New "Lingbei MM28.250 torque sensor mid drive"
csbike   100 mW
Re: New "Lingbei MM28.250 torque sensor mid drive"
Post by csbike » Apr 10 2019 3:57pm
hi all,
I was ready to order a Bafang BBS01b and I discovered this MM28.250. I found it at an Italian online reseller that has apparently customized it so that it yields 100Nm of torque. Is this worth spending 100E more than for the BBS01b?
Otherwise, where did you guys buy it from? For what price?
Thanks
csbike
edkin   1 µW
Post by edkin » Apr 11 2019 1:18am
From what I've read, the LingBei is a clone of the Bafang due to some Engineers creating their own company and emulating the Bafang design.
The attraction with the LingBei is that it incorporates a Torque Sensor that gives a much more intuitive cycling experience over the "Throttle only" Bafang.
Unfortunately they were having some issues with the software controlling the Lingbei. This was back in May last year so maybe they have sorted out the developmental issues. It might be worth inquiring about. Because this motor looks to be just as good (if not better) than the Bafang and the TDZ motor
csbike   100 mW
Post by csbike » Apr 11 2019 5:25am
thank you for your reply.
what kind of issues did they have with the software?
Is it possible to reprogram the software without taking the unit apart?
maitilupas   100 W
Post by maitilupas » Apr 11 2019 5:36am
The programing for pas is not well configured it gives you allot of power in all pas even on 1 i also would like to change the configuration none yet here knows how only thing i red was lingbei has a special cable and that only they do the programing.
edkin   1 µW
Post by edkin » Apr 11 2019 5:43am
csbike wrote:
Apr 11 2019 5:25am
Take time to read this thread from the first post and you'll pick up what the problems were/are
csbike   100 mW
Post by csbike » Apr 12 2019 11:42am
Hi
I have gone through this post, and I have contacted LingBei.
This post says at different places that there seems to be a cable:
Lingbei do say these motors are programmable through the green 5-pin display plug just like the Bafangs (no surprises there, then). I have a 2 minute video from Linda at Lingbei showing how to connect via a special box and start the “TREEDE” software.
According to Ling Bei, there is only one version -- it has 9 MOSFETs. The latest revision of the motor includes a connection for a programming cable (sold separately) and the ability to handle 52V with a maximum of 750W. I don't know if they've changed the
grease, but they are very responsive to emails, so you can ask them yourself.
Lingbei told me first that I can reprogram it myself with the cable and the software which requires W10. But that they do not recommend it as reprogramming several times may damage the motor.
When I asked why it would damage the motor she said that it's like a CD that you cannot rewrite multiple times, so I think she was referring to the fact that the flash memory in the motor can only be written a limited number of times.
I then asked her where I can get the software and she told me that they do not distribute the software and neither do they sell the cable.
They also added that this is because people have encountered issues while reprogramming.
Has anyone on this forum been able to get their hands on the software and on the cable? How? Did you succeed or did you brick the motor?
thanks
eyebyesickle   10 kW
Post by eyebyesickle » Apr 12 2019 4:40pm
I have the cable and can show you the pinout - what version do you have? The newer versions can be programmed through the display port - older versions require opening the motor...
I'll dig up the info this weekend if I have time...
We have had limited success with improving the torque function on this motor, and it having a bit more power than the TSDZ2 is nice....
csbike   100 mW
Post by csbike » Apr 12 2019 5:06pm
Thank you for your reply!
I do not yet have one. I am considering ordering one, after discovering this post, and I am doing some research before committing.
Where did you get the cable? From Leng Bei? What do you use in terms of software? and where did you get it?
Also what do you think about the statement that "reprogramming the motor several times can cause problems"?
Is it because of limited number of write cycles in the flash memory?
Finally, why limited success? Is there an open-source project I can have a look at?
thanks ;)
casainho   10 GW
Post by casainho » Apr 13 2019 5:07am
eyebyesickle wrote:
Apr 12 2019 4:40pm
I still do not understand how this motor can provide more power than TSDZ2 if it pull the same amount of power from battery: same amount of current amps and voltage.
- TSDZ2 OpenSource firmware
maitilupas   100 W
Post by maitilupas » Apr 13 2019 7:36am
casainho wrote:
Apr 13 2019 5:07am
eyebyesickle wrote:
Apr 12 2019 4:40pm
maybe has more torque and less speed , maybe windings are in star and tdz is delta?
also size of copper etc makes differences
eyebyesickle   10 kW
Post by eyebyesickle » Apr 13 2019 8:51am
casainho wrote:
Apr 13 2019 5:07am
eyebyesickle wrote:
Apr 12 2019 4:40pm
More current...(amps) Why do you say same current amps/voltage?
casainho   10 GW
Post by casainho » Apr 13 2019 8:55am
eyebyesickle wrote:
Apr 13 2019 8:51am
casainho wrote:
Apr 13 2019 5:07am
eyebyesickle wrote:
Apr 12 2019 4:40pm
Because that what was I did remember. So, what is the max amps that is possible to use?
eyebyesickle   10 kW
Post by eyebyesickle » Apr 13 2019 8:56am
Not sure, have not pushed to the limit since the controller upgrade... We are at over 20 reliably so far though...(at 52-58.8v)
casainho   10 GW
Post by casainho » Apr 13 2019 8:59am
eyebyesickle wrote:
Apr 13 2019 8:56am
Hmm, and there is any motor temperature protection?? Or that 20 amps without motor getting the limit temperature??
eyebyesickle   10 kW
Post by eyebyesickle » Apr 13 2019 9:03am
casainho wrote:
Apr 13 2019 8:59am
eyebyesickle wrote:
Apr 13 2019 8:56am
20 amps reliably... Not overheating to the point of damage... There is not motor temp protection that I am aware of
casainho   10 GW
Post by casainho » Apr 13 2019 9:13am
eyebyesickle wrote:
Apr 13 2019 9:03am
Hmmm, how do you know that is not overheating to point of damage? And for how long did you tested at 20 amps??
I am asking all this questions because I would like to know real differences from TSDZ2 and not what is written on specifications.
eyebyesickle   10 kW
Post by eyebyesickle » Apr 13 2019 11:59am
casainho wrote:
Apr 13 2019 9:13am
eyebyesickle wrote:
Apr 13 2019 9:03am
Same performance through same terrain with same WH consumption... As well as monitoring it closely myself, by hand, heat gun, and temporarily a cheap remote thermosensor...
I think I went over what the motor can take more earlier in the thread. If you are interested in working on this motor, I would be happy to discuss more, but it did not seem you were interested in this motor much when we were previously discussing it...
casainho   10 GW
Post by casainho » Apr 13 2019 12:12pm
eyebyesickle wrote:
Apr 13 2019 11:59am
casainho wrote:
Apr 13 2019 9:13am
eyebyesickle wrote:
Apr 13 2019 9:03am
Now that TSDZ2 firmware is mostly stable, I am curious about others and maybe the big different over TSDZ2 can be a motor more powerful (??). I still don't know by how much this motor is more powerful. TSDZ2, I consider it an deliver 10 amps continuously and 18 amps for peaks of some minutes. I would like to know this values for this motor.
But after months, still there is no repair part on sale for this motor, making it not attractive to me, compared to TSDZ2 that I think it is ideal because not like any other motor, like the famous Bafang that repair parts are like 6x higher price than on TSDZ2.
casainho   10 GW
Post by casainho » Apr 13 2019 12:16pm
New motor on sale - is this a TongSheng, Lingbei or Bafang, etc??
casainho wrote:
Apr 13 2019 9:25am
TSDZ2 / TongSheng new motor version??
I just saw on PSWPower site, it is on category of TSDZ2 but has a different name... what you guys know / think??
See here: http://www.pswpower.com/ven.php?cargo.2019-3p-953s
maitilupas   100 W
Post by maitilupas » Apr 13 2019 12:58pm
thanks for sharing this , i came up with this link from their attachments:
https://www.youtube.com/watch?v=SY4kYHtl-AY
i can try this on the lingbei , might work fine.
atomohodez   1 mW
Post by atomohodez » Apr 13 2019 2:11pm
casainho wrote:
Apr 13 2019 12:16pm
casainho wrote:
Apr 13 2019 9:25am
Aikema motor pas sensor
https://www.aikema.com.cn/en/product/MD-P250-02.html
With a torque sensor, shengyi will have a motor CMT-06
http://www.syimotor.com/productDe_91.html
https://www.youtube.com/watch?v=NDNMb1dq270
eyebyesickle   10 kW
Post by eyebyesickle » Apr 15 2019 10:26pm
After all that yapping I was doing... it seems someone burned up a unit @ 52v20amps... I have not confirmed overheat, etc yet - but its a good bet. They were on a recumbent... I am thinking the thing about this motor is unlike the TSDZ2 where you really have to work for the full current, at which point you are adding with it and usually spinning the motor to where it doesnt burn up as quick.... the MM28/Lingbei can be mashed/throttled for full power output... so it is easier to burn if you have the current set high
:bolt: :warn: :flame: :(
dodjob   1 kW
Post by dodjob » Apr 23 2019 2:19am
I use the lingbei a lot.
They are "flashable" not "programmable". Which means you can get different factory firmware to be flashed.
From my experience, they have way too much consumption in the first assist levels. That sucks real hard for clients having small (500wh) batteries.
Added to this, the gauge is out of the place, showing 20% remaining battery at 47,8V. And fluctuating with load like a cheap Bafang from the 90s (specially on the "new" display)
Both together create a load of problem if you resell the kit, because client makes 10-15km and "see" that he has 20% remaining... This in 1assist.lvl. , eco mode.. 🙈
The torque sensing is very weak (not like a tsdz)
First motor generation have problems with shaft sealing popping out (on the non drive side)
Other than this, the motor is very torquy, quite silent and very compact. The new display are beautiful.
Hope this helps :)
Gruß,
H.
Felt beer-cruiser MAC 8T lifepo4 36V12AH 12FETS4110 http://www.bavarian-ebikes.com
zoki   10 µW
10 µW
Post by zoki » Jun 03 2019 1:57pm
Hello,
I am looking to install mid-drive that will fit on my full suspension bike. I have roughly 60 mm from bottom bracket center to beginning of the chainstay swing arm. Can I mount the Lingbei MM28 or the TSDZ2 engine on my bike?
Thanks in advance
Metaller   10 µW
10 µW
Post by Metaller » Jun 13 2019 4:53pm
I welcome all.
A few days ago I have assembled e-bike on the basis of Lingbei MM28. During the test trip it was found out that the engine gives power breakthroughs. In more detailed analysis of behavior of the engine during the trip around the cross-country terrain in various modes I have come in conclusion that the torque sensor in my engine works on the contrary, i.e. at rotation of pedals without effort the engine gives the maximum power, and at power pedalling the engine is completely switched-off. I believe something will shift one of sensor magnets, or sensors exits are connected in wrong sequence, or it is some mistake in programming of the engine. How can i correct operation of my engine...and if it is possible, without its full disassembling?
to zoki: the engine has no parts behind bottom bracket. https://yadi.sk/i/rIXhmFxDEMCApQ
