HUGE EMPTY Downtube/Craddle Battery Box with Keylock
Matador   100 kW
Post by Matador » May 20 2017 8:32pm
I've spent quite some time on researching this...
Maybe some of you ES members can point me in the right direction.
The main thing that I notice is that it's REALLY NOT EASY to find an EMPTY Downtube Craddle Battery Case sold without friggin cells inside of it ... Easy to buy the case already filled with "some 18650" cells and BMS inside.
I dont get what's the deal with small boxes ? Can't they make bigger downtube craddle box ? I want to cram 140 cells, not 50 ! Make battery cases removable from sideway latching action and it's still easy to remove a much bigger pack from it's craddle.
They're all 4P 13S tiny boxes ... but if you glue cells you can cram maybe 4P 14S.... There is maybe one model allowing for 5P... Is that all you've got China ???
I've got many good 18650 cells... Got them for about one fitht of the price I would pay them brand new, taxed and delivered to my door taxed. Mine are not new, but all under 100 cycle usage. They're NMC 2100 mAh and capable of 30A continous-100A burst/cell.
I tested each one of them at 1A discharge (each individual cell) and they are on average 2173 mAh (lowest 1983 mAh, highest 2309 mAh from 4.20 to 2.70 V... probably 95% of them being between 2100 and 2200), are between 1.7 anf 4.0 years old (from date code when manufactured at Koriyama Japan (70km from Fukushima nuclear plant) to this very day ... Dont worry, I checked the lot with my Geiger counter... not radioactive at 0.14 uSv/h ; just like the normal background cosmic radiation level in my house). I discharged them back to 3.65V (45-50% SOC) for storage as I'm eventually planning to assembe them into packs this early June... I measured one of them cell at 22 milliOhms DC (slope of graph with 5 different load resistors), while they're rated at 12 milliOhm AC impedance at 1 kHz. Pretty awsome for a 1.9 yr old (but almost virgin) cell (supposed to be 23 mOhm DC brand new !).
I got 286 of them cells... In case you want my data on these cells :
Makita VTC4 cells from doctorbass.xlsx
(512.04 KiB) Downloaded 49 times
Back on topic now...
I've seen 4 types of battery box that I could fill up with my 18650 cells.
I want the box to look like an OEM battery from the outside... No cardboard or wood. Factory look is what i'm looking for.
It's going to be heavy (45 grams per cell) so it HAS TO HAVE a STURDY CRADLE to hold the pack. Ideally, the pack would be lockable, have some cute little led to display charge percentage
The thing is... I cannot go less than 14S5P as a very bare minimum (70cells)... Remember, my cells are just 2.1 Ah. And I like that because they are 15C cells so they will live a long life at less than 3C (ideally, I'd want to be at 1.5-2C... My BBSHD's controller is still at 30A for now... although I got myselfs some current sensing resistor to do the controller shunt mod in the future... to upgrade to 40 or 60A!).
QUESTION : Anybody knows where I can find such a craddle factory looking sturdy Downtube battery case to fit 140 cells ideally (14S10P - 52V, 20Ah, max 300A). I'd still be very happy to cram 112 cells in a case (14S8P - 16Ah, max 240A). For me a small but still intersting pack would be capable of holding 84 cells (14S6P - 12Ah, max 180A)... With my calculations and my riding style a 6P pack would give me 11.7 real Ah and I would not do more than 20-30 km on it (will only charge to 85% SOC and never discharge under 20% SOC)...
A 4P pack would be too small for me.
All I could find was these 4 boxes :
Tiger Shark.jpg (238.87 KiB) Viewed 4493 times
Carbon Shark.jpg (167.61 KiB) Viewed 4493 times
Seriously, isn't there anything bigger than that for a downtube craddle ???
Ideas please ! Anything bigger ? I live in cold Canada (sometimes -40°Celcious in winter), and want to be able to remove my battery to charge it and not let if freeze.
Could not find a thread on different MODELS of Downtube battey boxes available on the market to DIY, so I decided to create this thread.
Seriously, I'd really love to get an 14S8P downtube box...
Matador
Specification_US18650VTC4.pdf
(875.07 KiB) Downloaded 65 times
Matador   100 kW
Re: HUGE EMPTY Downtube/Craddle Battery Box with Keylock
Post by Matador » May 20 2017 8:50pm
Forgot to say, I'm also planning to have my BMS inside the box. This Bestech one to be exact (80A continous, 200A maximum) : https://endless-sphere.com/forums/viewt ... s#p1284752.
My bike has lots of triangle space...
It's a "Nakamura"19inch hybrid bike an the space inside triangle is : Vertical tube : 13.75 inch, downtube 25 inch, horizontal upper tube 21 inch.
I really want to avoid a "flexible", no-rigid triangle bag. I'd wont something rigid, removable and somehow water-/weathe-resistant.
Matador
Matador   100 kW
Post by Matador » May 20 2017 11:50pm
Reetetion : http://reention.com/product/1
Make battery cases (good reference for serial numbers).
I'm thinking I shoud buy two or even 3 cases of the TIGERSHARKS DS-6C Black. Do a dremel job an than a fiberglass (no experience on the fiberglass part) and than a bondo job + paint to expand the pack to hol 14S8P or even 14S10P.
The cradle looks sturdy.
Matador   100 kW
Post by Matador » May 21 2017 12:01am
kriskros   10 kW
Post by kriskros » May 21 2017 12:53am
split the pack in two and use saddle bags on the rear carrier... look for horse saddle bagsas they aresmaller than motorcycle bags... horse abouy 10x11x 4...motorcycle..about 11x 12 x6.. I am using 14sx20p in a split pack..
Matador   100 kW
Post by Matador » May 21 2017 6:50am
kriskros wrote:split the pack in two and use saddle bags on the rear carrier... look for horse saddle bagsas they aresmaller than motorcycle bags... horse abouy 10x11x 4...motorcycle..about 11x 12 x6.. I am using 14sx20p in a split pack..
I thought about it. My concern with saddlebags on the rear is about the weight on the back causing an unbalanced. I chose the BBSHD motor kit because it keeps center of gravity low and centered thus handls like a champ.
Maybe I can cut the to part of the Tiger Shark pack and make it so that it can store twice as much cells.... Fiberglass, bondo, paint.
Why don't the make readily available bigger packs ?
Matador   100 kW
Post by Matador » May 21 2017 7:46am
Anybody sells a rigid triangular battery boxes like the sondors has ?
Googled everywhere, I can't believe this doesn't exist
rojitor   100 kW
Post by rojitor » May 21 2017 7:49am
Have you considered frog? Room for 100+ cells
http://s.aliexpress.com/VbIf2iqE
Matador   100 kW
Post by Matador » May 21 2017 7:52am
rojitor wrote:Have you considered frog? Room for 100+ cells
36 V caja de batería de 48 V batería ... ndroid)
Thanks for the reply.
I've seen it on alibaba.
Good cell number... but i'm really ainming to put my battery inside the trangular space to keep the bike with a low and very centered center of gravity.
I'll still check out thr frog in bigger details.
Matador   100 kW
Post by Matador » May 21 2017 8:05am
Ideally, I'd want something like this if it existed :
ae6a3ae519d7cb40c129ebb3e3a73119 - Copie.jpg (74.54 KiB) Viewed 4411 times
Right now this is the biggest I can find on the market (room for just 65 cells).
The battery has to be removable.
Matador   100 kW
Post by Matador » May 21 2017 8:13am
Some cases are designed to be removed sideways, so height should not be a concern so much.
Like this one :
Right not i'm heasitating.
Either I buy a cas and cut it open to do fiberglass, bondo paint and expand it's size (Crazy labor intensive)
Either I fing a permade triangular box. I can't even find a place to buy a sondors triangle box to begin with.
Matador   100 kW
Post by Matador » May 21 2017 8:20am
These are cool, but 250+ $$$
https://gearjunkie.com/ak-codepak-bike-bag
Called the Codepack (Kickstarter.....)
Video of the Codpack:
https://www.kickstarter.com/projects/20 ... -solutions
Matador   100 kW
Post by Matador » May 21 2017 8:36am
I think nobody has tough of commercializing what I'm really looking for.
I'd want a rigid triangular frame box to cram in lots of cells, a bms and a battery indicator.
The triangular box I imagine would be easily removed by strong metallic latching mechanism.
There would be a cradle made of metal to attach it in a very solid way.... That cradle could even span on 2 sides of the triangle frame for more solid grip (attached by 4 screws to the frame).
Matador   100 kW
Post by Matador » May 22 2017 1:38am
Ashland ebikes triangle case (on Pinterest).
Dunno where to buy it but looks good.
Matador   100 kW
Post by Matador » May 26 2017 4:12pm
Anybody knows a source for EMPTY Killer Whale casing+cradle ?
cassschr1   10 kW
Post by cassschr1 » May 26 2017 4:55pm
that ashland was for tidal force bikes when they went under.
fechter   100 GW
Post by fechter » May 26 2017 5:10pm
What about two separate cases, one on the downtube and one on the top tube? Not ideal, but might be able to use off the shelf parts.
Matador   100 kW
Post by Matador » May 27 2017 12:40am
fechter wrote:What about two separate cases, one on the downtube and one on the top tube? Not ideal, but might be able to use off the shelf parts.
Finally bought two of these empty kits (should fit 14S5P 70 cells if I get rid of the holders...)
56$ per kit (case, cradle, connector, battery meter).
Got 2 + 16 $ DHL shipping.
Expecting a little DHL surprise fee at my door but seller agreed to declare each pack at 30 USD rather than 56, as some of the cases he sell really retail for 32 $ on his website...
A 34 CAD surprise to be exact :
DHL Custom fee calculator (matador).xlsx
(11.58 KiB) Downloaded 58 times
So each battery case kit comes down at 105 CAD (USD) after taxes, customs, and shipping...
Bit pricey, but I was not satisfied with the idea of a 4P or even 3P pack. Even with 30amp rated cells... I went them to live a long life.
Who know, I might even choose to mod one of the battery case in the future... to increase capacity (as long a the cradle can hold the pack unde high G-force in x, y and z-axis).
A little fiberglass there, a little bondo here, a little sanding there, a touch of black paint here. :wink:
There is that one seller on aliexpress who actually has a great choices between around 20 to 30 different models of empty battery cases (lot of downtube models too). He does not sell ready made packs with 18650 cells inside, but he has 100% good feedbacks (n = 267).
There's even an aluminium one that can host 120 cells or so. and it slide onto a metal plate "cradle", but the box is squary, not for downtube postion.
Matador   100 kW
Post by Matador » May 27 2017 1:13am
Quick view on different battery casings :
Toorbough ULL-Zeveigh   100 MW
Post by Toorbough ULL-Zeveigh » May 27 2017 1:27pm
https://endless-sphere.com/forums/viewt ... 5&#p603605
Oatnet onn Friday June 29, 2012 wrote:Jerry, at Ashland electric bikes, had completed a model, and was looking to do a production run. Send him a pm I'm sure he'd be glad to hear from you.
wavetrack closed its doors October 2006, soo yeah, when.
sure, just like today is 'when'.
pm these two, see if he's even still into it.
may need to gather together a group buy for him to get it up one more time.
https://endless-sphere.com/forums/membe ... le&u=18440
https://endless-sphere.com/forums/membe ... file&u=533
Matador   100 kW
Post by Matador » May 28 2017 12:46pm
This one empty alloy case is pretty cool also. Quite gigantic...
I think it can contain up to 96 cells, judging by the inner dimension ! But it's for a rear rack, so that can be a pitfall for the center of gravity :
I think this is about to become the "Where to find empty battery case, and what are the options for a huge batteruy case" thread.
999zip999   100 GW
Post by 999zip999 » May 28 2017 3:31pm
Diy. Just make one. You have the skills. You said 140 cells custom. That means you.
Matador   100 kW
Post by Matador » May 28 2017 4:25pm
999zip999 wrote:Diy. Just make one. You have the skills. You said 140 cells custom. That means you.
I'd love to. Just too busy with work these days...
Matador   100 kW
Huge EMPTY DOWNTUBE / Craddle BATTERY BOX with Keylock
Post by Matador » Jun 24 2017 11:52am
Okay, so I recieved 2 x Tiger shark empty battery cases. They are meant to fit 60 (ex: 10S6P) to 65 cells (ex: 13S5P) when you use the cell holders.
All in all. I'm happy. I ended up having to pay only 22 Canadian dollars at the door for custom duties and tax by UPS (declared value was 30 USD rather tha 56 USD per kit).
So with shipping and duties. Each case (includes craddle, key lock, 48V voltage display,ON/OFF switch and USB phone charging port) ended up costing me 99$ CAD every fee included (72 USD) per kit.
I have a 14S Li-ion charger (58.8V @ 5A) I got from Paul at EM3EV.
I want to do 14S5P (70cells). The only way I can see this to fit is to just hot glue the cells togeoether (BMS fits too, but very crammed).
This is very crammed but it should fit. I made a simulation with laptop cells. You can see that I have to put 2 cells in a special position (the voltage indicator bumps on the alien placed cells otherwise).
I managed to put the BMS on the upper left part. I's really crammed.
What do you think. I'm kind stuck doing it 14S... Got 14S BMS and 14S charger....
BTW picture is just a Mock up... No way I'm filling it with cheapo laptop cells. I'll fill it up with some Sony VTC4 cells with some already soldered nickel plated copper tags you just saw above : https://endless-sphere.com/forums/viewt ... 4#p1289715
Matador
Matador   100 kW
Post by Matador » Jun 24 2017 1:44pm
Also I was thinking of using the "slide and solder" 9mmx1.7 mm Copper bussbar technique for wiring P-groups togoether. But I'm now wondering if it's going to fin inside...
Like this https://endless-sphere.com/forums/viewt ... s#p1273439
Copperbussbar are 100A ampacity. Would it fit....
I also had tinned copper braid (a 50 feet roll that's supposedly 30A ampacity), I could alos solder that instead : this one to be exact : http://www.ebay.com/itm/50-Ft-Flat-Brai ... SwU-pXqIpM
Or I could go buy solid copper wire.
I also bought nickelstrips.... but I was a noob at that time, and it ended up being nickel plated steel... doh! This to be exact : http://www.ebay.com/itm/0-15mm-8mm-10me ... V4&vxp=mtr
So what's your vote ?
1) Copper bussbars (100A)
2) Copper braid, tin plated (30A)
3) Solid copper wire
4) Steel strips plated with nickel (maybe good for 2.5A)
Any input appreciated. I'm aiming at building a good quality pack, with quality cells.
Matador
