Electric Hydrofoil/E-Foil
Boats, Jet Skis, Kayaks etc., including hovercrafts
s9tim   10 µW
10 µW
Re: Electric Hydrofoil/E-Foil
Post by s9tim » Aug 17 2017 7:42am
More pictures
Gege2000   10 mW
Post by Gege2000 » Aug 17 2017 11:15am
s9tim wrote:More pictures
Awesome job :shock: :!:
Jezza   10 W
Post by Jezza » Aug 17 2017 11:30am
What material did you print with?
What infill did you use?
How did you seal the 3D printed material?
s9tim   10 µW
10 µW
Post by s9tim » Aug 17 2017 12:40pm
Printed with pla, infill varied slightly but most parts were printed at 70 percent. Sealed with epoxy resin. O rings and marine 5200 used between sections.
Gege2000   10 mW
Post by Gege2000 » Aug 17 2017 2:34pm
Hi,
I ordered the SSS56104/500kV brushless motor on ebay.
Do you have links for the planetary gearbox between 1:5 and 1:8 at a reasonable price?
Thank for you help
Gege
kiter_UK   10 mW
Post by kiter_UK » Aug 17 2017 2:57pm
One used 8:1 still going on eBay
http://www.ebay.de/itm/332343178078
See prior thread for cons (price is a pro)
dirkdiggler   10 kW
Post by dirkdiggler » Aug 17 2017 4:13pm
It's great to finally see some success on all this. The e-surfboard thread is like 6 years old now and only a handful have gotten a working board. Now there are like 7-8 efoils that are rideable. Hopefully this will bring the costs down for Lift and others, so that we don't have to DIY it. E-skateboards at were around $1500 to begin with and after everyone started making there own the costs have dropped a ton. Maybe Lift will have to rethink charging $12k for a product that people can make at home!
Anyhow, congrats to everyone that has a working board and to all the people that have helped along the way. ES is amazing in that way! I hope to be riding my own soon, but winter is closer than I'd like to admit.
Hiorth   1 W
1 W
Post by Hiorth » Aug 17 2017 5:08pm
beonwater wrote:
Hiorth wrote:I angled the rear wing of the foil, and the foil mast to make the foile fusalage more parallel to the board, It made huuge difference in riding experience! much easier now :)
Also did a thrust test, with no rider:
https://www.facebook.com/nikolai.hiorth ... 344945144/
Its amazing how much power you get out of these small motors/propellers!
It seems logical as you have the thrust so far down. And depending on the boardsize and distribution of the volume you may need to be to far back when start riding and when the foil lifts you you need to be further forward to keep it down.
Have you measured how much current you use when starting and foiling?
I you got my "MYLB-FT08 RC 150A High Precision Watt Meter and Power Analyzer" that I´m thinking of using to see peak current and power. But further on I´m thinking of logging current, voltage, speed (GPS-module or syncing with a smartphone) using an ESP32. I think these figures would be valuable for optimizing prop and wings.
Have you published your 3d models yet?
Havent measured amps. It works nicely, so i dont mind;) will maby do it later when optimizing propeller duct etc. Will try do some cfd calculations also, at least calculations!
Working on a instructables.com article now. With all 3d models part list and so on. Will publish in the weekend hopefully.
Efoil boards are many times more efficient than jet surfboard, so they are in our mind 100 times more interesting (and fun, as you can fly). I guess that combined with the 12000$ price tag is the reason for it being diy built.
Just bought 4x 10000mah 6s lipos. Will also build another pack of 3 e-bike batteries. Will make a compartment in the board that suits both packs, so we get loads of foiling time!!!
The foil skills are improving:
https://www.instagram.com/p/BX6QyXOnhP_/
beonwater   1 mW
Post by beonwater » Aug 17 2017 6:14pm
s9tim wrote:Printed with pla, infill varied slightly but most parts were printed at 70 percent. Sealed with epoxy resin. O rings and marine 5200 used between sections.
Nice job! Seems like you also nailed it. Good looking foil.
When you say "Sealed with epoxy" does that mean that you can not open it without a destroying it?
What type of board did you use? size and volume
s9tim   10 µW
10 µW
Post by s9tim » Aug 17 2017 7:07pm
The epoxy was used as a thin barrier coat to seal the pla parts prior to assembly. However the end pieces were epoxied into the aluminum tubing so it would not be easy to disassemble. The rear cone with the shaft seal is screwed to the main body with an o ring sealing this area. I can access the rear of the gear head area and drive shaft coupler to change the driveshaft.
The board is a 5'8" long x 22" wide x 2 3/4" thick. Not sure of the exact volume. It will not allow you to stand on it until you start moving forward. The next step is to build a larger custom board with all electronics concealed inside.
Jimmy22   100 µW
100 µW
Post by Jimmy22 » Aug 17 2017 7:24pm
2017-07-16 10.34.14.jpg (125.16 KiB) Viewed 1723 times
Hi All,
Great work on getting your own Efoils up and running, we are working on one also and the success here is heartening.
In the mean time we have been tow foiling for a few months and testing prototype production foils and making our own entire rigs .
I would like to share a few thoughts with you in the hope it helps someone progress faster.
We put a load cell on our ski rope and towed our foil boards slowly on to the plane and then popped to foil , directly behind the boat, the current sup foil popped at around 9kmph and loaded to 30kg force max ,then down as low as 7kg force when popped. The kite foil loaded 35kg Max, (partly due to a 50cm wide 185cm board vs 70cm wide) then fell to 7-10kg force popping at 15kmph .
I note when most people are learning in the videos they have the nose really, really high which makes everything highly unstable. I have noted that when every rider of our foils and boards gives the thumbs up to indicate they are really feeling it and comfortable with the ride the boards rear section, which in our case has no rocker and exactly parallel to the fuselage, is parallel to the horizon line, e.g. the fuselage is parallel to the water. When going too fast the board points downward like Americas cup boats on the down wind leg, this is not to say cavitating, just reaching the foils limit and near cavitation. Always best to fly flat folks, and in ten or so different boards and foil setups, it is always the nicest possible way to go.
Also If your foil ever gets 1x the foil chord from the waters surface the drag increases a LOT so that may help you sense you are about to breach the foil, lol.
Further it is not very nice to have anything but zero degrees of front (lifting) foil AOA as when the speed increases with front AOA the front foot pressure increases too much. The rear foil should be used to determine how fast your foil pops, leave the front foil at zero (exception is a flat bottomed foil which will be good with 0.5deg upward AOA) . Rear foil AOA is anything from 1.5deg to 5 deg but i run 2.5deg personally. A Robart meter is a handy tool to set AOA , but you can make one easily and add a digital level for a fraction of the cost. If you dont do as above your fuselage will be causing unwanted drag and you can feel the difference pretty easily, plus you push "dirty" water onto your rear foil and it is less stable.
If you kneel on the board to begin with it makes it way more stable, just put your knees where your front foot would be and give it a go for the first try, you can then learn to fly and feel the foil without the need to balance yourself as well, i would think it is 3x easier to control the flight kneeling. As for foot placement, begin with rear foot directly on top of the mast and front foot 550-600mm forward of that. Rear foot ever so slightly on the toe side of the centre and front foot slightly to the heel side , this gives better control of roll and makes it more stable , Dont run foot straps at the start ! Mark the deck with tape or something , your ankles will thank me .
On take off get the board planing and get the foil lifting, dont pop too early as you will pop with the nose high (stalling) instead of the foil more horizontal which is much easier to ride and the props ability to make the nose lift is partly cancelled out while the board is still on the water. Lean forward to hold the nose down as long as you can then shift your head back or your hips back about 25mm and it will lift, if it doesn't , your front part of your body is too far forwards.
When you are an expert find your own happy place but this little lot of info will get you going much faster. Also buy or make one of these balance boards with the half sphere lower , it halves the practice http://www.fitter1.com/Professional-Bal ... 0.htmltime you need on the water :) Start with it on carpet then put a hard wood or tile under it for a greater skill level.
toto44   100 mW
Post by toto44 » Aug 18 2017 3:17am
As I am still in work of setting up my new workshop, my progress with the foil is slow. Here are some screenshots of the wing I designed. Will print it next week.
Congratulations to all who flew already with their creation.
Gege2000   10 mW
Post by Gege2000 » Aug 18 2017 12:57pm
kiter_UK wrote:One used 8:1 still going on eBay
Thanks, I saw it, but in the description of the item was i=16. I asked the seller and it was a mistake, the right value is i=8, like mentioned in the title, so I bought it for 65€ (72€ with shipping). Cool.
Gege2000   10 mW
Post by Gege2000 » Aug 18 2017 1:16pm
Hi guys,
Could you tell me what do you think about this ESC ? https://hobbyking.com/fr_fr/turnigy-aqu ... tore=fr_fr
Best regards,
Gege
FROGMANGEEK   1 mW
Post by FROGMANGEEK » Aug 18 2017 2:56pm
Toto44 which airfoil profil did you choose for the wing ?
Do you plan to laminate the printed wing ?
Envoyé de mon F5321 en utilisant Tapatalk
markula78   10 µW
10 µW
Post by markula78 » Aug 18 2017 4:16pm
Gege2000 wrote:Hi guys,
Best regards,
Gege
Its not water sealed ESC. Is not more water resistant than a normal ESC, but it have a water cooling plate/connection.
parabellum   10 MW
Post by parabellum » Aug 18 2017 6:59pm
Best regards,
Gege
Looks like successor of aguastar 240. Thogh ESC, only one I did not kill in my early scooter and bike intents.
Unfortunately, topology is different and no beck, so its not same thing.
fruitygreen   1 µW
Reduction gear , propeller, and motor combo combination
Post by fruitygreen » Aug 18 2017 8:16pm
I see that the SSS 56104 IS a popular choice for motors and gear reduced with a Parker.
Yet some of the guys are using different ratio gear reduction
Does anyone have a theory on the relationship between motor, gear ratio and propeller size?
A chart would be nice to see. :D
slanton   1 µW
Post by slanton » Aug 18 2017 10:34pm
I was told by someone that helped with the Jet Foiler that the motor they use is about half as powerful as the SSS 56104 and that for the 14Kw SSS 56104 he recommended a 225mm ducted prop. He wouldn't say what their setup was. I also saw on a forum someone who had spoken to Nick Leason from e-Lift who said that their motor is in the 6Kw range.
parabellum   10 MW
Post by parabellum » Aug 19 2017 12:37am
Bigger prop and lower rpm is always more efficient actually. At 9" D prop, it should not take 2HP output to fly according to info of Jimmy22 about 30-35 kg take off thrust, lets say 2KW IN due to low efficiency, Motor-gears-9x6 prop at 2500rpm max.
IMHO: 14 KW on 56104 is probably a real data point where plasma ionises the air, creating more alternative conductivity paths, spitting vaporised copper dust all around a saturated stator and rapidly demagnetising rotor. Not considering, there are no ESC's to provide those 14KW reliably. :lol:
Gege2000   10 mW
Post by Gege2000 » Aug 19 2017 2:25am
markula78 wrote:Its not water sealed ESC. Is not more water resistant than a normal ESC, but it have a water cooling plate/connection.
parabellum wrote:Looks like successor of aguastar 240. Thogh ESC, only one I did not kill in my early scooter and bike intents.
Thanks. It's seems that the Seaking 130A V3 is the best candidate for the moment, with great reviews.
kiter_UK   10 mW
Post by kiter_UK » Aug 19 2017 3:49am
My parts list and sources so far in case of use. Nb. I am still in the early stages. Feel free to critique!
https://docs.google.com/spreadsheets/d/ ... p=drivesdk
Jezza   10 W
Post by Jezza » Aug 19 2017 5:59am
Best regards,
Gege
I'm taking a chance on the HK YEP120 Marine version. It's cheap and I wont be pulling more than 100A so it should be adequate. I'm also going to try get away without water cooling and instead use a heatsink.
toto44   100 mW
Post by toto44 » Aug 19 2017 9:55am
I am using Eppler 214 for the Wing. For stabilisier it will be naca 009. I had the idea to use a only Wing setup. Do. such foils exist?
markula78   10 µW
10 µW
Post by markula78 » Aug 19 2017 11:06am
Best regards,
Gege
I havent tested this, but the price is nice and it at least water seal.
http://www.ebay.com/itm/Flycolor-waterp ... SwZQRYa3nW
Maybe install a 40mm fan if it gets to hot.
