150mm X 15mm Thru with 36h Drilling
jktobin1   1 mW
Post by jktobin1 » Jul 16 2018 9:49am
Hey guys I'm looking for advice to try and solve my hub situation. I'm making a dirt bike style electric bike so I will not have a freewheel in the rear. I plan to have it be a direct drive system. After doing some research and seeing what others are doing I plan to use a front bike hub and mount my sprocket to the 6 bolt rotor mount. However, I am in need of a 150mm wide hub that will support a 15mm through axle and have 36 spoke holes. I don't believe this exists based on the last couple hours of research. The rim I plan to use is a the Yamaha play bike rim http://www.prowheelracing.com/yamaha-pl ... -19-black/. I have seen this used in the past but I can't seem to find any threads with someone doing the same thing. Does anyone know if this is something that I can purchase and just cant find? Or should I start looking at custom machining one? Any and all help is greatly appreciated.
MadRhino   100 GW
Re: 150mm X 15mm Thru with 36h Drilling
Post by MadRhino » Jul 16 2018 12:01pm
Onyx Racing fat bike hub, should fit your requirements.
Current bikes
Street:
Dirt:
Santa Cruz V10. 50mph
ScooterMan101   10 MW
Post by ScooterMan101 » Jul 16 2018 12:31pm
The Rear of your bicycle has 150 mm wide spacing with a axle of 15 mm ?
Most Bicycles I have seen have 12 mm axles , and they are 142/143 , 148, and 177 mm spacing .
Interested in seeing what frame you have , looks like a good project for loose dirt and sandy areas.
My first conversion ... Sold
viewtopic.php?f=3&t=71378&p=1077497&hil ... 1#p1077497
It's 2018 already, ( now 2019 ) lets get some real , improved e-bike / e-velomobile / e-motorcycle designs .
jktobin1   1 mW
Post by jktobin1 » Jul 16 2018 12:59pm
The Onyx hub is perfect! Thank you! I am building a custom bike from the ground up but I bought the swingarm from vector ebike to make things a little easier for me. After receiving the swingarm and taking measurements it looks like I need a 150mmx15mm hub. I thought it sounded a little weird at first too but I am going to be sending a lot of power through it so the bigger size will be beneficial.
ScooterMan101   10 MW
Post by ScooterMan101 » Jul 16 2018 3:54pm
I thought that you were talking about a Thru-Axle bike.
Vector E-Bike rear swing arms are slotted only ?
or do they now have a thru-axle design like this for the rear swing arm ... https://www.dtswiss.com/en/products/hubs-rws/rws/15-mm/
or for a Rear hub 12 mm version ...https://www.jensonusa.com/DT-Swiss-RWS- ... gII4_D_BwE
I Would like to see more e-bike frames with the rear thru-axle so called now dropouts , for people wanting to use a mid-drive.
