Bafang BBSHD Hallsensor Error 08 "fixed", now controller problems?
Föppel   100 W
Post by Föppel » Sep 22 2018 3:28pm
Hey Folks, i can need some help with my Bafang BBSHD problem(s).
After i replaced the Nylon Gear in the motor (peanutbutter), i put the Motor back together, and had a Hallsensor Error-code (08).
Motor did move the Chainwheel 1cm, than stopped, display showed Error code 08, peeping noise came from the controller while pulling the throttle.
after this, i opened the Motor again, hallsensors looked nice, also the the soldering on the
Hallsensor-Board (both, from the Sensors and the white JST-Connector) looked not that bad, but i resoldered them, to get sure. put everything back together, and the Sensor-Error 08 does not show again since this procedure. But the motor does not move, and still making this trange peep-Noise from the controller when pulling the throttle.
i also tryed to unplug just the black JST-Connector from the controller (it was a tip i found, if you have the 08 Error...)
...oh, and i checked every connection multiple times... not sure what to try next. Anyone a good idea?
Riding dirty since 1684
Fotos and Videos here : http://endless-sphere.com/forums/viewto ... =6&t=68182
Small-block Kits on 3000W+ here : https://endless-sphere.com/forums/viewt ... 28&t=78861
Föppel   100 W
Re: Bafang BBSHD Hallsensor Error 08 "fixed", now controller problems?
Post by Föppel » Sep 28 2018 10:28am
the Hallsensor-Error is back.
I guess, the motor have to turn a little bit to detect the Error.
Last time when i was thinking i fixed it by resoldering the Hallsensor-Board, the motor was in a position wherer it doesnt move.
I turn the chainwheel backwards, to move all the gears inside to get the motor in a other position, and when i pulled the throttle, it moved 1cm, stopped and showed Error 08 again.
Does anyone know where to get a new Hallsensor-Board from? Would be nice to just swap out the whole thing and run it again.
My other option is to try to find the broken Sensor, and replace it. but not sure if my soldering skills are that good.
Föppel   100 W
Post by Föppel » Sep 28 2018 10:44am
this was the first Problem, thats fixed by now...
the Hallsensorboard after resoldering
Hallsensorboard installed, sensors pointing downwards. the soldering of the right Hallsensor dont look that nice, will check this again, and try to replace the Hallsensors with some i have ordered some years ago with my first BMC-Hubmotor. They look allmost the same and would fit in the motor, but have different Numbers printed on.
Föppel   100 W
Post by Föppel » Sep 28 2018 10:53am
The Replacement-Sensors are labeled
S41
121
The Originals are
B5030
65T
not 100% sure about those numbers, cant see it exactly, they are tiny...
You guys think that will work?
fechter   100 GW
Post by fechter » Sep 28 2018 12:17pm
SS41 hall sensor should work fine for that.
Err 08 indicates an invalid hall combination. You need to power the hall board and measure each signal line while moving the rotor to see if each signal is toggling between high and low.
Any chance the new halls were installed backward? I've never pulled the hall board off on one to look at it.
Föppel   100 W
Post by Föppel » Sep 28 2018 12:50pm
Thanks for the info fechter, i will try to find the broken one and replace it.
I dont think that the Halls were installed backwards, i didnt replaced them yet, just resoldered the joints.
Cheerio
Föppel   100 W
Post by Föppel » Sep 30 2018 7:58am
OK, found that bastard and removed him from the Board
Installed a new one... here on the foto the legs are naked, but i did some silicone on them when i installed it (no foto made at this time)
checked it, and everything workes
Testriding, after 1 Km i had a H8 Error again... (while pedaling at 20 km/h )
so i took the motor apart again, to check the Halls... again
oh, and i stripped the alloy-windings on this pedal... so 3 leg puller-Time
... i checked the Sensors again, and they all work fine.. i cleaned it with alcohol and put some silicon on the solderjoints on the backside to protect them (...?)
thats strange, the sensors are working nice, and for the 1 Km i testrided the Bike, it workd like new.
i will put anything back together and try again. dont know what to try next. anyone a idea?
Thanks, Föppel
Föppel   100 W
Post by Föppel » Oct 10 2018 10:20am
Little update; problem not solved yet.
When i put everything apart and measure the halls, they are ok.
then i reassemble the Motor, and the bike runs for about 10min like its new.
after some time the motor beginns to stotter and shows error 08 again.
i tried to unplug the PAS-wires as well (again). this was recommendet as an easy fix if you have a throttle, but it doesnt effect the behavier on my motor.
Now im waiting for a new "Hallsensor-Board" from em3, hope that will fix my motor, if so, i still wouldnt know exactly why, but i think its the best chance i have.
thanks fechter for your tips, and also em3 for the good customer support. I try to solve the problem by myself, but at this point im just not electrician enough
fechter   100 GW
Post by fechter » Oct 13 2018 2:17pm
There isn’t much to go wrong with the hall board but it is easy to replace. If you still have the same problem after that, the controller board is about the only thing left.
Föppel   100 W
Post by Föppel » Nov 02 2018 12:51pm
Thanks fechter, problem solved.
I got a new "motor-core" from Em3 with the Hall-Board included.
Also thanks to Em3!..
