Zero Motorcycles BATTERY for your E-projects!!
Got something to sell? Have extra parts that need a good home? Have something that others would need to complete their kits? Post it up here and see if anyone else is searching for what you are selling.
Doctorbass   100 GW
Post by Doctorbass » May 01 2017 9:56am
Hello guys i recently bought a stock of used Zero battery ( ZF2.8 and ZF11.4 !!)
I am ready to sell some of these that i will not use
This is incredible RARE offer of the most performant QUALITY battery for ebike and e-motorcycles!! :twisted:
My actyal NYX 16kW operate with 22s of the cells of these battery
I will add more info and pictures soon. no worrie!
Well i am figuring 250$ per kWh
1000$ for each Zf2.8 and 4000$( worth 3000$usd) for the ZF11.4 (worth 12 000 usd)
I will include performance check.
Anyone interested PM me!
These battery are the most compact battery and are made of HIGH QUALITY 25Ah NMC FARASIS poutch in very STRONG aluminum case!
Spec of the cells iside these modules here: https://www.cdiweb.com/datasheets/ctc-b ... 5Ah-v5.pdf
each modules are 28s 102V nominal 116V full but you can reconfigured the way you want.
Farasis cells specs:
5C continous 7C peak
capable of 400A burst at 100% SOC
I have 3x ZF2.8
- (2.5kWh usable)
-28s1p
ULTRACOMPACT
http://cyclepartstriumph.com/index.php? ... ts_id=1028
http://www.mbike.com/news/wp-content/up ... 00x357.jpg
https://evmc2.files.wordpress.com/2013/ ... _press.jpg
and
1x ZF11.4 ( the full pack of the Zero 2013 S and DS) !
-(10.0kWh usable)
-4 modules 28s1p in parallel
- 500A contactor
-the 4p cells are capable 500A continuous 700A burst 1600A at 100%soc
-ULTRACOMPACT
INSIDE Image
I will add info very soon!
Doc
CURRENT PROJECT: 2WD duo MXUS/Max-E ebike 32kW
http://endless-sphere.com/forums/viewto ... =3&t=65764
-Fastest speed record 117 km/h on flat
-Fastest 1/4 mile@ 114km/h on flat and 16.316 sec
113kmh Gianthttp://www.evalbum.com/3406
Mongoosehttp://www.evalbum.com/1947
YOUTUBE---https://m.youtube.com/user/Doctorbasss
I speak FRENCH and english
kneedeep   100 W
Re: Zero Motorcycles BATTERY!!
Post by kneedeep » May 01 2017 11:19am
I am in Ontario very interested in a price.
Chinese Ebay build in progress https://endless-sphere.com/forums/viewt ... 12&t=86149 , been through half a dozen scooter ebikes..No More of those.
I like to build it better than I can buy it. I like to think outside the box...Come to think of it where is that box?
Doctorbass   100 GW
Post by Doctorbass » May 01 2017 8:27pm
It is also possible to split the ZF2.8 battery like i did for the NYX project:
https://endless-sphere.com/forums/viewt ... =nyx+built
Kin   10 kW
Re: Zero Motorcycles BATTERY for your E-projects!!
Post by Kin » May 01 2017 10:21pm
Kind of curious to hear updates on this thread ^_^. Nice batteries.
Any idea if any packs would be remotely suitable for putting in series? concerned about used packs not really being well matched, but maybe you will respond that they are decently matched.
New to endless-sphere? Notice a lot of signatures recommending Ebikes.ca? That's because it's the best place for a quality and manageable, (but still 'real'), first build. Justin is a solid supporter of electric bike development, and a good source of equipment.
Doctorbass   100 GW
Post by Doctorbass » May 01 2017 11:05pm
Kin wrote:Kind of curious to hear updates on this thread ^_^. Nice batteries.
Some of these packs had deffective BMS. I will connect a Zero BMS to the one that dont have any and see the state of each cells. from what i know these have excellent cells usually very well matched
Not to confuse with cheap chineese cells...
Arlo already use some of these in serie for his Drag race CRX :wink:
Doc
Kin   10 kW
Post by Kin » May 02 2017 2:46pm
I'm sorry, I was not very clear.
I mean, maybe pack A is made of 28 cells, C0,C1,C2...C27. Pack B is made of 28 cells, D0,D1,...D27.
I understand matching between [C0...C27] is good, but what do you think about a pack of [C0...C27,D0...D27]?
In other words, putting two of these battery banks in series? I understand they're more likely to go out of match , but is it remotely rational? I assume BMS would need to be removed.
Doctorbass   100 GW
Post by Doctorbass » May 02 2017 4:05pm
Kin wrote:I'm sorry, I was not very clear.
Well we need to be sure that paralle is Paralle and serie is Serie.. sorry to ask but there is alot of people here still confusing serie and parallel...
PARALLEL: paralel positive and parallel negative
SERIE: first positive connected to second negative, ---(-+)(-+)(-+)+++
These Zero modules ( ZF2.8 of the Zero XU and FX are correct to be paralleled , this is what happen in the big monolith of the S, SR, DSR etc
In serie, yes, module 1 should be same capacity and similar RI as module 2 i serie with it etc...
Doc
binlagin   100 W
Post by binlagin » May 02 2017 5:59pm
Also very interested in this! Please add me on FB to discuss further if you'd like http://www.facebook.com/binlagin.
I'm in Ottawa and can meetup with you Dr.Bass, I've purchased your dropouts for other builds!
I need a battery for my current project!
Greyborg Motor, 18-FET Lyen Controller
Turnigy 20C @ 30S x 2P
Giant Team DH Bike, Kiwi Dropout adapters
100km/h+
robby   10 mW
Post by robby » Jun 01 2018 8:14pm
Do you still have the ZF 2.8 packs for sale? Both of mine are shot. I was planning to rebuild them, but I just opened one up and the cells are bloated to the point that the casing is collapsing on itself when I remove a few screws. I'm looking to either replace the packs or build something compatible from scratch.
michaelebradley   1 µW
Post by michaelebradley » Aug 05 2018 9:25am
looking for cells to finish rebuilding a 2012 Zero Model X battery pack. The cells are EIG 20 Ah I believe. Anybody know where they can be found?
