Nyx frame, 273mm*40m V3 hub, and 650A
liveforphysics   100 GW
Post by liveforphysics » Oct 19 2016 1:35am
I've been super busy, finally hired an expert bike builder friend to get my next mt bike build together. First step was swapping the Fox 40 lowers out for 27.5" tire compatible legs, a new stiffer Ti spring, and a new damping cartridge for heavier weight bikes.
Uses a bottom bracket Schulmpf drive to a gates belt drive for the human pedal input.
Motor is 16.8Kv, should be pretty peppy with 650A.
JumperJackFlash   100 W
Re: Nyx frame, 273mm*40m V3 hub, and 650A
Post by JumperJackFlash » Oct 19 2016 3:53am
That's an awesome build!!!
Did you have to drill the rim for the 273?
Post by liveforphysics » Oct 19 2016 4:36am
JumperJackFlash wrote:That's an awesome build!!!
Just a smidge to get a strong crossing spoke pattern to have a sound wheel.
Post by JumperJackFlash » Oct 19 2016 4:56am
Could you post the specs for the rim? 18"?
xadmx   1 kW
Post by xadmx » Oct 19 2016 5:10am
holy shit thats going to be badass when done.
litespeed   100 kW
Post by litespeed » Oct 19 2016 6:58am
Wow. That is super cool.
Tom
Ykick   100 GW
Post by Ykick » Oct 19 2016 7:40am
Right on Luke, go big or go home! Motor looks insane...
- Frank Sinatra
MrDude_1   100 kW
Post by MrDude_1 » Oct 19 2016 8:04am
What controller will you be using? sevcon?
Warning:This post is being read via light, a substance known to the state of California to cause cancer.
Quokka   1 kW
Post by Quokka » Oct 19 2016 8:09am
Jeesus..this is very much like what i am building. Cant wait to see how this combo go's
Can you show pics of the drop outs? Did you have to mill much out to go 12mm flats? Are you planning on modifying the closed torque plates that came with the 273 to fit the frame? And will the rear disk work?
Qulbix Q76R+ QS205+MaxE
Hyena   100 GW
Post by Hyena » Oct 19 2016 8:28am
Another silly powerful build, we expect no less from you sir! Truly, you are just building a reasonable mans electric mountain bike :mrgreen:
That rear shock is just a place holder, right ? I've seen air shocks blow out in short order with much lighter motors than that biggen.
Apparently those QS axles are made of alloy with a high cheese content and have been known to break over 200A. I've got the bigger 50mm version with cast rim for my moto conversion project (my poor mans zero, inspired by the ones you loaned me a few years back! ) and that was the warning given to me when I said I'd planned for feed it 600A.
www.HyenaElectricBikes.com
Doctorbass   100 GW
Post by Doctorbass » Oct 19 2016 9:17am
Awsome Luke!
To solve the problem Hyena mentionned about the axle,, I have built a torque arm to take the torque of the longer slit of the QS motor axel... This is the slit that is about 25mm long that is located directly on the larger diameter axel... And installed it between the NYX swing arm and the motor, and bolted the othe rend with a high grade M8 bolt about 4 inch away.
I have drilled and used a file to make it to get a nice 10mm x 26mm rectangle hole that fit just perfect without any play. I can use regen up to 8kW and push 15kW alternatively without anything becoming loose.
I think this is the way to go.
Doc
QS205 wider axel slit.jpg (172.72 KiB) Viewed 1750 times
CURRENT PROJECT: 2WD duo MXUS/Max-E ebike 32kW
http://endless-sphere.com/forums/viewto ... =3&t=65764
-Fastest speed record 117 km/h on flat
-Fastest 1/4 mile@ 114km/h on flat and 16.316 sec
113kmh Gianthttp://www.evalbum.com/3406
Mongoosehttp://www.evalbum.com/1947
YOUTUBE---https://m.youtube.com/user/Doctorbasss
I speak FRENCH and english
Doctorbass   100 GW
Post by Doctorbass » Oct 19 2016 9:20am
Luke i am also curious to know witch controller will you use? a size 6 ? a rinehart... dual MAX-E ? other? i know that Steveo is using dual MAX-E on his C-lute enertrack hub with succes. This is my plan for 2017.. single wheel drive but dual controller.. however.. QS205 + MAX -E unlocked and 22s is aleready a nice combinaison for wheelie... I guess you will limit phase current and put batt currnet at the max and keep high powerband for max top speed.. maybe a deathbike V2.... made with one of the best Ebike frame ever! :twisted:
Doc
Doctorbass   100 GW
Post by Doctorbass » Oct 19 2016 9:28am
Also.. I am very curious to see the V2 of this!:
Doc
Ypedal   100 GW
Post by Ypedal » Oct 19 2016 10:02am
Damn !!... envy ... :D
ES site status page:
madin88   100 MW
Post by madin88 » Oct 19 2016 2:30pm
a motor with bicycle in front :mrgreen:
What sort of controller can deliver such high amps while still having reasonable size? I'm curious about it.
- 10kW belt drive with Neumotor 8057: viewtopic.php?f=30&t=91144&start=50#p1377787
- Fully road legal (L1E approval) e-bike based on Votec V-FR frame
/ MXUS 3T / 17" Mitas MC11 / Adaptto Max-E / 20s12p 25R
- KTM Hardtail Pedelec / eZee V2 6T / 27,5" / Kelly KBSX @ 1,5kW / Torque PAS / CA-V3 / 13s4p Sanyo GA in Shark case
MrDude_1   100 kW
Post by MrDude_1 » Oct 19 2016 2:33pm
madin88 wrote:a motor with bicycle in front :mrgreen:
expensive ones. :lol:
or cheap ones, with tons of MOSFETs but they're the really scary ones, because they have no real throttle control. lol...
Post by liveforphysics » Oct 19 2016 3:07pm
NYX frame was super easy to mill for axle clearance, took 5min.
Thank you for the tips about the axle being a fine aged cheese based alloy. I will give it a shot with the torque plate setup and if it shreds itself I will machine a new axle from non-cheese metal.
The controller is something special, not Sevcon, and not capable of >80vdc packs, but very compact and rugged, FOC based and 650A phase RMS.
MrDude_1   100 kW
Post by MrDude_1 » Oct 19 2016 5:07pm
SO I take it that means you will be running 80v peak, and 650 phase amps... about 50kw bike? :lol: Sounds fun.
teslanv   100 MW
Post by teslanv » Oct 19 2016 5:17pm
Zero Battery?
DD Hubs, Batteries, Controllers & Custom Ebikes.
http://westcoastelectrics.com
West Coast Electric Cycles
Bellevue, WA
USA
MrDude_1   100 kW
Post by MrDude_1 » Oct 19 2016 5:49pm
teslanv wrote:Zero Battery?
unlikely. the Zero modules are 28s lipo. He just said 80v is the max.
John in CR   100 GW
Post by John in CR » Oct 19 2016 10:59pm
650A rms, as always, you're the man!
Post by liveforphysics » Oct 20 2016 1:49am
John in CR wrote:650A rms, as always, you're the man!
Thank you John! You're the man buddy! Without the monster hub experiences you shared with me I wouldn't be building this beast today. :-)
brumbrum   100 kW
Post by brumbrum » Oct 20 2016 1:53am
I found that the best setup for the rear shock was large/long bracket on the bottom and small at the top. This gave the shock a more horizontal angle and also made the head angle on the forks a little wider and not so steep. A 200mm fox dhx rc4 spring shock works for me with 600lb spring, me being about 175lb weight with about 27lb of lipo.
My NYX and cromotor build
viewtopic.php?f=6&t=74615
My LMX 161 dirt bike build
viewtopic.php?f=6&t=94074
Post by liveforphysics » Oct 20 2016 3:27am
I ran that same shock on my wife's Nyx build, and I agree it's pretty nice.
This air shock may blow quickly, which is fine I can put a coil shock on it. I kinda like the feel of air shocks.
ridethelightning   1 MW
Post by ridethelightning » Oct 20 2016 5:46am
sub'd
