Sur-Ron - New Mid drive Bike
rcmonstermike   1 mW
Post by rcmonstermike » Jul 15 2018 5:15pm
Tommm wrote:
Jul 15 2018 3:54pm
rcmonstermike wrote:
Jul 15 2018 12:41pm
28.4 degrees....about .3 degrees less than my electricmoto blade(28.7), which uses the same forks, and identical to my ktm 350xcf. Didn't calibrate, but the 3 bikes show apples to apples comparison.
So 90-28.4=61.6 to the ground! That is some serious slack there. Downhill bikes don't go lower than 63. :lol:
As I said, I didn't calibrate anything, but compared other bikes for a realistic comparison. FWIW, the KTM specification is 26 degrees - same as the firefly. In practice, the number is constantly changing during the ride - bumps, acceleration, braking, where I sit on the seat, etc., all make for a constantly changing angle, so I don't get hung up on the static number so much as the "seat of the pants feel" - I haven't had ample time to make a determination, so the jury is still out on that. I also find that I end up quite forward on the seat on the firefly for some reason(nuts on the battery cover if you know what I mean) - so I likely am getting a fair bit of compression on the forks(effectively reducing the angle) - I felt like the stock forks were actually too steep for me(not enough angle) based on the actual seating position. I considered lowering the forks by about an inch(reduce travel to 11", add rigidity) if the need arises - it'll be a week or so before I get any real time to put it through its paces to determine my next move. It doesn't have enough power to really push things either.....yet. I do feel like a longer swingarm is most certainly in my future, which should balance things out nicely once properly setup. :-)
motomoto   1 kW
Post by motomoto » Jul 15 2018 9:14pm
Looks pretty awesome rcmonstermike.
I have tried to find those forks at different times and could never find any for sale.
Like what you have done.
rcmonstermike   1 mW
Post by rcmonstermike » Jul 16 2018 8:34pm
motomoto wrote:
Jul 15 2018 9:14pm
Thanks motomoto - I managed to get a spare set of forks when I got the blade and never used them....wasnt thrilled with the RST, so good opportunity to put the extra set to work. Looking fwd to seeing what you have working. :-)
motomoto   1 kW
Post by motomoto » Jul 18 2018 10:40pm
looks like we killed the thread monstermike, no one has posted since monday.... weird.
rcmonstermike   1 mW
Post by rcmonstermike » Jul 19 2018 6:46pm
motomoto wrote:
Jul 18 2018 10:40pm
Maybe everyone else is out riding....lucky dogs! I did manage about an hour yesterday in some tight single track.....thank you Mr. Marzocchi!! Suspension is a ton better than stock up front and the rear worked well (better shock and longer swingarm still on the list). I really need more power now....it eats up technical stuff quite well, but falls on its face too soon.
Tommm   10 kW
Post by Tommm » Jul 19 2018 9:36pm
Jul 19 2018 6:46pm
motomoto wrote:
Jul 18 2018 10:40pm
For single track you will have enough power if you change to 60t rear.
rcmonstermike   1 mW
Post by rcmonstermike » Jul 19 2018 9:50pm
In really tight, not too steep stuff I agree - the 58t provides ample power, even in eco mode(or whatever it's called) if it's "bicycle tight" and flat. It needs more when things open up and for climbing, though(gets me up most anything, but not very fast). I ran a 72v, 300 amp setup in my blade(brushed perm or etek motor) - now that has some snap(bigger bike, too)! I'd like to triple the firefly's power (or so) tbh.....
jph3   10 mW
Post by jph3 » Jul 20 2018 12:12am
I feel like this topic should be split into its own sub forum. My head is spinning looking for info.
Need to upgrade the brakes, mine are shot. Any suggestions?
Also, I have a brand new set of 58 tooth sprockets from Kim, for sale. I thought I had ordered 52’s... PM me if you want the 58’s, I have 2 of them, come with the chain extensions, they are still in original packaging.
stonezone   100 W
Post by stonezone » Jul 20 2018 12:32pm
Magura mt5 from starbike
LR-BB on 2014 Glory
Sur-Ron
B B S-HD on some sort of DH Kona frame
2017 GG GP 300 <3
RIP Bobarella
Rix   100 GW
Post by Rix » Jul 20 2018 2:22pm
jph3 wrote:
Jul 20 2018 12:12am
+1 on the MT5 Magura with the 200mm/203mm rotors, they work very well, and even though they aren't the most powerful DH MTB brakes on the market, they work very well and have minimum fade when really hot.
stonezone   100 W
Post by stonezone » Jul 21 2018 1:16am
And to add to that, I found 50 pads for $50 on ali express. Although you’ll run 4 pads per brake you are effectively upgrading to mt7. I’ve been running them on the stock rotors with no issue.
Has anyone tried any other controllers besides the asi yet???
LR-BB on 2014 Glory
Sur-Ron
2017 GG GP 300 <3
RIP Bobarella
nethern   1 mW
Post by nethern » Jul 21 2018 7:39am
Did someone do something about the chain noisy? I realized the chain is touching the bolts on the front spocket. Need A smaller head bolt? Or a bigger front spocket?
motomoto   1 kW
Post by motomoto » Jul 21 2018 4:19pm
I think I jacked my battery. I washed the bike with the battery in and it had about a 50% charge. I put it
on the charger later and it went to 16% with the 16 flashing and the left side bar flashing and it won't charge
with either of my chargers.
Rix   100 GW
Post by Rix » Jul 21 2018 5:22pm
nethern wrote:
Jul 21 2018 7:39am
I haven't checked mine yet, but if its touching the bolts, it must be touching consistently as my chain tension doesn't change.
Rix   100 GW
Post by Rix » Jul 21 2018 5:24pm
motomoto wrote:
Jul 21 2018 4:19pm
May want to pull the battery from the bike, and let it sit in the sun for a couple of days and let UV rays dry things out. If that doesn't resolve the issue, time to split the case.
n2mb   100 W
Post by n2mb » Jul 21 2018 11:50pm
Rix wrote:
Jul 21 2018 5:24pm
motomoto wrote:
Jul 21 2018 4:19pm
Direct sun might be bad. Roasting the pack above 110f is bad for long term battery health.
Allex   1 GW
1 GW
Post by Allex » Jul 22 2018 5:02am
Open up the top lead of the battery and let it dry on a sunny day under a shadow...might help.
Rabid   1 mW
Post by Rabid » Jul 22 2018 5:06am
Has anyone thought about taking their bike with them on a plane? Is it at all possible with the battery, or is the battery too big to take on a plane (even if brought as hand luggage)?
Tommm   10 kW
Post by Tommm » Jul 22 2018 7:09am
Rabid wrote:
Jul 22 2018 5:06am
There are fixed prices for bikes in different weight categories, I doubt the sur ron will fit in any of them. The battery is considered hazardous so hand luggage is out of the question.
motomoto   1 kW
Post by motomoto » Jul 22 2018 8:48am
I took the top off and there was no moisture in it. It has sat a couple of days with the top off and no change. I guess I should
consult Luna and see what they say. It kind of sucks because they cost so much. I still have the battery for the other bike.
Rix   100 GW
Post by Rix » Jul 22 2018 9:07am
n2mb wrote:
Jul 21 2018 11:50pm
Rix wrote:
Jul 21 2018 5:24pm
motomoto wrote:
Jul 21 2018 4:19pm
This is true, but if the was water inside, getting things warm is the best way to get rid of the water. Either way, it doesn't appear that was the issue.
Rabid   1 mW
Post by Rabid » Jul 22 2018 9:18am
Tommm wrote:
Jul 22 2018 7:09am
Rabid wrote:
Jul 22 2018 5:06am
Airlines I've used before usually give up to 50kg for a 'bike bag', so I'm less concerned about the weight as what to do with the battery. Rules now say that batteries should be taken in hand luggage (as far as I'm aware), but there are also limits to the capacity of batteries that you can take. Was just wondering if anyone had transported their Light Bee by plane and if so how they had done it.
fechter   100 GW
Post by fechter » Jul 22 2018 9:53am
If you have it apart you might be able to measure the individual cell voltages and see if any are out of line. Disconnecting the pack from the BMS might reset it too.
jamilon01   100 µW
100 µW
Post by jamilon01 » Jul 22 2018 12:50pm
motomoto wrote:
Jul 22 2018 8:48am
MOTOMOTO, did you try the battery reset procedure? Plugging the charger in and out? My battery was brought back from the dead by doing this.
https://electricbike.com/forum/forum/kn ... umentation
Awaking the Battery after Auto-Sleep mode:
Plug the charger into the Main power. Do not turn on the charger, then insert the charger into the battery charge port.
Turn on the main power, the moment, the red and green indicators of the charger will alternately blink, turn off the charger and then on again.
The red indicator of the charger will blink fast (0.5 second per time). The blink time will last to 20 seconds.
After the 20 second blink, the red indicator will be a constant light for 10 seconds. During this 10 seconds, turn off at the power point and then on for one time.
After Step 4, the “Forced Charging” function of the charger will be turned on. Then, the charger will work normally.
Remarks:
In Step 3, during the red indicator’s 20 seconds fast blink, please do not turn off the charger. Otherwise, you need to start the procedure again from step 1.
In Step 4, the action to turn off and then turn on the charger needs to be finished during the 10 seconds, when the red indicator is constant light. Otherwise, you need to start the procedure again from Step 1.
rcmonstermike   1 mW
Post by rcmonstermike » Jul 23 2018 5:43pm
motomoto wrote:
Jul 22 2018 8:48am
Maybe just the volt-meter is bad? What voltage is present at the main leads(controller plug)? Have you tried to charge and/or discharge(run) it since the display issue developed?
