52V bms
Monti   10 µW
10 µW
52V bms
Post by Monti » Jun 27 2018 8:56pm
Hi All
I need to change my bms but want it to be a seamless change so need the balance connector to be the same and ideally the whole board
Its 60x80mm and the balance connector is about 35 mm. Photos attached
Any idea where I can get the same or a compatible one. It is in my 52v shark pack 17.5amphours bought from lunacycle
Thanks for any help
x.l.r.8   100 W
Re: 52V bms
Post by x.l.r.8 » Jul 13 2018 11:21am
your best bet is (choose the shortest delivery time from China here) and just make sure you do not undersize it otherwise it will cut out going up hills) trust me I thought matching to my controller was smart at one time, much better to match the output potential of your pack. The problem is the wait time
Intelligence is distributed nearly evenly, with only the occasional concentration in one person. The total quantity of Intelligence is a constant: as more people come into being, fewer and fewer get a sufficient amount for themselves.
Some say this has already reached homeopathic levels.
