Electric Hydrofoil/E-Foil
Boats, Jet Skis, Kayaks etc., including hovercrafts
Jezza   10 W
Re: Electric Hydrofoil/E-Foil
Post by Jezza » Oct 22 2017 2:46am
superlefax wrote:Has anybody experience with this ESC:
https://hobbyking.com/de_de/yep-120a-hv ... -opto.html
Or any other alternative for the Seaking 130A?
I have the Yep 120A. I haven't used it in the water yet, but it should be fine with sufficient cooling.
msk8   100 µW
100 µW
Post by msk8 » Oct 22 2017 2:44pm
Have a look at this thread regarding this ESC: http://efoil.builders/t/esc-alternative/282
Hiorth   1 W
1 W
Post by Hiorth » Oct 23 2017 5:35am
Jezza wrote:
Hiorth wrote: Thanks :) nope ordered from a supplier.
Was it quite cost effective or expensive?
Did you just glue the joint between the housing and the mast mount again?
Parts was about 300$, which is quite inexpencive for a one-off. Nope, no glue at all this time. Only screws:) to ease maintenance.
Jezza   10 W
Post by Jezza » Oct 23 2017 9:14am
Hiorth wrote:Parts was about 300$, which is quite inexpencive for a one-off. Nope, no glue at all this time. Only screws:) to ease maintenance.
Thats really good! I'd love to see the internal design. Have you used a large thread from the mast mount to casing?
dirkdiggler   10 kW
Post by dirkdiggler » Oct 24 2017 4:47pm
Although I hate to see everyone leave and head over to efoil.builders, we need different sections for this type of build. The eskate forum here on ES was ruined when esk8.builders started. I do wish the mods here would have things like subsections where we could discuss items like ESC, prop size/shape, motors, foil and on and on. We'll end up with a 400 page thread if not and all the important info will get buried. Efoil.builders looks pretty chaotic right now too, but there are tons of informative posts already.
I also hate when guys try to monetize the info - but I guess everyone has to make a living somehow. A kickstarter for info though?!!? I can see selling parts for an efoil. Someone could do a whole setup with prop, duct, motor, esc and you bring your own foil/foil board and easily make cash off that. Kind of like how the eskateboard thing went.
I saw this yesterday which I found interesting.
https://newatlas.com/manta5-hydrofoil-bike/51826/
The current prototype version can run for an average of about one hour per charge of its removable battery, and reach a top speed of 15 to 20 km/h (9 to 12 mph). Plans call for the first limited-edition production model – the Hydrofoiler XE-1, pictured below – to be faster.
The Manta5 has an aluminum frame, two carbon fiber hydrofoils that provide lift, and a 400-watt motor that augments the rider's pedalling power to turn the propeller.
So if the foil has 400w and the rider maybe 200-300w, we are talking under a 1000w total. Also the foils are way different than a surf foil. Why do we not have something like they are using? Last - the prop being a push design would be better for an efoil for safety reasons. Your foot/leg will not be as prone to be in this area because of the front foil protecting it.
msk8   100 µW
100 µW
Post by msk8 » Oct 24 2017 7:50pm
Yes totally cool. Pedal powered foils have been around since 1983. See here: http://flyingfishhydrofoil.com/ ... and I think "Der Wasserlaufer" in 1952 was the first human powered one, here: afaik: https://www.youtube.com/watch?v=NVYQO-C8s0o
I am glad you too joined the new http://efoil.builders community. There are so many topics to research and discuss and this new site will help us all. It's growing fast and there are many good discussions happening already after less than a week. It won't be the only efoil forum which is totally fine but it is the biggest one in the world now. We have every efoil DIY maker I know off actively participating and also most of the ongoing commercial efforts are signed up and sharing what they can. Very exciting times. All info is free.
See you on http://efoil.builders
Merten
Just2807   10 W
Post by Just2807 » Oct 29 2017 3:09pm
I was looking some noise comparisons on youtube and noticed how much quieter ePropulsion next to Torqueedo is. I went to ePropulsion official site, they showed their "gearbox free" system. Possibly an outrunner? (i didnt find anything about dimentions but it doesnt look 2 bulky, not sure)
http://www.epropulsion.com/navy
kiter_UK   10 mW
Post by kiter_UK » Oct 29 2017 5:03pm
The 3kw system doesn't look that powerful. The 6kw is shaft driven (geared?) with closed loop cooling by the looks of it.
LogicalDIYBuilder   1 mW
Post by LogicalDIYBuilder » Oct 29 2017 7:13pm
I just shared this post on the main prop and duct thread http://efoil.builders/t/propellers-and-ducts/38/50, but this helps select the proper foil (wing shape):
Hey Guys, A backer of our eFoil Kickstarter Project found a really good program for wing foils and props both air and water. It helps you designed and test everything on the spot with JAVA based program. I have not yet read through the entire site but looks interesting.
You can even select the prop surface finishes…:
Smooth
Painted
NACA Standard
BUGS AND DIRT… yes, this is an option
https://www.mh-aerotools.de/airfoils/javaprop.htm
I'm an entrepreneur, stock & commodity trader, landlord, and self-storage business owner.
Built & Building: DIY Electric Hydrofoil Board http://www.diy-electric-hydrofoil.com/, Electric Dirt Bike, Self-Storage Portable Delivery System, High Volume Sand Dredge, Tazer/Stungun, Barge Boat, Air Planes
fechter   100 GW
Post by fechter » Nov 03 2017 8:08am
Just2807 wrote:I was looking some noise comparisons on youtube and noticed how much quieter ePropulsion next to Torqueedo is. I went to ePropulsion official site, they showed their "gearbox free" system. Possibly an outrunner? (i didnt find anything about dimentions but it doesnt look 2 bulky, not sure)
Yes, looks like a direct drive outrunner.
parabellum   10 MW
Post by parabellum » Nov 03 2017 10:05am
Isn’t it an in-runner on that picture? :)
fechter   100 GW
Post by fechter » Nov 03 2017 10:13am
parabellum wrote: Isn’t it an in-runner on that picture? :)
Maybe you're right, but it looks like magnets around the outside. It could be both inrunner and outrunner (magnets on both sides of the stator).
kiter_UK   10 mW
Post by kiter_UK » Nov 03 2017 1:32pm
Could bigger 6ke one be bevel gear?
Hiorth   1 W
1 W
Post by Hiorth » Nov 21 2017 7:09pm
