Kickstand for EEB type bike.
kingjamez   100 W
Post by kingjamez » Apr 30 2017 10:03am
My EEB frame didn't come with a kickstand. I need one. I'd prefer one that can attach to the square tubing of the rear fork, but will settle for the standard one that screws into the bottom of the frame like standard kickstands. The EEB frame requires a much longer leg than normal kickstands, so I can't just buy a replacement bike model. Any ideas or tips on where to buy an EEB specific kickstand?
If something steel can be found, I can weld it to the frame if that expands my options.
-Jim
teslanv   100 MW
Re: Kickstand for EEB type bike.
Post by teslanv » Apr 30 2017 10:12am
Best thing I've found are these moped kick stands. You have to grind off the inner tabs, though.
https://www.treatland.tv/tomos-BLACK-si ... ck-013.htm
They tend to be a bit short if using 26" wheels. For 19" / 24" wheels, they work ok.
DD Hubs, Batteries, Controllers & Custom Ebikes.
http://westcoastelectrics.com
West Coast Electric Cycles
Bellevue, WA
USA
kingjamez   100 W
Post by kingjamez » Apr 30 2017 10:27am
Perfect! Thank you! Order placed.
-Jim
Newagebike   10 W
Post by Newagebike » Apr 30 2017 12:14pm
The EEB site sells them and on ebay there is a seller C&N ebike, just message them and they will sell you the one made for the EEB for $25
That's what they told me.
Sent from my SM-N900T using Tapatalk
madin88   1 GW
1 GW
Post by madin88 » Apr 30 2017 2:38pm
subd
- 10kW belt drive with Neumotor 8057: [url]viewtopic.php?
- KTM Hardtail Pedelec / eZee V2 6T / 27,5" / Kelly KBSX @ 1,5kW / Torque PAS / CA-V3 / 13s4p Sanyo GA in Shark case
kingjamez   100 W
Post by kingjamez » May 04 2017 10:28am
I got the Tomos Moped side kickstand in. It indeed fits on the EEB frame after grinding the welds that hold the tabs in place. It's a solid connection with just the "U" bolts.
However, it's way to short. My EEB with 17" moped rims leans over very steeply and isn't at all stable. I'll either weld on an extension (the leg is steel tubing) or I'll just buy the EEB kickstand instead.
-Jim
ecycler   10 kW
Post by ecycler » May 04 2017 5:23pm
People still use kickstands on bicycles?
Any grease is better than no grease.
The best exercises are the ones you enjoy doing.
I strongly prefer vehicles without doors.
flat tire   1 MW
Post by flat tire » May 04 2017 9:25pm
Real bikes don't have kickstands. You can always lean it against something.
kingjamez   100 W
Post by kingjamez » May 04 2017 11:27pm
ecycler wrote:People still use kickstands on bicycles?
What is the alternative?
I will be parking my bike in a parking spot while I'm charging it at work. It needs to stand up on it's own.
-Jim
kingjamez   100 W
Post by kingjamez » May 04 2017 11:29pm
flat tire wrote:Real bikes don't have kickstands. You can always lean it against something.
An EEB frame with 17" Moto wheels housing a QS205V3, Mobipus 72200, and 20Ah of 20S Lithium is about as far from a "real" bike as you can get and still have pedals.
This thing is a heavy beast.
-Jim
flat tire   1 MW
Post by flat tire » May 05 2017 12:38am
kingjamez wrote:Moto
Real motorcycles don't have kickstands either, see the thread I just made about my motocross bike! :D
ecycler   10 kW
Post by ecycler » May 05 2017 9:36am
If you are not momentarily propping it by the rear wheel against something or leaving it in your garage, then it should be locked via heavy cable to an object ideally strong enough to at least hold the bike up, LOL. It sounds like you are unaware how quickly a motorcycle will disappear into a van, let alone an 80-90lbs ebike that one person can pick up - especially in DC. It is a sitting duck on opening day of season parked on a kickstand in a lot.
Besides, if you are riding it hard like most of us, the kickstand will either make you crash when it unfolds and you lean it over or juts fall off at some point. Any offroad rider will tell you that. They only belong on wally world bicycles IMO.
slacker   10 kW
Post by slacker » May 05 2017 10:04am
harley davidsons have kickstands ?.
kingjamez   100 W
Post by kingjamez » May 05 2017 10:15am
ecycler wrote:If you are not momentarily propping it by the rear wheel against something or leaving it in your garage, then it should be locked via heavy cable to an object ideally strong enough to at least hold the bike up, LOL. It sounds like you are unaware how quickly a motorcycle will disappear into a van, let alone an 80-90lbs ebike that one person can pick up - especially in DC. It is a sitting duck on opening day of season parked on a kickstand in a lot.
Unfortunately, none of those are options for me. When charging, I park in a garage that is 100% video monitored and I have to be in a standard car parking spot. Non-charging parking is in a private garage so I'm not terribly concerned about theft. If I'm in actual "public" it'll of course be chained up.
-Jim
ecycler   10 kW
Post by ecycler » May 05 2017 1:44pm
gotcha. Everyone's situation is a little different. If you take it on a ride for heavy offroad use, my recommendation would be remove the kickstand or ziptie it in place!
