Sanyo 25Ah nmc Voltage Drop
Pota   100 W
Re: Sanyo 25Ah nmc Voltage Drop
Post by Pota » Nov 08 2018 3:19pm
Okay, ill try explain it, thanks alot btw :D
First off, we have the same motor. Prestolite MTY4001 36v stock.
Just look at these two videos
https://www.youtube.com/watch?v=BGwtqgN_7no
https://www.youtube.com/watch?v=KObUDN7pMcE
the first is with EXTREMLY grippy wide tires.
the second is with normal gokart tires.
he is running 1.16:1
Same setup in both videos, only different tires. He is running 110v 500amp open revolt controller. In other words, yes more volt than mine, ive tested 84v, but again. today i tested 48v, and the burnout WITHOUT me in the cart is the same, just less high rpm wheel spin. (spun the tires at 480amp+ with the test yesterday @ 84v and today @48v, so seems the volt doesent make any different in when it starts to spin, both at 480amp+)
I did a test today with 48v. Pushing it against the wall, i wasent in the cart, so it only had around 60-70kg load at the back tires (motor and frame). Still same gear ratio 1:1. I added a clamp meter to be sure that the data from the controller wasent wrong, and yes, they was correct, i peaked 662amp @ 48v.
It started to spin the wheels at around 480amp+.
With me in the cart it would NEVER do any kind of burnout, and the wheels wouldent spin.
The motor is wired in this way
Plus to S-1
S-2 to A-1
Ground to A-2
Brush picture. I got 8 of these.
neptronix   100 GW
Post by neptronix » Nov 08 2018 3:51pm
Punx0r wrote:
Nov 08 2018 11:55am
If motor is the same and motor current is the same (or better) then your motor torque will be the same (or better) regardless of battery voltage. If gearing is the same (or lower) then axle torque will be the same (or better).
Unfortunately not the case with BLDC motors. You will see a jump in torque with voltage because the total wattage converted back down to phase amperage can be much higher.
You can even check this on the ebikes.ca motor simulator. Take this link and change the battery to the 66v dewalt battery. You'll see a ~20% boost in torque.
https://www.ebikes.ca/tools/simulator.h ... t=B3623_GA
But we need motor speed to make burnouts, which comes mostly from voltage, not amperage in this case. OP does not have the same motor speed because of a combination of huge battery sag and lower battery voltage to begin with.
Efficiency is everything :bolt:
My first major build: 8T MAC motor on a Trek 4500.
The new all-arounder: Leafmotor 1500w on a Turner O2 full suspension.
The monster scooter: ? on a Cannondale Semi Recumbent.
Pota   100 W
Post by Pota » Nov 08 2018 4:22pm
Btw. This is brushed to brushless.
999zip999   100 GW
Post by 999zip999 » Nov 08 2018 5:56pm
3p...
Punx0r   100 GW
Post by Punx0r » Nov 08 2018 6:05pm
Wow, that's some torque he has! :shock:
Neptronix, I think this the motor both karts have:
http://vi.vipr.ebaydesc.com/ws/eBayISAP ... cureDesc=0
AFAIK on anything brushed, motor current = battery current. The controller simply chops the supply with PWM to deliver reduced voltage & current to the motor.
I'm running out of guesses and my knowledge of non-PM DC motors is pretty thin, but since this motor has separate connections for field and armature and I'm not sure what systems both your controllers use, are you sure both motors are connected in the same configuration RE: series/sepex/compound? I'm wondering if maybe he's accidentally or deliberately miss-wired his motor and is putting way more current through the field winding than intended?
Pota wrote:
Nov 06 2018 7:57pm
This guy is running about 100v. 1:1 gear ratio and 500amp controller. He does INSANE burnout.
Im having 600amp, and have been running 82v. with 1:2 gear ratio. 1 on motor and 2 on axle. But im NOWHERE near that kind of burnout.
Probably a silly question, but just to check when you say "1 on motor, 2 on axle" I assume that's twice the number of teeth on the axle sprocket and not 1 revolution on motor = 2 revolutions on axle? I.e. your motor is geared DOWN not UP. I appreciate you said you also tested it at 1:1 and there's not much room for confusion there...
Punx0r   100 GW
Post by Punx0r » Nov 08 2018 6:17pm
999zip999 wrote:
Nov 08 2018 5:56pm
3p...
The OP is delivering 600A to his motor on a 1P VW e-up pack
The other guy is delivering 500A to his identical motor from (according to Youtube comments) a Leaf & VW pack
600A @ 1P on the e-up cells is 24C which is leaning pretty hard on them but what is the other guy's pack like? I can't tell from image of the battery at the end of the video if it's 1P or 2P. Either way, Leaf cells are good for, what, 10C?
Pota   100 W
Post by Pota » Nov 08 2018 6:21pm
Punx0r wrote:
Nov 08 2018 6:05pm
Pota wrote:
Nov 06 2018 7:57pm
Correct. THATS the motor i have, i bought from that guy, but a newer one :)
Yes, thats what ive been thinking aswell, maybe the wiring is different. I think ive done it right, but there may be another way to increase the torque alot.
Correct, example. 18teeth on motor, 36 on the axle :)
I mean, it wont help me with the amp going from 1p to 2p. Because 1p already gives me 662amp at peak :) And you know, it actualy is around 600amp for maybe 5sec!
eee291   10 kW
Post by eee291 » Nov 08 2018 6:28pm
Do you have the same sized tires as that guy?
Pota   100 W
Post by Pota » Nov 08 2018 6:35pm
eee291 wrote:
Nov 08 2018 6:28pm
Yes, but thats not the problem, even with car tires. I have WAAAAAAYYYY lower torque. There are other things that make mine alot weaker.
neptronix   100 GW
Post by neptronix » Nov 08 2018 7:22pm
Punx0r wrote:
Nov 08 2018 6:05pm
He said it was brushed to brushless..
Anyway, wheel RPM data from both karts is missing and i suggested speed is the main factor here.
As i demonstrate here, wheel speed makes smoke, and all you need is enough torque to start the reaction..
Crystalyte 3548 ( fastest winding available ) spinning at ~950rpm on a very soft tire.
See how much smoke i made in just a few seconds from all that friction? it's the wheel speed that causes the tire to get hot enough to vaporize.
Pota   100 W
Post by Pota » Nov 09 2018 2:23am
Mine make INSANE smoke at 84v With noone in the gokart. But With me sitting in it, its a different story, it wont spin.
Punx0r   100 GW
Post by Punx0r » Nov 09 2018 3:31am
There's definitely something weird going on as it looks like an apples-to-apples comparison between your karts but he is clearly making way more torque at the axle than you despite you have a bit more motor current and shorter gearing :?
It would be great if one of the guys knowledgeable on non-PM brushed motors could comment.
Pota   100 W
Post by Pota » Nov 09 2018 3:56am
Some say it may be my brushes advancement. @ DIYElectricCar they say im loosing 80% torque if its 30% Advanced.
redline2097   100 W
Post by redline2097 » Nov 09 2018 4:51am
Whats the total weight of Kart + You?
Pota   100 W
Post by Pota » Nov 09 2018 6:04am
150-200kg
Joachim   1 kW
Post by Joachim » Nov 09 2018 2:50pm
try 18S 2p :lowbatt:
Punx0r   100 GW
Post by Punx0r » Nov 12 2018 8:27am
Pota wrote:
Nov 09 2018 3:56am
I was going to suggest the DIYElectricCar forum as those guys are much more experienced with large brushed motors.
Looking at the news photos above I'd guess your motor is wired in a series configuration. I was thinking if it was intended to be shunt or sepex this might restrict power by placing a relatively high-resistance field winding in series with the armature, but your measurements show this isn't the case. As with the suggestions of increasing the battery to 2P or 3P, your motor is drawing plenty of current, it's just not using it to make torque like the other guy's is. Presumably it's wasting it as heat instead, so maybe you're onto something with the brush timing. Maybe someone monkeyed around with the motor before it got into your hands?
Pota   100 W
Post by Pota » Nov 13 2018 1:42pm
Punx0r wrote:
Nov 12 2018 8:27am
Pota wrote:
Nov 09 2018 3:56am
True, but no, the brush timing was good.
But i havent tried reversing the motor.
