Power PCB for Lebowski Controller to be combined with Bobc's processor board
whereswally606   100 kW
Re: Power PCB for Lebowski Controller to be combined with Bobc's processor board
Post by whereswally606 » Mar 29 2018 4:55am
I have a motor bike (emax scooter) should be fun :twisted:
Distributing "Lebowski" FOC Controller PCB (Through hole) since 2016
Moped: Emax 110s 2009
izeman   10 GW
Post by izeman » Apr 01 2018 2:50pm
200A phase? no problem. you can do it with most motors. even my little MAC takes 150A easily. could go up to 200A but there's not need in my application.
every mxus like hubmotor needs more than that to perform ...
Lebowski   1 GW
1 GW
Post by Lebowski » Apr 02 2018 2:31am
and this is where I keep assorted lengths of wire...
Post by whereswally606 » Apr 03 2018 1:40am
Is this the next gen chip or the same but perf board variant of bobc brain?
Lebowski   1 GW
1 GW
Post by Lebowski » Apr 07 2018 5:05am
This might become the next generation... depends on whether I get sensorless full torque at standstill working...
The power pcb makes for a nice development platform, only need to build a new processor board and can use the power pcbs output stage and current sensors.
Altair   100 W
Post by Altair » Apr 07 2018 7:01am
Lebowski wrote:
Apr 07 2018 5:05am
"sensorless full torque at standstill"
Wow... THAT would be the apotheosis of motor control.
Up to now, people have only dreamed about that. :lol:
Lebowski   1 GW
1 GW
Post by Lebowski » Apr 07 2018 8:14am
TI has it (and is the only one I think) but as far as I know has not published how it works... plus figuring out for myself is more fun :D
Altair   100 W
Post by Altair » Apr 07 2018 11:20am
Well, I wish you LOTS of fun, and at the end of it, a Nobel prize or something! :lol:
But seriously, I hope you will be able to sell your design one day.
(But don't give them the exclusivity, to the detriment of ES builders) 8)
Post by whereswally606 » Apr 13 2018 4:19am
progress from yesterday
don't do it like this. using scrap extrusion from a upvc window
here is were my screws went in (white arrow) to be attached from the outside
A lot of tedious filing and grinding went into this and it is useless.
after all this work I realised I couldn't solder the fets and then take out the heatsink to place the insulating pads in. I had a long hard think about where my other scrap aluminium was and after about an hour of tearing the house apart I found it.
do it more like this (still needs insulating pads) as Lebowski originally demonstrated
so now I'm on to the other power board bits which I shall try to create a video for.
Post by whereswally606 » Apr 13 2018 7:33am
There is an issue with the Zip on the first page.
It contains a file called component list, it is missing some of the cheaper more generic components on the board
here are the missing parts.
components missing.png (18.53 KiB) Viewed 1262 times
I only realised when attempting to build my powerboard so I could start testing.
This will set me (and others in the group buy) back till I can buy in the bits I'm missing.
How this happened is I didn't open the project first in KICAD and produce the BOM for myself but thought that every thing was in the file called component_list.
:roll:
Lebowski   1 GW
1 GW
Post by Lebowski » Apr 13 2018 9:52am
Make sure you get the correct gate resistors for the Fet you are using.
Also, leave some room between Fets and PCB, this make it easier to replace a broken FET and for fattening uo the traces.
Post by whereswally606 » Apr 13 2018 11:16am
Make sure you get the correct gate resistors for the Fet you are using?
Which are the correct resistors for the 4468 fet, Nobody is using anything else?
Ive just put in a digikey order with the components in the picture before. Am I missing something?
This just added £40. I feel like I'm gaining nothing but experience at this point. and frustration.
components missing2.png (22.86 KiB) Viewed 1250 times
this is what I ordered (10 sets of to get free shipping) and some dip8 sockets
I think these are right for the 4468 fets as you posted on the first post of this thread Bas.
Post by whereswally606 » Apr 13 2018 1:28pm
This is as far as I could get today. Hopefully Monday I'll have more parts and can finish it.
Lebowski   1 GW
1 GW
Post by Lebowski » Apr 13 2018 4:04pm
Just be meticulous and building the board should pose no problems.
I would however add copper wire to the high current traces. Solder basically has about 10 times the resistance of the equivalent area of copper. So you need 10mm^2 of solder (a 2 mm thick layer on 5 mm wide traces) to get the equivalent resistance of only 1 mm^2 of copper..
Post by whereswally606 » Apr 14 2018 8:05am
I twisted some 1mm copper ground cable to a coil and soldered it to resemble your beefing up of the power traces.
Also I've left a decent gap from the board to the bottom of the heatsink.
Just got to wait for parts now
Post by whereswally606 » Apr 16 2018 4:46am
Digikey parts arrived. so should be able to finish my power board and update the other 3 kits from the group buy. I bought 6 more assemblies worth to make up the shipping so It was free and will sort those and sell them with the spare boards I bought, that way in the long run it wont matter about this mistake.
Anyway I'm getting quite a bit of interest now in the brain boards so it will be great when I can test the boards before bothering bas about them.
:D
Sorry to all those who are patiently waiting.
coleasterling   100 W
Post by coleasterling » Apr 16 2018 12:03pm
If you come up with a heatsink design I'll gladly machine it and send them out to the other beta guys.
Post by whereswally606 » Apr 16 2018 2:08pm
coleasterling wrote:
Apr 16 2018 12:03pm
That's a very cool offer. I'll look into it.
Post by whereswally606 » Apr 16 2018 4:11pm
Tonights progress
So I didn't do any in the brain boards tonight. I was up at 6am and I didn't feel awake enough to solder the fine pitch stuff. So tomorrow I should have something to test with. bas before I power up this bad boy are the 4r7 resistors in r18-r23 correct for the 4468 fet.
So this is the beefy trace on the underside. You cant see much of the on top under the fets.they are similar though.
Lebowski   1 GW
1 GW
Post by Lebowski » Apr 17 2018 1:04am
Yep, R18-23 for 4468's should be 4.7 Ohm, R12-17 should be 15 Ohm.
R1, I dont know the value of this one yet, it is a filter resistor for the processor board supply. Ive been using 100 Ohm so far, but shorting it out should be ok too. Plan is to drop around 5V across this resistor, assuming the power dissipated wont be too high.
Ianhill   100 kW
Post by Ianhill » May 12 2018 8:26am
lizardmech   1 W
1 W
Post by lizardmech » May 13 2018 1:48am
Lebowski wrote:
Apr 07 2018 8:14am
Do you have any theories as to how instaspin differs from other FOC controllers? I know they aren't using HFI by default, the only notable difference I have been able to find is that they use the phase voltage sense combined with hardware filters to do something, the firmware has to know the value of these filters, either omitting the phase voltage capacitors or having the wrong value in the firmware causes the entire thing to fail. I think they are using them for some other purpose than just tracking rotor position when its coasting, the filters appear to be there to reject PWM which indicates they use them while the motor is being driven.
Lebowski   1 GW
1 GW
Post by Lebowski » May 13 2018 3:34am
Tja, I don't really know what TI does with Instaspin. If you have a schematic somewhere I'd be interested to have a look...
What I have seen somewhere (but this is not FOC or rotor position detection at standstill) is that they integrate the phase voltages to get motor flux (as voltage is the derivative of motor flux). And then commutation is based on motor flux.
I don't do this as I drive all three motor voltages constantly... there's no point in measuring motor voltages if you supply them yourself by means of the output stage... I also try to stay motor parameter independent. One of the nice things that I have in my sensorless running is that it does not need to know motor parameters for the control loops to be stable. This means that for instance the Nissan Leaf motor from Arlo1's car runs with the same control loop parameters as Izemans MAC motor...
lizardmech   1 W
1 W
Post by lizardmech » May 13 2018 8:30am
Lebowski wrote:
May 13 2018 3:34am
It's fairly mundane, note the 0.1uf caps after the voltage dividers on the phase voltage sense. I stumbled on to the impact it has by accident, I built a power stage that allowed me to switch between a VESC compatible MCU and Ti instaspin launchpads. The VESC has a nice GUI that allows you to generate graphs of the various analogue inputs, normally when running in FOC mode you get no useful data from phase v sense as you said, when I was running the VESC on the power stage with filtered vsense I discovered you could suddenly perfectly observer the sinusoidal BEMF voltages while running FOC. I'm not entirely sure how it works or what instaspin uses the data for, I think the capacitor basically holds the BEMF voltage sensed during the PWM deadtime until the ADC is triggered in the centre of the next PWM cycle, presumably this introduces a delay so the frequency of the filter must be known so as to apply compensation.
How do you deal with the impact of motor inductance and resistance for your sensorless controller? Doesn't the stator flux have a delay as ERPM increases which requires motor details to be able to compensate for?
Lebowski   1 GW
1 GW
Post by Lebowski » May 14 2018 2:55am
basically the circuit is a lowpass filter. With the VESC it allows you to filter out the PWM and see the sinusoidal content of the output.... though it should look more trapezoidal than sinusoidal.
You need the motor parameters to calculate the correct timing advance for FOC. But mine does not need to know the motor parameters for stable control loop operation (and this is unusual).
