Finished project: Super Light Carbon Ebike
qwerkus   1 kW
Post by qwerkus » Apr 19 2018 1:34pm
Hello,
I finished my second Ebike Projekt (first was a TSDZ2 build) and wanted to share the results here hoping to inspire others. Special thanks to all forum members who helped me (Spinningmagnets, D8ve, Amberwolf, Fetcher...). Would have been much more difficult without.
First some impressions:
The base bicycle was already a top of the line 28" simplon full carbon ebike, so it was hard for me to mess this completely up. Motorization is achieved with the tiny Xiongda YTW-06 Motor, 48V, 350W Max and just 1.6Kg (measured). Controller is lishui, and the display is from topology, specially programmed to work with the lishui controller. There is an output for a throttle, but I don't really need it.
More on the battery later.
MadRhino   100 GW
Re: Finished project: Super Light Carbon Ebike
Post by MadRhino » Apr 19 2018 2:46pm
Very neat, and stealth.
Current bikes
Street: https://s20.postimg.org/ewrvugywt/Session_04_2015.jpg
Dirt: https://s20.postimg.org/lbqwr55ml/IMG_0157.jpg
zro-1   1 kW
Post by zro-1 » Apr 19 2018 7:02pm
Very nice build! That bottle battery looks great! I really like how you incorporated the Rosenberger magnetic connector into the top of the bottle. Very fancy! I love that little display you have. Can you share a link to where you got it from?
I'm also using a YTW-06 in my bike and have been pretty happy with it. I'm running mine at 48V 12A and haven't had any issues so far.
~01~
qwerkus   1 kW
Post by qwerkus » Apr 20 2018 1:28pm
zro-1 wrote:
Apr 19 2018 7:02pm
The display is from topology - not sure you can get it standalone. I put the kit together with the help of https://greenpedel.en.alibaba.com/
It has to be flashed to work with the lishui controller, but since I already did it once, maybe you can ask greepedel to ship you the same model.
neptronix   100 GW
Post by neptronix » Apr 24 2018 11:24pm
Sweet build, man!
Efficiency is everything :bolt:
Storyline   1 µW
Post by Storyline » Jun 27 2018 11:17am
Qwerkus - have just found this thread and wonder if you could post some info on the battery you used in this lightweight build.
Many thanks
Paul
qwerkus   1 kW
Post by qwerkus » Aug 30 2018 2:03pm
Storyline wrote:
Jun 27 2018 11:17am
Many thanks
Paul
Sorry for the late reply. The battery is home-brew. 80mm Aluminium bottle if found on the internet, and 13s2p cells inside. The trick is to cleanly cut ou a 2cm ring out of the upper part of the bottle, than cut through the ring, and use it a muff to join the top and the bottom part of the bottle. On side glued, the other bolted. Than I was lucky to find out that the ropd connector fits exactly into the bottle opening!
zro-1   1 kW
Post by zro-1 » Aug 30 2018 7:47pm
You fit 13s2p in that little bottle with a Rosenberger connector?! Are you using a BMS with it?
I currently have my 13s2p in a seat bag, which is fine, but if I could build a stealthy little bottle like you did (with a BMS) I'd be ordering parts right this second.
~01~
Hillhater   100 GW
Post by Hillhater » Aug 30 2018 8:07pm
What was the final weight of the completed bike ?
qwerkus   1 kW
Post by qwerkus » Dec 11 2018 2:15pm
Hillhater wrote:
Aug 30 2018 8:07pm
About 14Kg with fenders, light + dynamo and rack.
qwerkus   1 kW
Post by qwerkus » Dec 11 2018 2:16pm
zro-1 wrote:
Aug 30 2018 7:47pm
Sorry I didn't see this earlier. Yes, cheap chinese 13s15A Bms inside. Controller is factory set to 11A max anyway. this bottle is a perfect fit
Sgarufone   1 µW
Post by Sgarufone » Mar 26 2019 5:00am
Hello,
what type of controller and PAS has been provided with the kit? I've a display similar to yours and i'm struggling to make it working, and I'm also trying to use double hall PAS sensor without success...
d8veh   100 GW
Post by d8veh » Mar 26 2019 5:15pm
Double hall pedal sensors are usually handed. Take it off the bike and test it 4 ways: 2 ways of magnet disk orientation (flip) and 2 ways of rotation (clockwise and anticlockwise). Only one of the 4 possibilities will work. When you know which way, you know how to install it on the crank.
markz   100 GW
Post by markz » Mar 26 2019 7:28pm
As usual you are correct MadRhino, but its too "clean" and glistening, too much eye candy and curb appeal. Too many eyes will be looking its way.
Fugly bicycles are an anti-theft mechanism.
MadRhino wrote:
Apr 19 2018 2:46pm
MadRhino   100 GW
Post by MadRhino » Mar 27 2019 8:39am
markz wrote:
Mar 26 2019 7:28pm
MadRhino wrote:
Apr 19 2018 2:46pm
The opposite is also true.
I mean, hard to steal a bike when there is always some people gathered around to look at it. :twisted:
Current bikes
markz   100 GW
Post by markz » Mar 27 2019 12:02pm
As usual you make good statements.
MadRhino wrote:
Mar 27 2019 8:39am
neptronix   100 GW
Post by neptronix » Mar 27 2019 1:12pm
How is the xiongda YTW-06 holding up?
John in CR   100 GW
Post by John in CR » Mar 29 2019 11:45pm
MadRhino wrote:
Mar 27 2019 8:39am
markz wrote:
Mar 26 2019 7:28pm
MadRhino wrote:
Apr 19 2018 2:46pm
Ebike thieves should be treated the same as horse thieves 150yrs ago. The scum better be prepared to pay the ultimate price if they try to take any of mine.
Great job on the ebike Qwerkus! I hope you get a lot of mileage with it.
MadRhino   100 GW
Post by MadRhino » Mar 30 2019 9:14am
John in CR wrote:
Mar 29 2019 11:45pm
Ebike thieves should be treated the same as horse thieves 150yrs ago...
I don’t remember. I am only half that old. :D
Was it the era of tarring and feathering, or just hanging ?
It is easy to train a horse to eject any unknown rider. My street bike is somewatts like that. :wink:
Here we have had a real problem with bike thieves. We got rid of them with bait bikes. One summer was enough for all of them to know this neighborhood is a freaking dangerous place to steal a bike. :mrgreen:
Current bikes
markz   100 GW
Post by markz » Mar 30 2019 12:16pm
SNC Lavalin to be precise :wink:
MadRhino wrote:
Mar 30 2019 9:14am
Here we have had a real problem with thieves.
MadRhino   100 GW
Post by MadRhino » Mar 30 2019 3:22pm
markz wrote:
Mar 30 2019 12:16pm
MadRhino wrote:
Mar 30 2019 9:14am
The administrators of SNC-LAVALIN were worse than thieves. A bunch of crooks that deserve to be condemned for organized crime. One got a gift of 2 years home detention, another one got away because of ‘Jordan decision’, a middle man is serving the only serious detention... in Switzerland. All the other administrators so far, are free.
Current bikes
markz   100 GW
Post by markz » Mar 30 2019 7:30pm
There seems to be a lot of mob ties in QC compared to other provinces. Maybe its just cuz it comes out more so over there, and is hidden everywhere else. Wont think too much into it tho.
MadRhino   100 GW
Post by MadRhino » Mar 31 2019 12:20am
markz wrote:
Mar 30 2019 7:30pm
The 3 bigger urban areas in Canada are infested with white collar crime related to politics and business. They are not different than any other big cities in the world. The more they make the news, is an indicator of how hard we fight them.
Current bikes
oops   1 µW
Post by oops » May 17 2019 1:59am
any new input on the ytw-06 rear hub noise level and drag resistance?
