More LTO cells ~3.5ah
Got something to sell? Have extra parts that need a good home? Have something that others would need to complete their kits? Post it up here and see if anyone else is searching for what you are selling.
Inwo   10 kW
Post by Inwo » Mar 06 2018 4:20pm
Don't know condition, new or tested, or quantity.
Any interest? Too small for me.
Only samples so far. I could arrange shipping a single sample if someone wants a head-start.
Should be at least 500pcs available.
spinningmagnets   100 GW
Re: More LTO cells ~3.5ah
Post by spinningmagnets » Mar 06 2018 6:31pm
Needs banana for scale. I bought six of the 11Ah foil pouches. And I thought five of them would be good for a 12V pack. The seller I got them from insisted they worked better as 6S, so I will try that. It's an odd voltage. 2.4V nominal, but...if you look at the discharge curve graphs, the useful range seems to be 2.2V to 2.6V.
They can be charged up to 2.8V, and the listed LVC is 1.7V, however, one of the interesting features is that "supposedly" they can be discharged to zero, without suffering any harm.
Very high C-rate when charging and discharging.
Can operate in unusually cold weather much better than the more common chemistries.
Very high cycle life, 7,000 cycles seems to be a common spec...
Xxxxxxxxxxxxxxxxxxxxx
One of the uses is as a feeder for a 12V capacitor bank, being used to start a car. There are many videos of supercapacitors (five 3.0V, or six 2.7V) that easily start a car in extremely cold weather (where lead acid, and even lithium will struggle with voltage sag).
Also, the capacitors are not hurt by very hot weather (lead-acid batteries in Phoenix in the summer). A properly-specced supercap bank can be charged directly by the cars alternator system.
Capacitors should last the life of the vehicle, but...their one huge flaw is that they slowly drain down over time.
There are two strategies to fix that. One way is to use huge supercapacitors that will last a couple weeks before draining, or...use a small supercapacitor bank that is coupled with a hand-sized 12V battery. ($60-ish for the caps, Google 3.0V Amperics)
https://www.amperics.com/product/am12v250a/
Charge the capacitor bank through a 1/2 ohm resistor, then start the car with the supercaps. Since LTO chemistry performs well in the cold, it could still be kept in the car. It's long term life-cycle is a great match for supercaps.
Once you are driving, recharge the LTO pack from the 12V utility socket. The small 12V pack can also be a sweet portable phone or laptop auxiliary battery bank.
Inwo   10 kW
Post by Inwo » Mar 06 2018 10:32pm
A little wider than the 11ah.
6s is best for automotive use. 16.5 volt max should never be reached with alternator.
2p will start a v8. 3p for racing motors.
I'm using 2p on my diesel mower.
These small cells are dead. Mike is testing them hard. From dead to full in 8 minutes.
I had a bunch of these small ones before, but gave them away with another sale.
Post by spinningmagnets » Mar 06 2018 11:16pm
How much for 12 of these?
_________LVC___useful range___max charge
Per cell__1.7V____2.2V---2.6V___2.8V
____5S___8.5V__11.0V--13.0V__14.0V
____6S__10.2V__13.2V--15.6V__16.8V
Inwo   10 kW
Post by Inwo » Mar 06 2018 11:40pm
$100 for 12pcs 11ah conus Friends and family. 😉
12 are easy for me to ship.
themelon   1 W
1 W
Post by themelon » Mar 07 2018 5:08pm
I'll take a sample to try out if you are still offering.
Post by spinningmagnets » Mar 07 2018 5:17pm
I just recieved six of the 11Ah pouches, very well packed and rapid shipping. Depending on how the experiments go, I may buy a $h!t-ton of these while they are available. If they work for the 12V "suitcases", they should last my lifetime...
Just bought a $40 Harbor Freight Tool (HFT) suitcase that is a Pelican clone. Apache brand, Model 3800, $40.
Inwo   10 kW
Post by Inwo » Mar 07 2018 11:38pm
themelon wrote:
Mar 07 2018 5:08pm
My partner is on vacation for a couple weeks.
He has test charged a completely dead cell @25a rate.
Full capacity.
themelon   1 W
1 W
Post by themelon » Mar 08 2018 8:18am
Inwo wrote:
Mar 07 2018 11:38pm
themelon wrote:
Mar 07 2018 5:08pm
Full capacity.
I have come up with a number of uses for them and would likely not have a problem going through more than 500 cells pretty quickly. Can you post basic dimensions while your partner is out? PM me and we can work something out. I am genuinely interested.
Inwo   10 kW
Post by Inwo » Mar 08 2018 1:20pm
Vanarian   10 kW
Post by Vanarian » Mar 15 2018 8:53am
Inwo wrote:
Mar 08 2018 1:20pm
Can you please detail what we see ? packs are roughly 70x47mm and 100x47mm ? What is the thickness of both, what is the weight / pouch ? Which specs for both size ?
At 1.50$ / piece it looks pretty affordable ; is it 2.4v 3.5Ah ? What is the max discharge per cell (I see you tested up to 25A) ?
If I calculate roughly 60 cells = 90USD + shipping ? 20S3P, 48V 10.5Ah ?
-+AT-One project : electric inline skates - no remote, hub motors, one frame for various wheel sizes & quasi-universal boot mount
Rollo Ergo Sum!
cal3thousand   1.21 GW
1.21 GW
Post by cal3thousand » Mar 15 2018 11:11am
themelon wrote:
Mar 08 2018 8:18am
Inwo wrote:
Mar 07 2018 11:38pm
themelon wrote:
Mar 07 2018 5:08pm
Full capacity.
That's a lot of cells. How do you plan on arranging/connecting cells?
Get a Cycle Analyst and a Multimeter, you're still a noob if you don't have at least one of each.
Planning on posting questions or buying anything on this site? Put up your country (at minimum) on your profile. This is a worldwide forum and we haven't reached clairvoyance.
themelon   1 W
1 W
Post by themelon » Mar 15 2018 3:21pm
cal3thousand wrote:
Mar 15 2018 11:11am
themelon wrote:
Mar 08 2018 8:18am
Inwo wrote:
Mar 07 2018 11:38pm
themelon wrote:
Mar 07 2018 5:08pm
Full capacity.
I'll be replacing Lead Acid in allot of places so 6S and anywhere between 3P and 6P. Connecting, have not quite figured that one out yet but I have some ideas.
1.21 GW
Post by cal3thousand » Apr 11 2018 5:44pm
I would like to start using LTO in more applications in the future, based on what you've been sharing. Thanks for supplying these.
So to that end, I think I should start with a batch of these smaller pouches and see what I can make for fun and figure out how to build these things.
I'll take a dozen of these packs... PM sent
Inwo   10 kW
Post by Inwo » Apr 11 2018 6:16pm
Thanks, I'll see what I can do. They are available now. Can't make good on the price until I take delivery of 1,000 pieces.
coleasterling   100 W
Post by coleasterling » Apr 12 2018 5:01pm
So those at 3.5ah look much bigger than the 11ah ones? Any idea on the current capability? Hopefully super high? I have a bunch of the 11ah ones I've been wanting to use, but the current specs aren't high enough to make me use them over my LFP cells.
Inwo   10 kW
Post by Inwo » Apr 12 2018 5:30pm
No, they are unknown.
The 11ah are great. I tested a 2p6s to 350a.
11ah LTOsmall.jpg (205.43 KiB) Viewed 2517 times
coleasterling   100 W
Post by coleasterling » Apr 18 2018 10:55am
Any chance you could do some quick DCIR measurements on the 3.5's? I'd need far higher specific power than the 11ah's to warrant purchasing them.
Inwo   10 kW
Post by Inwo » Apr 18 2018 11:30am
Still don't have my hands on them.
Drop shipped some samples to a member. He may check in and report.
Had some a year ago from Kokam or Altairnano and was not impressed. I gave them away with another big order.
They seem near as heavy as the 11ah.
Once I do get them, price will reflect condition. Hope to get a report soon.
The warehouse will send 12pcs for $50.
Hope to do better when my pallet comes in, but it's a way to do some testing.
Inwo   10 kW
Post by Inwo » May 03 2018 10:02am
Mine were shipped to Florida warehouse by mistake.
Now there's a middle man.
PM me for info, but he is at $2 minimum. More for small orders.
Sorry for the trouble. It will only add to the cost if I have them shipped to Mn. :(
Survivor694   1 µW
Post by Survivor694 » Aug 09 2019 8:43am
Any of the 3.5 ah still available ?
