Farfles Electric Ultralight.
Things that fly
craneplaneguy   10 kW
Re: Farfles Electric Ultralight.
Post by craneplaneguy » Nov 01 2018 9:44pm
VG's on the UNDERSIDE of the hor stab, about 1.5" in front of the stab/elevator gap can increase the available elevator authority. In fact most certified vg's kits come with them for the stab, besides the wing tops. The wing ones let you attain a bit higher AOA before stalling and the enhanced elevator authority let you take advantage of that. Gap seals between the hor stab and elv, can also increase it's power, sailplane parts suppliers are a good source. Is your hor stab AOA adjustable? If so, set right?
I dealt with poor elevator authority in the flair with my first RANS S-7, which I installed a converted Subaru engine in, much heavier then it was designed for. Reliable as hell, 1300 hours and no problems, but unless it was loaded for XC or with a passenger, I was always on the verge of too far forward CG, even after adding lead in the tail. The above mentioned mods helped that condition.
Your static stick rigging should be based on how many degrees of movement you have in the control surfaces, set while on the ground.....not as a way to solve poor pitching power in the flair, ideally anyway! See if you can get a shot of your elevator in level flight/cruise, it should be in line with your hor stab for best performance.
Grantmac   100 W
Post by Grantmac » Nov 02 2018 12:15am
Agree with a fwd CofG.
You can likely do gap seals with either the covering you have or 3m clear car bra.
Adjusting wash out with the struts should be done in conjunction with stall testing otherwise you can get into an asymmetrical stall condition.
-Grant
bigmoose   100 MW
Post by bigmoose » Nov 02 2018 10:09am
Great thread, great build, great flights! :bigthumb:
"Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God..." all the best, Dave
jonescg   1 GW
1 GW
Post by jonescg » Nov 02 2018 10:08pm
bigmoose wrote:
Nov 02 2018 10:09am
Great to see you back BigMoose!
helno   1 W
1 W
Post by helno » Nov 05 2018 10:24pm
Great to see this project flying!
Farfle   1 MW
Post by Farfle » Nov 12 2018 3:13pm
Some onboard video of the Electric Belite!
Not quite enough authority on the elevator to flare for a proper three-point landing.
I have a list of fixes to apply:
Move the CG rearwards by moving the rear pack to the rear of its tray.
Adding some oratex to the elevator to act as a gap seal there
Verifying that the elevator pushrod is not bending under flight loads, and that the travel is to spec.
Test Review Revise Repeat
SlowCo   100 kW
Post by SlowCo » Nov 12 2018 4:48pm
Wow, how amazing to build your own electric plane and fly it. What an achievement! :bigthumb:
fechter   100 GW
Post by fechter » Nov 13 2018 9:28am
Looks great.
Any estimate of the power consumption for level flight?
spinningmagnets   100 GW
Post by spinningmagnets » Nov 13 2018 9:58am
Well done, Jackson! Congratulations.
grindz145   100 MW
Post by grindz145 » Nov 13 2018 1:54pm
Unreal.
kerim   10 mW
Post by kerim » Nov 22 2018 6:18am
What an inspirational project that is. I am very impressed!
Farfle   1 MW
Post by Farfle » Nov 26 2018 9:46pm
After re-weighing the airplane with a set of automotive corner scales, I got an identical result to the scales that the EAA had. So I moved the rear battery 8" rearwards, and replaced the elevator pushrod with a slightly less bent :shock: and slightly thicker walled tube that was slightly longer. Now the elevator is limited to 35° up and down symmetrically.
It flew amazingly well, and had all the flare authority that I needed for three point landings. The EMI problem has also been solved with a really awesome performing antennae located as far away as possible from the noise generating electronics (dumb AM Aviation radios). It is a dipole with the elements made from copper foil tape. It uses a Pawsey stub and Rg58 coax up to my handheld. Better reception and broadcast that the KX155 in the 172.
Image2018-11-26_06-43-59 by Jackson Edwards, on Flickr
ImageIMG_20181124_120939 by Jackson Edwards, on Flickr
ImageIMG_5967 by Jackson Edwards, on Flickr
ImageIMG_6044 by Jackson Edwards, on Flickr
d55guy   100 µW
100 µW
Post by d55guy » Nov 26 2018 10:58pm
Awesome job on first flight and diagnosing and fixing the squawks! Looking forward to more flight reports!
fechter   100 GW
Post by fechter » Nov 29 2018 1:30pm
Cool antenna. I assume you will route the coax inside the body somehow.
Post by spinningmagnets » Nov 29 2018 1:59pm
I love the folding wings!
Farfle   1 MW
Post by Farfle » Nov 29 2018 2:35pm
Yup! the coax went thru the composite tail into the cabin via the left rudder cable sheath, A friend of mine who is much skinnier than I helped me out:
Imageimage-20181120_164518 by Jackson Edwards, on Flickr
Image20181120_183842 by Jackson Edwards, on Flickr
Image20181120_183854 by Jackson Edwards, on Flickr
Image8541367466814476452 by Jackson Edwards, on Flickr
fechter   100 GW
Post by fechter » Nov 29 2018 3:45pm
Awesome. It would suck to crawl back there and get stuck.
Seems like there is a lot of empty space back there. Too bad it can't be utilized for something. A bunch of helium balloons?
Post by spinningmagnets » Nov 29 2018 4:05pm
This reminds me of the DeHavilland Mosquito. It was built as a left and right side all the way down the assembly line. Then the two halves were joined after the last test and inspection.
Also used a lot of wood...
Hillhater   100 GW
Post by Hillhater » Nov 29 2018 7:52pm
Wow !
That mention of Mosquito's gave me the chills :o
Yesterday i heard of the passing of an old aquaintance (father of a friend) that i had known for several years as just "another old guy"..before i learned that he had earned his "wings". flying Mosquito night fighters on incursion raids over Germany in the '40s. ..low level, high speed, night raids for precision bombing of secret targets , airfields, etc
I guess the pilots amongst you can imagine what that must have been like , in those aircraft , for ( at that time) a 20 year old.!
He instantly earned my maximum respect ! :bigthumb:
And i learned not to pre judge anyone.
craneplaneguy   10 kW
Post by craneplaneguy » Nov 29 2018 11:52pm
Awesome looking little bird, it has a "just right" stance, some planes don't, though they may fly OK. All the lightening holes are good to see, nothing worse then hauling around unneeded material. Putting lightening holes in everything can be addictive, a good habit to have.
So what was the final all up weight?
Farfle   1 MW
Post by Farfle » Dec 10 2018 8:53am
Heya all! Quick update on the Electric Belite.
The Flight report so far:
Three hours and 27 landings in. This last flight, the squawk list had nothing on it to start the flight, and no new entries to add at the end of the flight.
Now that the squawk list is clear, it is time to start filling out the Poh data. So there will be several flights coming up determining stall speed, best glide speed and also bringing in operation of the flaps and determining flap performance for short feild takeoffs and landings.
riba2233   1 MW
Post by riba2233 » Dec 12 2018 2:03pm
OMG, congratulations man! I never had even a slightest bit of doubt in your success :bigthumb: :bigthumb:
