Is it possible to upgrade the internal controller of MP2?
Encebras   1 µW
Post by Encebras » Jan 04 2019 6:35am
Happy New Year everyone!
This may be a silly question, but I cannot find the answer elsewhere:
I am currently using a Magic Pie 4, and I am completely in awe of how well it works. My daily commute is pure joy, even now in the winter time with 4 feet of snow. But, I would like to upgrade to the Vector 5 controller with bluetooth capabilities. This should be no problem, but I have an older MP2 that I would also like to upgrade. Would it be possible to fit my internal MP4 controller to an MP2? Or are the magnets/windings not compatible? Thanks a lot for any advice. Erik
TommyCat   1 kW
Re: Is it possible to upgrade the internal controller of MP2?
Post by TommyCat » Jan 04 2019 10:30am
Hi Eric,
Just a reminder on the MP4 to MP5 upgrade to check the motor wiring connections as there where 2 types on the MP4. And as such you may need the wiring upgrade...
As far as the MP2 motor and MP4 controller, I don't think there's a spot for it around the axle, unless your talking about externally? Which would be doable but would require a cooling solution.
But the ultimate authorities and ones I would check with would be Gary, with Golden Motors Canada.
https://www.goldenmotor.ca/
And Alan (AKA Bikemad) on the Golden Motor Forums...
https://goldenmotor.com/SMF/index.php
Regards,
T.C.
See my completed Magic Pie V5 rear hub E-Bike build Here!
