New Chargery 1500 24s charger
Inwo   10 kW
Post by Inwo » Jun 30 2017 6:35pm
First look:
Controlled directly by bms-24.
Available July 2017
MSRP $350
Hope to have 20pcs in USA July 2017.
A beta sample in a week.
chargery 1500.gif (61.15 KiB) Viewed 4609 times
Features
The Battery Charger has been designed to provide reliable, quality charging for battery systems in
electric drive vehicles. It is a high efficiency wide input voltage charger, the charger can output 1500W at
AC90V~265V in a smaller size. Many creative technology help to realize up to 94% of efficiency, and the
internal temperature is still under 50℃. The following are some new features:
 Intelligent control output voltage and current by microprocessor, 100% calibration before
delivery
 ±1% voltage and current accuracy
 Active PFC: smaller AC input current less interference, and Conform to European Commission
Regulation no 278/2009 and Energy Star Version 2.0
 AC 90-265V worldwide operation: need not any alternative switcher, worldwide safe operation.
 Low power consumption (less than 1W) at idle mode and standby mode
 Up to 94% of convert efficiency.
 Programmable output voltage from 10V to 102V
 Programmable output current from 1A to 25A
 TFT color LCD display output Voltage, current, power and internal temperature on time.
 Over current, over voltage, over load, over temperature, and short circuit protection
 Short-circuit protection on output, safer and more reliable.
 2 Intelligent cooling fans turned on and adjust speed upon the temperature automatically
 ZVS/ZCS and Synchronous Rectification
assure the highest efficiency.
 High power density: 652W/Kg
 Start at no load or full load
 Approved by CE
 24 months warranty
Application
 Home application
 Electric drive vehicles
madin88   1 GW
1 GW
Re: New Chargery 1500 24s charger
Post by madin88 » Jul 01 2017 8:57am
seems to be a great charger for higher powered vehicles - at least if there is no Adaptto system installed.
10-102V, 1-25A, 94% eff, active pfc and lots of protections sounds AWESOME.
finally there is a good alternative to the crap EMC / BMS battery chargers.
- 10kW belt drive with Neumotor 8057: [url]viewtopic.php?
- KTM Hardtail Pedelec / eZee V2 6T / 27,5" / Kelly KBSX @ 1,5kW / Torque PAS / CA-V3 / 13s4p Sanyo GA in Shark case
Inwo   10 kW
Post by Inwo » Jul 01 2017 10:30am
Remains to be seen. However if it's built and designed like the BMS-24 it will be great.
Direct communication with the designer who listens and supplies trouble shooting help. His boss won't let him release source code or complete schematics, but he will supply partial diagrams as needed.
I suggested a few things that he is working on. Such as networking in a future version that will allow battery health to be followed remotely.
A buddy let 10 Leaf modules go dead at a second home because of an ac connection that needed a harder insertion than was supplied by an unnamed spouse. :oops:
Also an auto start selection for maintaining charge. Even after power outage, hopefully.
I'll post his answers, and pass along any suggestions.
Steve asked for light and rugged, but I don't believe a 25a charger with fans will ever be a good on-board charger.
Opted for XT-90 connectors included as it makes it easy for full power burn in a factory.
Tail included.
Inwo   10 kW
Post by Inwo » Jul 01 2017 10:35am
Hi Dave,
Thanks for your suggestions and from Grant.
Lock programming choices option? For simple start procedure. It means charge same battery at last charge setup, we will modify the program as below,
on battery type interface, choose battery type and then press knob for 2 seconds start to charge at last charge setup, OK?
Restart option to allow continued connection to vehicle during storage. It means the battery is still connected to charger, and charge connected to AC outlet, when battery voltage goes down 2V or more, the charger will restart to charge, correct? If yes, we will add a option on program setup interface, such as “Restart to charge” YES or NO.
Maybe a low power selection for maintaining batteries. Maintain button for storage of lead acid types? Maintain means battery voltage is in storage, such as lead acid battery is 2V per cell, LIPO is 3.85V per cell, but the charger don’t discharge, if battery voltage over storage voltage, how to maintain? If battery voltage under storage, can setup the charge terminal voltage to storage, the charger will charge to storage as maintain. At the same time, setup “Restart to charge” is yes, the battery will keep the storage voltage.
Restart with bms settings. Or restart with low voltage. Even restart weekly to check battery level. Restart with low voltage, not restart weekly to check, or with BMS settings.
If not possible, maybe alarm low level. Operates if no ac power and low battery. we can do the Restart function.
Future future version.
Network solution. User can poll charger from another location to see how his baby is doing. Smile good idea.
Either bms or charger.
Separate product?
Waiting for your kind and soon comments.
Have a nice day
Inwo   10 kW
Post by Inwo » Jul 01 2017 10:47am
Inwo   10 kW
Post by Inwo » Jul 03 2017 8:30pm
Edit:
Shipping date to me is 3 weeks.
Last week or two for pre-order at $300.
Once I have them for 3 day shipping:
1 pcs $350 msrp
chargery 15002.gif (91.57 KiB) Viewed 4512 times
liveforphysics   100 GW
Post by liveforphysics » Jul 04 2017 4:22am
That's fantastic to see a ZVS power supply topology enter the hobby world. I may get one for my kick scooter, thanks for importing them.
vipster76   1 mW
Post by vipster76 » Jul 04 2017 5:01am
can the amps increase at lower voltages ? or is the current fixed?
Inwo   10 kW
Post by Inwo » Jul 04 2017 6:22pm
My understanding is 1500w or 25a limit.
After I get a few out, I will welcome suggestions on improving them.
No way to update in the field. (he may give me the ability if there are bugs)
The price is high, so will only order moq of 20pcs unless there is a lot of interest.
I asked about referring international sales back, for direct delivery. I was told there is no saving for customer buying direct.
Whether true or not I don't, and have no control. I will ship when convenient, if I can save you money, but have no interest in coming out of retirement. :D
cwah   10 GW
Post by cwah » Jul 09 2017 7:06am
Whats the weight and dimension?
Inwo   10 kW
Post by Inwo » Jul 10 2017 2:39pm
Mechanical Characteristics
 Size:275*170*68 (L*W*H, mm) or 10.8 * 6.7 * 2.7 (L*W*H, inch)
 Weight: 2.46Kg without input cable
 Input power cable: AWG14 wire, 1.5m length
 Output DC connector: XT-90 male connector
cwah   10 GW
Post by cwah » Jul 10 2017 3:10pm
thanks. A bit on the heavy side!
Inwo   10 kW
Post by Inwo » Jul 12 2017 11:25pm
Info is now on Chargery.com.
Based on power supply 1500w. Over 5,000 sold in usa.
25a 102v output can be set up in power supply mode.
Set up to restart when voltage drops 5%.
I would think 10% better?
Up to 4 can be connected parallel for fast charge.
Next release 3000w charger.
Inwo   10 kW
Post by Inwo » Jul 12 2017 11:27pm
vipster76 wrote:can the amps increase at lower voltages ? or is the current fixed?
25a max
New models will do 50a and 60a.
From 120vac if you want.
Inwo   10 kW
Post by Inwo » Jul 13 2017 5:05pm
Beta model in my hands.
Test tonight.
ohzee   1 MW
Post by ohzee » Jul 13 2017 5:29pm
Inwo wrote:Info is now on Charger.com.
May not matter so please feel free to disregard , but charger.com forwards to 7sc.com and neither seemed to have any information.
Ahh I see you meant this web site http://www.chargery.com/ . I am straight now.
Inwo   10 kW
Post by Inwo » Jul 13 2017 5:47pm
OMG!
This charger is great. Has everything I asked for.
Without instructions, had it charging a 24s volt pack in 5 minutes.
Set chemistry
Cell count
Current
End current
End voltage 4.1 etc.
Displays:
Volts
Amps
AH
Time
Single knob setup:
short press to change setup
long press to charge
short press to abort
Select in menu, one time charge or restart with 5% drop ( for storage set up for 3.7v or whatever)
Does Lith or lead etc. all
Power supply mode for 10-102v 1-25a.
Inwo   10 kW
Post by Inwo » Jul 13 2017 5:54pm
Factory approves connecting in parallel for fast charge. Up to 4.
Rube   100 W
Post by Rube » Jul 14 2017 5:23am
Super flexible charger setup, awesome!
Noted for my next build :D
rojitor   100 kW
Post by rojitor » Jul 14 2017 5:29am
I luv it! Do you make discounts for students? Lol j.k. It is worth every penny.
Inwo   10 kW
Post by Inwo » Jul 14 2017 12:46pm
Thanks,
Typo
fechter   100 GW
Post by fechter » Jul 14 2017 2:38pm
Ahr display on the charger is a great feature.
Let me know if they come out with a smaller version. This one would be overkill for any of my packs.
Inwo   10 kW
Post by Inwo » Jul 14 2017 3:15pm
If a few people agree with you, I'll see what I can do.
A 3000w is in the works.
Smaller size and weight is what you need?
Remember this can be used for all your batteries and as a bench supply.
In all honesty I'm having trouble finding the time for testing. A bunch of projects are happening at the same time.
And Jason needs feedback to finalize sw.
So far it can't be updated in the field.
vipster76   1 mW
Post by vipster76 » Jul 14 2017 4:44pm
i wonder how much it would be shipped to the uk
Post by liveforphysics » Jul 14 2017 5:08pm
The 3kW unit sounds like a fantastic addition to ebike charging options. That's right about perfect for timely charging ebike sized packs.
