Axial Induction motor with no magnets.
GordonFreeman   1 µW
Post by GordonFreeman » Dec 14 2017 8:37pm
Is there such a thing? I'm thinking the stator design would be like the coreless pancake motors I've seen on here. And the "cage" rotor would be sort of a "spoked" shape. An inner ring, an outer ring, with the copper conductor "spokes" connecting them. Would that be the right orientation to work? Asynchronous is a goal.
Upsides, downsides?
Also do induction motors need laminations on both stator and rotor? I see coreless designs on here, so what do lamenations really do?
GordonFreeman   1 µW
Re: Axial Induction motor with no magnets.
Post by GordonFreeman » Dec 15 2017 5:18pm
Nothin"? Maybe my paint skills will get some comments.
major   10 kW
Post by major » Dec 15 2017 9:57pm
Axial air gap induction motors (and generators) have been around for a while although not too common. Here's a discussion: http://forums.aeva.asn.au/viewtopic.php?t=1966 Google brings up many other examples.
And ferromagnetic cores are used because the material has a magnetic permeability of thousands times greater than air.
Regards,
major
GordonFreeman   1 µW
Post by GordonFreeman » Dec 16 2017 1:31am
Ah, thanks. So it works and a wheel motor is indeed the application.
There must be some reasons it's not popular, since it's not a new idea.
I ask about coreless as this would be a DIY project. I assume coreless would make less torque?
Thanks for the input.
