A2B Metro - [rear rack, auxiliary, secondary, battery]
Looking for something? Need a special part, but can't find it online anywhere? Post what you need, maybe others will have it to sell. Guest may post replies to topics already here. All topics here will expire after 60 days of inactivity.
marty   10 MW
Post by marty » Mar 08 2019 5:25pm
Want a auxiliary battery that mounts to the rear rack on A2B Metro Electric Bicycle.
Sent a email to people at http://wearea2b.com/index.php/us Reply was:
Replacement batteries for the Metro are no longer available through A2B.
The main battery is inside the frame.
MARTY
Volt Electric Vehicles
http://www.voltev.com
E-Glider   1 W
1 W
Re: A2B Metro - [rear rack, auxiliary battery]
Post by E-Glider » Mar 14 2019 11:41am
Yes, 'wearea2b' seem very quiet now! I guess you could also try these guys:
https://ebikemarketplace.com/blogs/news ... eplacement
They may already have a complete spare/reconditioned rear case/pack available for you?
There was also one on eBay a year ago - maybe contact the seller to see if he can point you in the right direction anyway:
https://www.ebay.com/itm/A2B-Metro-Velo ... _cvip=true
There was also a place in Taiwan offering new rear packs last year, but they seem to have disappeared now!
Good luck anyway.
marty   10 MW
Post by marty » Mar 16 2019 6:02am
E-Glider,
Thanks for finding that eBay add. Now I got pictures of what I am looking for.
MARTY
marty   10 MW
Re: A2B Metro - [rear rack, auxiliary, secondary, battery]
Post by marty » Mar 16 2019 6:53am
More pictures.
MARTY
marty   10 MW
Post by marty » Mar 16 2019 8:10am
eBay > Click on the ♥ heart sign when searching.
My eBay > Saved searches, Search for a2b metro battery
Now eBay will send me a email whenever someone is selling a a2b metro battery.
MARTY
E-Glider   1 W
1 W
Post by E-Glider » Mar 16 2019 2:46pm
Marty,
Cool.. no worries!
Maybe drop these guys a line too:
https://ebikemarketplace.com/products/a ... -batteries
They may well have a 'spare' rear case/pack already in stock?
marty   10 MW
Post by marty » Mar 16 2019 3:21pm
E-Glider wrote:
Mar 16 2019 2:46pm
Marty,
Cool.. no worries!
Did ↑
Also added a2b velociti battery to my eBay Saved Searches.
MARTY
fechter   100 GW
Post by fechter » Mar 16 2019 3:29pm
You can use just about any 36V battery for the rear. You just need to make a way to mount it and cut off the stock connector and splice on a new one that fits the new pack.
You can also run a higher voltage up to 48V for more speed.
The factory rear pack is nice but very hard to find these days.
E-Glider   1 W
1 W
Post by E-Glider » Mar 17 2019 6:27am
Yep! ;/ (@ 'fechter' - your posts/work here have inspired me greatly - thank you!)
Luckily my old Metro already came with a factory rear case, which I then 're-packed' with x4 of these - in series/parallel:
https://hobbyking.com/en_us/zippy-compa ... tore=en_us
Frame pack now has x4 of these in similar config:
https://hobbyking.com/en_us/turnigy-hig ... -xt90.html
Tight fit, but worth it. :)
R
ear also runs lights & USB charging port. ;)
Good range & pace now - Stock motor loves it, but stock controller has the thermo cut-out glitch still on those hot days!
marty   10 MW
Post by marty » Mar 21 2019 6:10am
Some random numbers to help others who might be searching the internet for this battery.
SDTDCGC400149
SDTDCGD160387
36V/13.2A
Lithium
UM1006F
TD HiTech
63103 00 40010
MARTY
kauaikit   100 mW
Post by kauaikit » Mar 26 2020 7:38pm
Hey e-Glider.....the lithium batteries you linked to are either 7sx2 =14s (51.8v) or 6sx2=12s (44.4v)! Neither of these packs will work with the stock A2B 36v controller, right?
Kit- Wavecrest Lab Tidalforce ebikes (12-all models), 2 EMS M-750 E+, EVG ebikes (18-all models), '13 A2B Shima, '10 A2B Velociti 26", Ultra Motor Velociti (26" White), Tres Terra Europa 36v (2-Blk & White), eZip EcoRider 24v, eZip Trailz step 24v, Chinese 28" 36v alum man-bike, Chinese ped-scooter 48v, iZip 1000 36v scooter, Tanaka 36v scooter.
E-Glider   1 W
1 W
Post by E-Glider » Mar 27 2020 4:29pm
kauaikit wrote:
Mar 26 2020 7:38pm
Wrong. Both packs still work fine on my Gen 1 unit. :)
It seems that the stock contoller will handle up to around 57-59v before it freaks/burns out!
As mentioned, the only 'glitch' with the stock controller/motor seems to be the built-in automatic thermo cut-out.. which obviously, ambient temperatures aside, will tend to get warmer sooner, the higher the operating voltages etc.
kauaikit   100 mW
Post by kauaikit » Jun 30 2020 1:29am
Great.....I asked as I've got a '10 A2B Velociti that is in need of a battery rebuilt & I desired more top-end speed over the 20mph limit. Is it possible to cut a "wire" for the temp shut-off? So, what level speeds are you getting with a 14s pack?
KB
fechter   100 GW
Post by fechter » Jun 30 2020 2:05pm
The thermal sensor is buried in the controller, so not easy to get to. The controller is potted.
With the stock 36v battery, my Metro would go about 20mph. With a 14s battery, it goes around 27mph. The only time I had the temp sensor cut off on me was after a really long ride. It takes about 30 minutes to cool off enough to reset.
