"Edge" DD hubmotor, 1500W, 35mm, Al core
epower-1   100 mW
Re: "Edge" DD hubmotor, 1500W, 35mm, Al core
Post by epower-1 » Apr 02 2019 5:28pm
put me down for a 4t
how much are they
Thank you barent
teslanv   100 MW
Post by teslanv » Apr 04 2019 12:00pm
OK Guys. Here's a new thread for the group buy. Post there to place your orders.
https://endless-sphere.com/forums/viewt ... 31&t=99505
DD Hubs, Batteries, Controllers & Custom Ebikes.
http://westcoastelectrics.com
West Coast Electric Cycles
Bellevue, WA
USA
epower-1   100 mW
Post by epower-1 » Apr 04 2019 5:46pm
Nice job Berent putting this together for the builders who will remember
what you have done for us.
I know that most people don't want to build a wheel
and the smart thing to do is sell a turn key kit just bolt on and go,
but as a builder I want to pick out what rim and size that I want to have
and it is great to be able to get this motor naked so we can have our way with it
you will for sure go down in ebikedome forever as the man who made the little
motor even better for those of us who love and run the little motor
Peace and long live the 205 V2 35mm WCEC version at 95 amps
with out FF forever
calfeetwenty   10 W
Post by calfeetwenty » Apr 05 2019 8:33am
I will take 2 6t motors. Will pm in a day or two.
Electra 7D/BBSHD, 24 spd hybrid drive 52 volt....mods coming
Electra 7D Fat/Mxus 3000 Turbo, 72 volt.
Paratrooper Pro/BBS02/Alfine 8, 52 volt...back to regular bike
KMX Trike 1500 Edge 72 volt
Luna Cargo/ possible 2wd...on the back burner again
Vector Typhoon QS 205/50 6T half done
Easy Racer LWB recumbent, Bafang G310 stealth...soon
Hp Velotechnik scorpion fs 26 Mxus 30mm cassette motor...soon
calfeetwenty   10 W
Post by calfeetwenty » Apr 05 2019 11:40am
This is kind of an out of the way thread. You may want to put a link in the classified section. I would but I don't feel it is my place to do that.
harmonist   1 W
1 W
Post by harmonist » Jul 15 2019 3:36pm
Just wondering if anyone can help out with some spoke specs for this hub, I bought it already made up in a MTX33 rim, I've just noticed that I've broken a spoke so better order some new ones, I think the current spokes might be sapim 13G/14G, is 13G the spoke and 14G the nipple? anyone have some opinions on where to order maybe?
Cheers all
spinningmagnets   100 GW
Post by spinningmagnets » Jul 15 2019 5:06pm
The head of the spoke and the threaded part need to be as thick as possible. The shaft should be as thin as possible while still surviving the given loads. With spokes, the bigger number is thinner, and the smaller number is thicker. (ie, 14ga is common on bicycles, 10-ga is for light motorcycles)
When a spoke is "double butted" then the two ends are thicker but the shaft is thinner, and this is what I recommend. The length is the final number that needs to be determined, but...although the hub is the same, the rim may have several diameters for the same nominal size.
You NEED to take off one of the good spokes and measure it.
viewtopic.php?t=64324
harmonist   1 W
1 W
Post by harmonist » Jul 15 2019 6:32pm
Excellent thanks for the info, will whip one off tonight and get some measurements.
Cheers
teslanv   100 MW
Post by teslanv » Jul 16 2019 12:25pm
harmonist wrote:
Jul 15 2019 3:36pm
Cheers all
I use Sapim Strong 13g/14g single-butted spokes. Length is 162mm when this motor is laced in a Sun Ringle MTX33 - 26" wheel.
Bellevue, WA
USA
cheeko   100 W
Post by cheeko » Jul 26 2019 5:23am
Can anyone tell me have they had issues with the brake mount on these, i have a Mxus 3k and i think i might downgrade and that was one thing that annoyed hell out of me having to shimming mount
Also anyone running at 72v might run cooler lower amps needing to get to speed.
Cheers
20S7P Futr Beta 26" Mxus3k with the Unbelievable Nucular 12F
NASPC   1 µW
Post by NASPC » Sep 19 2019 8:01am
Hi everyone, I just got one from LAEbikes. Awaiting for it to arrive. Can anyone tell me in the mean time if this has a speed sensor built in. I need this info to order my Cycle Analyst.
Thanks everyone.
mrbill   10 kW
Post by mrbill » Sep 19 2019 10:09pm
NASPC wrote:
Sep 19 2019 8:01am
Thanks everyone.
If the motor you ordered has at least one working Hall sensor, then it has a "speed sensor" as far as the Cycle Analyst is concerned.
Bill Bushnell
http://mrbill.homeip.net/
Bike build thread can be seen here.
NASPC   1 µW
Post by NASPC » Jan 08 2020 8:52am
FYI, I did manage to figure out the wiring on the Motor from LAEbikes. 3 phase wires, 3 hall sensors wires, 1 +12v wire, 1 -12v, and 1 temp sensor wire.
