6F and 99$ with 12F, are they any different (or even swappable) ?
Post by Powervelocity.com » Jun 19 2018 6:18pm
The $45 is for the previous version of the module that could do only programming. It's not available anymore.
The price for the module is $99 regardless of the controller type. Modules can be used on any controllers I offer (swappable that is).
12F would give you more headroom if you ask me, so that's what I'd recommend.
Aeron wrote:
Jun 18 2018 8:45am
Jan 15 2018 3:52pm
Aeron   100 mW
Post by Aeron » Jun 20 2018 4:24am
Thanks for your answer. One last precision, regarding the 12F controller : you confirm it's dual mode (sensor/sensorless) ?
I've seen one of your post mentionning it (for Cyclone motors), but i'd better be sure.
Thanks !
Post by Powervelocity.com » Jun 20 2018 10:25am
There are sensored only and dual mode. This one is dual mode:
http://powervelocity.com/index.php?id_p ... er=product
Aeron wrote:
Jun 20 2018 4:24am
Thanks !
Owl   10 µW
10 µW
Post by Owl » Jul 29 2018 2:33am
Hello at the team from powervelocity ,
I drive a etricks from sev since 4 years. Now I need a new controller. I preferences the 12F Controller from powervelocity. The problem is that I can't order it from Germany.
Thank you very much.
Post by Powervelocity.com » Jul 30 2018 5:02pm
Please send inquiry to sales@powervelocity.com
Owl wrote:
Jul 29 2018 2:33am
Owl   10 µW
10 µW
Post by Owl » Aug 01 2018 2:07pm
The Mail delivery failed all the time. (sales@powervelocity.com)
Is there any other possibility?
Thanks
boytitan   100 W
Post by boytitan » Dec 28 2018 12:31pm
is that 125 for the controller and the cycle analyst ?
Btw is there a way to turn the battery amps down to 36 amps.
MJSfoto1956   100 W
Post by MJSfoto1956 » Jan 07 2019 8:38am
Apr 24 2017 1:08am
These wires (orange and red) are meant to be connected together. You just plug it into your key switch or any on/off switch. Shorting these wireless will turn the controller on.
Not sure "shorting" is the proper terminology. In fact, it might be downright confusing. What I "believe" you meant to say is:
Powervelocity.com wrote: These two wires (orange and red) are meant to be powered by the same switched circuit. You just connect the 2-pin connector to the output side of your key switch or any on/off switch. Powering both these two wires together will turn the controller on.
(please correct me if I am wrong!)
Post by Powervelocity.com » Jan 07 2019 5:01pm
I insist on shorting=connecting together :)
Red is simply an extension of the battery positive, so it should be treated as that.
Orange is the input for powering the controller step down supply that converts high battery voltage to 5v and 12-18v that powers low voltage circuits of the controller.
Connecting red to orange powers the controller MCU and other other low voltage components.
MJSfoto1956 wrote:
Jan 07 2019 8:38am
Apr 24 2017 1:08am
