Electric Enduro Frame with QS 273 4000W-16KW
evolutiongts   10 kW
Post by evolutiongts » Sep 29 2016 2:16am
Up for sale a is a brand new Electric Enduro Frame with the dropouts modified for the QS 273 4000W Rear Hub Motor, technically I put 16Kw through this motor and it doesn't even get warm. This is a extremely powerful motor, it makes the QS 205 feel weak. I hit almost 70mph on 72V, it pulls harder than some sport bikes. It is insanely fast.
Asking $1350 for both the complete Electric Enduro Frame kit and the QS 273 4000W 18" Moto rim.
Both Brand new.
This is the race prototype, the parts I'm selling have never been mounted or ran.
Acceleration runs:
http://www.electricrt.com
Electric Race Technologies
Schwinn 405 2WD Track Bike 18KW
EDGE 1500W Hub / MXUS 3K Turbo
ASI BAC 2000 / BAC 4000 Bluetooth
viewtopic.php?f=6&t=93079
10Kw KMX death trike
MUXUS 3K Turbo
Sabvoton 72V150A
Moto Wheels all around
Front Suspension Kit
viewtopic.php?f=6&t=83423
Giant Trance 4 Full Suspension
Cyclone 3000W
74V 3000W
http://endless-sphere.com/forums/viewto ... =6&t=59005
Quokka   1 kW
Re: Enduro Frame with QS 273 4000W
Post by Quokka » Sep 29 2016 5:16am
Could you please post some close up pictures of the drop outs? Would be good to see how robust these are after the mods. Did you have to spread the drop outs at all? How difficult is it to mount a disk brake?
Qulbix Q76R+ QS205+MaxE
Dumsterdave   100 W
Post by Dumsterdave » Sep 29 2016 5:34am
Wow, that thing is huge!
litespeed   100 kW
Post by litespeed » Sep 29 2016 6:57am
As crazy powerful as my 205 at only 12.2KW I got from you is I can't even imagine what this would be like.
Next time I need a hub motor that will be the one I pick.
Tom
evolutiongts   10 kW
Post by evolutiongts » Sep 29 2016 8:48am
Quokka wrote:Could you please post some close up pictures of the drop outs? Would be good to see how robust these are after the mods. Did you have to spread the drop outs at all? How difficult is it to mount a disk brake?
Yes I can, I've ran this motor up to 16Kw on the same frame and it held up fine. The motor has 6 bolt disc pattern Mount, so it shouldn't be hard
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
evolutiongts   10 kW
Post by evolutiongts » Sep 29 2016 8:50am
litespeed wrote:As crazy powerful as my 205 at only 12.2KW I got from you is I can't even imagine what this would be like.
Tom
I did a head to head comparison with the QS273 vs QS205 and there is no comparison. The QS273 left the QS205 way behind even from a stand still. The QS273 just shot way ahead and the QS205 could not catch up.
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
evolutiongts   10 kW
Post by evolutiongts » Sep 30 2016 11:16am
Powervelocity.com wrote:How much is it heavier compared to QS 205?
QS205 vs QS273 is 30lbs vs 46lbs
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
evolutiongts   10 kW
Post by evolutiongts » Sep 30 2016 12:07pm
Powervelocity.com wrote:Damn, that's a 50% weight penalty.
But 70℅ more torque :P
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
evolutiongts   10 kW
Post by evolutiongts » Sep 30 2016 5:25pm
Powervelocity.com wrote:It looks like a bicycle disc brake will not work on this, as it's set for motorcycle type of a disk brake. So, on the Enduro frame which is designed for a bicycle brakes, is further modification needed to fit a motorcycle brake disc?
It has a 6 bolt pattern for a bicycle rotor, however you may need some modifications, I ran into a clearance issue.
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
ninepointeight   1 W
1 W
Re: Electric Enduro Frame with QS 273 4000W-16KW
Post by ninepointeight » Nov 16 2016 8:26pm
Sick looking motor, wondering how many phase amps you have put through it and what controller you run it with? If it gets up to 70mph on 72v that's nuts.
What AWG wires are the phase leads?
And what is the smallest moto wheel you could lace this into? Thanks.
steveo   1 MW
Post by steveo » Nov 17 2016 2:33pm
I'd love to line this up with my hub monster six phase dual adaptto bike :twisted:
i can't see the videos here at work, but i'm sure this is a fast setup, whats the kv on that motor?
-steveo
Repair Thread
http://endless-sphere.com/forums/viewto ... =3&t=27170
Hub Monster bike ~ 24s7p A123 15.4ah/18kv Six Phase Motor/Dual Max-E Adapttos/32kw~42.91Hp/Est 140LBS
X6 Kmx Trike ~ 24s4p 20ah/X6 MHM 602/Infinion EB324 IRFB 4110/20Kw~26.82Hp/Est 120LBS ~SOLD~
Lightening rods bike ~ 18s2p 10ah/1500w Inrunner/Infinion EB312 IRFB4110/2KW~2.68hp/Est 60LBS
EV Outboard ~ 12s8p 40ah/5KW GM Inrunner/Infinion EB324 IRFB 4110/18Hp Evinrude Drive/Est 100lbs
http://www.youtube.com/user/trdfreak03
Powervelocity.com   10 kW
Post by Powervelocity.com » Nov 17 2016 3:22pm
Yet to take it for a spin and see if it can haul azz. I will subject it to 10kw (100A at 100V) to start with.
Here are some pictures for comparison. I was able to put on a 3.5'' wide (realistically close to 4'') tire that makes it even more intimidating. Much larger teeth (protectors) on the tire compared to a 17'' 3'' Shinko. It is a very tight fit on an EBB, only like a couple of mm of clearance on each side but it works.
Some pics.
Quokka   1 kW
Post by Quokka » Nov 17 2016 9:42pm
Will the brakes mount up? Or is it too tight?
litespeed   100 kW
Post by litespeed » Nov 17 2016 10:04pm
I would love to do one but my 205 at 13 KW is so kick ass I really don't need it....I just want it.
I love the big tire!
Tom
Post by Powervelocity.com » Nov 18 2016 11:11pm
It is pretty tight, very close to the hub like a a couple of mm clearance but I guess it depends on the shape of the caliper. I also din't want to add a spacer that would move the disc mount screws too close to the phase/hall wires. So I ended up grinding the caliper a bit to add a couple of mm to the clearance.
Quokka wrote:Will the brakes mount up? Or is it too tight?
ninepointeight   1 W
1 W
Post by ninepointeight » Nov 20 2016 4:20pm
Is this the same QS 273 listed here?
https://endless-sphere.com/forums/viewt ... 4#p1235434
And are those specs applicable?
Also, what is the width of the rim that you are selling it with?
Post by Powervelocity.com » Nov 22 2016 2:12pm
Nope. That one is with 200mm dropouts and disc mount for scooters. Plus it has 50mm magnets which is what I was hoping to get with this motor but they don't make 273 with 50mm magnets, 150mm dropouts, and bicycle style disc mount.
ninepointeight wrote:Is this the same QS 273 listed here?
joe81   100 W
Post by joe81 » Jan 12 2018 9:23am
Hey there,
I'm just curious how the QS273, the Enduro Frame and the radial lacing is holding up in the long run at 16kW?
Some experience here? :mrgreen:
Mywpn   100 mW
Post by Mywpn » Apr 01 2018 5:11am
joe81 wrote:
Jan 12 2018 9:23am
Hey there,
I run the qs273 with radial spokes. And it has been flawless. I don’t exactly treat it nice either. I wouldn’t recommend off-road jumps with it due to the unsprung weight being so high. But acceleration from 40km/h onwards is mind boggling. At 80+ is still pulls as hard.
steven7601   10 W
Post by steven7601 » Apr 24 2018 2:12pm
Is this still for sale
