AliExpress battery pack unboxing (for my eZuma project)
flippy   1 MW
Re: AliExpress battery pack unboxing
Post by flippy » May 15 2019 6:06pm
yes, they are original plates.
i noticed that QS does not have a really thight fit on the torque plates. i have had to put shims in mine and others to prevent the axle from turning on the plates so the flat sides had no play in them. in some plates the space was well over 1mm.
i plan on getting a few laser cut when i get my 13" motor that fit really thight on the flat sides.
does QS say anyhting about their V4 motors on what is different?
Lithium beats liquid dinosaurs.
MJSfoto1956   10 kW
Post by MJSfoto1956 » May 15 2019 6:41pm
flippy wrote:
May 15 2019 6:06pm
i plan on getting a few laser cut when i get my 13" motor that fit really thight [sic] on the flat sides.
Where will you send your files for laser cutting?
flippy wrote:
May 15 2019 6:06pm
does QS say anyhting [sic] about their V4 motors on what is different?
Nope, the photo I posted is what they shipped with the motor.
I'll look into perhaps using some shims if there is any play at all.
Do you think using strips of aluminum foil tape might work as a super-thin shim?
Voting has ended: viewtopic.php?f=26&t=102697
Слишком мало, слишком поздно
flippy   1 MW
Post by flippy » May 15 2019 7:08pm
i have a local company that has a 2kW laser and i know the owner. it should be able to cut 10mm steel
alu foil wont work, its too soft. for the 205 motor i used steel washers and cut them if they were too big and tapped them in with a hammer. now i have a welder so i will probably just try and weld it up and file it back down again.
MJSfoto1956   10 kW
Post by MJSfoto1956 » May 15 2019 7:47pm
flippy wrote:
May 15 2019 7:08pm
What do you think it might cost to have them fabricate two of these @ 8mm thick (shown in red below)?
flippy   1 MW
Post by flippy » May 16 2019 10:31am
i'll ask, but shipping a couple steel plates to the US will be "prohibitive" in cost.
might want to find a job shop near you with a cnc mill. they can crank a few out in no time. if you give them a complete CAD then it should ne easy for them if they only have to generate the gcode.
MJSfoto1956   10 kW
Post by MJSfoto1956 » May 16 2019 12:38pm
Finally some sun! What the brake-side of the motor+swingarm looks like:
flippy   1 MW
Post by flippy » May 16 2019 1:32pm
i still find it hillarious that it only going to to scooter speeds. with a matching controller and battery it can do insane accelerations.
MJSfoto1956   10 kW
Post by MJSfoto1956 » May 16 2019 1:41pm
flippy wrote:
May 16 2019 1:32pm
i still find it hillarious [sic] that it only going to to [sic] scooter speeds. with a matching controller and battery it can do insane accelerations.
Baby steps, flippy. Baby steps.
Besides, what's wrong with taking pride in your work? :P
M
P.S. I just ordered some 0.2mm 316 stainless steel shims for the dropout which should be good enough for the time being
MJSfoto1956   10 kW
Post by MJSfoto1956 » May 26 2019 7:32pm
Ok. Been away on business travel these past few weeks. But it's starting to come all together now. This puppy may be rideable in the next two weeks, God willing.
MJSfoto1956   10 kW
Post by MJSfoto1956 » Jun 03 2019 4:46pm
It's alive!
I finally got 90% of the wiring done and fired her up. N.B. much of the Chinese wiring was inadequate so I took the opportunity to re-wire a bunch of it leaving plenty of extra capacity for the future (e.g. dual PIAA horns). According to the PowerVelocity controller, on a full-throttle test (fully elevated off the ground) the unloaded top speed is 85mph. I'm guessing the real-world top speed will be more like 60mph which suits me just fine. Now just to finish up some loose ends, put the body back together and take her for her maiden voyage. I can't wait!
P.S. for those curious types, the junction box I used above (under the floorboard) for the power distribution, circuit breakers, and contactor is from Polycase: https://www.polycase.com/sk-24
999zip999   100 GW
Post by 999zip999 » Jun 04 2019 12:28am
Si I can't wait
MJSfoto1956   10 kW
Post by MJSfoto1956 » Jun 04 2019 2:27pm
Bled the brakes today and took her out for an illicit spin down our little street. Everything seems to be working fine with the QSmotor V4 8000W hub motor and the PowerVelocity 20kW controller with Bluetooth. Battery still showing the same voltage 30 days later in a dormant state. Just need to make some final tweaks to the wiring and finish installing all the body panels before I get my plates and inspection.
MJSfoto1956   10 kW
Post by MJSfoto1956 » Jun 07 2019 3:42pm
Well, I have to say, this eScooter both accelerates faster and has higher top speed than my 150cc ICE scooter. I think I have a keeper. Even the regen works well to keep the battery level topped up when coasting.
P.S. I think I'm going to need a bigger and better looking front rim. Something like this:
Punx0r   100 GW
Post by Punx0r » Jun 08 2019 5:02am
Awesome project 8) That swing arm is quite something!
MJSfoto1956   10 kW
Post by MJSfoto1956 » Jun 08 2019 7:17pm
I just had to replace those cheap Chinese clone "hand guards" with something more substantial. These are serious motocross hand guards, to which I had to perform some significant grinding/drilling in order to fit the much shorter scooter handlebars. I like the look too, especially as it maintains the homage to the original Yamaha Zuma/BWs 125 gestalt.
MJSfoto1956   10 kW
Post by MJSfoto1956 » Jun 09 2019 5:25pm
Today I replaced the pathetic, single, cheap scooter horn with dual PIAA sport horns, powered via a relay by a dedicated 10A DC-DC converter. Man they are loud! This is a sweet upgrade for any motorcycle.
flippy   1 MW
Post by flippy » Jun 09 2019 6:25pm
i used those in the past as well. later i upgraded to a truck horn with a 12v compressor because everyone thinks that horn is not for them. now they think a truck is diving 5ft behind hem and they get out the way in a hurry.
MJSfoto1956   10 kW
Post by MJSfoto1956 » Jun 09 2019 6:37pm
flippy wrote:
Jun 09 2019 6:25pm
...now they think a truck is diving 5ft behind hem and they get out the way in a hurry.
I'd love to hear that!
M
flippy   1 MW
Post by flippy » Jun 10 2019 3:52am
Ill make a video when i get back from my trip.
Its not -that- interesting, its just taking out a puny electric horn and replacing the sound with the one of a proper 18 wheeler.
Youtube "hornblasters" if you what to see some fun by people thst build train horns in their cars.
fechter   100 GW
Post by fechter » Jun 10 2019 9:05am
MJSfoto1956 wrote:
Jun 07 2019 3:42pm
What kind of top speed are you getting?
MJSfoto1956   10 kW
Post by MJSfoto1956 » Jun 10 2019 11:23am
It will easily do 50mph up hills that my 150cc ICE scooter had trouble doing 45mph.
Not sure of the top speed yet -- still tweaking things.
On a related note, the other day I went for a 25mi round trip and it used 25% of the battery (i.e. it went from 50% to 25%).
I wonder if that suggests that I might be able to get as much as 100 miles out of this puppy (if I baby it)?
M
999zip999   100 GW
Post by 999zip999 » Jun 10 2019 11:51am
Give it some time and cycles before you try to find LVC.
MJSfoto1956   10 kW
Post by MJSfoto1956 » Jun 10 2019 12:57pm
999zip999 wrote:
Jun 10 2019 11:51am
Yeah I'm currently limiting charging to 4.1V and not letting it drop below 3V -- just so I can get my bearings first.
MJSfoto1956   10 kW
Post by MJSfoto1956 » Jun 11 2019 4:18pm
So I just took a quickie 3.8mi test around my neighborhood with some runs up/down various nearby hills.
  • Temperature was 80°F/26.7C
  • Charge was at 91%
  • PowerVelocity 20kW 100V controller, limited to 82A battery, 230A phase
  • QSmotor V4 8000W hub motor
  • 57Ah 20s 17p li-ion battery pack
  • Approximately 284lbs/129kg bike weight
Recording of the PV app screen (see link below) shows 61mph top speed on this particular run, which is more than enough for my purposes.
Vimeo link: https://vimeo.com/341660978
M
P.S. This puppy is much faster than my 150cc ICE scooter, which will be put up for sale soon.
MJSfoto1956   10 kW
Post by MJSfoto1956 » Jun 14 2019 11:34am
Some more progress on little details:
  • I found a used PUIG windscreen for cheap, then modified some of the clear plastic to fit the scooter's tight dimensions.
  • Made a custom mount for the license plate out of black HDPE
  • Took a nice 30 mile round-trip to get the bike inspected -- given their reaction, I don't believe they had yet seen an electric bike come in for inspection
Next up:
  • I need to build a custom ventilator for the battery pack. Likely going to use a computer fan and some PVC pipe.
  • Add a new 13" rim with 110/90-13 Pirelli tire to match the rear
  • Ditch the cheap, twitchy Hall Throttle in favor of a mechanical throttle linked to a potentiometer
