Ebike Conversion - which motor
trex-bike   1 µW
Post by trex-bike » May 17 2018 11:08pm
I've had a of Soma DC Doublecross Disc bike for about 6 years. Its a great but I need a little help on the hills these days.
Im trying to decide between a Bafang BBS02 and a BBSHD motor and would appreciate any advice on this.
For my commuting I ride 14 miles RT and I probably have around 300-400 ft of elevation gain with a grade of maybe 3-4%. I'm 61 years old and weigh 195 pounds.
I am thinking the the BBSHD might be better a) at stop and go initial acceleration b) keeping up with downtown traffic at 25mph and c) more robust. But my concerns are a) is that it might be too much of a good thing and b) it is heavier c) extra torque would somehow be damaging to my bike. My bike frame is made with Tange Prestige heat-treated CrMo steel.
Thats pretty much it and I appreciate your help.
ScooterMan101   1 MW
Re: Ebike Conversion - which motor
Post by ScooterMan101 » May 18 2018 9:53am
I want a mid-drive as well, ... However I will be going up much steeper grades and want to to higher altitude gains,
For the ride you are describing even a small simple hub motor will work just fine . ... viewtopic.php?f=3&t=93180
There are other hub motors sold by many vendors, for your ride any rear hub motor that is between 6-10 pounds will work just fine.
For instance my Mac motor that is a fast wind ( 6t ) does your kind of ride well. it weighs 9.5 pounds, the cassette version weighs a small amount more but a cassette weighs less than a freewheel so it evens out.
But for even lighter weight a motor that is in the Q128 weight range will work for you. 750 watts is all you need for that ride. the Experts in DIY e-bikes say that 80 % of people are better off with a hub motor.
But if you are stuck on getting a Befang mid drive, the BBS02 is all and even more than you need for the ride you describe .
trex-bike wrote:
May 17 2018 11:08pm
My first conversion ... Sold
viewtopic.php?f=3&t=71378&p=1077497&hil ... 1#p1077497
It's 2018 already, ( now 2019 ) lets get some real , improved e-bike / e-velomobile / e-motorcycle designs .
John and Cecil   1 kW
Post by John and Cecil » May 18 2018 10:11am
You might also consider the tsdz2 750w mid drive. It is a little cheaper and a little lighter than the bafang (and less power than bbs02) but it has a torque sensor and not just a move the pedals sensor.
Marin   1 kW
Post by Marin » May 18 2018 11:17am
trex-bike wrote:
May 17 2018 11:08pm
For your stated use the bbs02 will be fine and plenty of power with a good battery. The key to less wear on the machinery is to use your gears effectivly and smoothly. Always start off in lower gears to reduce stress.
Marin ex-rental hybrid with 48v bionx...sold
Specialized hardrock with magic pie 4-5
Lunacycle with l/r mid drive coming soon
Kona Caldera with QS 30H (maybe), and phase runner
Giant Yukon bbs02
Kona Abra Cadabra bbshd
Wildfire fat bike bbshd
trex-bike   1 µW
Post by trex-bike » May 20 2018 10:08am
Thanks for all of your helpful advice. I'll look into the hub motor a bit. There is a guy in Portland that does conversions. He let me try his bike and he had the tsdz2 750w mid drive but I found it a little too low in power for me.
