Will these battery specs power a BBSHD?
doubledipsoon   100 W
Post by doubledipsoon » May 22 2018 10:06am
Model UPP-S003-2
Nominal Voltage 48V
Rated Capicaty 13Ah
Size 110*360 mm
Battery Cell Samsung26F
Peak current 70A
Charge voltage 54.6V
Charger 54.6V 2A
Max Constant Discharge Current 25A
Discharge cut off voltage 39V
Battery Weight 4.3Kg
Warranty 12 months
Place of Origin Shenzhen, Guangdong, China
Marin   1 kW
Re: Will these battery specs power a BBSHD?
Post by Marin » May 22 2018 10:43am
doubledipsoon wrote:
May 22 2018 10:06am
Model UPP-S003-2
Nominal Voltage 48V
Rated Capicaty 13Ah
Size 110*360 mm
Peak current 70A
Charger 54.6V 2A
Max Constant Discharge Current 25A ****this probably too low need min 30 amp*****
Warranty 12 months
see note above
Marin ex-rental hybrid with 48v bionx...sold
Specialized hardrock with magic pie 4-5
Lunacycle with l/r mid drive coming soon
Kona Caldera with QS 30H (maybe), and phase runner
Giant Yukon bbs02
Kona Abra Cadabra bbshd
Wildfire fat bike bbshd
WoodlandHills   10 kW
Post by WoodlandHills » May 22 2018 12:58pm
It's not too low to power a BBSHD, but you won't be putting enough watts through it to justify the extra expense and weight over a BBS02 unless this is to be a rental bike that will get constant abuse. However, if you are planning on upgrading to a higher voltage battery at a later date and want a motor with an ability to grow with the battery, then get the BBSHD as you can run up to 72v through them with an external controller.
If you already have an HD, then I would get a battery with the volts and continuous amps to get the power you have paid for with the motor. 52v and 30a continuous is what you should be looking for to pair with a BBSHD and the stock Bafang internal controller.
doubledipsoon   100 W
Post by doubledipsoon » May 22 2018 6:13pm
Marin/Woodlanhills, yes, that "25 amp continuous" was the only unfavorable spec on this battery, since the BBSHD limits at 30 amps.......My predicament is that I bought a 48v 13.5Ah Lithium Bottle battery from Luna last year, and I want to buy another. However, they no longer carry this specific Bottle battery. It looks exactly like the Aliexpress 48v 13Ah (not 13.5) that only has 25 amps continuous....Anyway, if anyone knows a source for this bottle battery with a 30 amp continuous rating, give me a buzz. Thanks, Luna!
