Nissan Leaf Modules over 500 amps peak?
garolittle   1 kW
Post by garolittle » Mar 15 2019 11:53pm
So I am finding conflicting information regarding the peak amps for a 7S configuration of Nissan Leaf modules (2013 model year). This is a 54V nominal pack and the site below claims over 500 amps peak current. Other sources have claimed lower peak current levels for this same cell. Any opinions from the experts would be greatly appreciated. Thanks. Gary
amberwolf   100 GW
Re: Nissan Leaf Modules over 500 amps peak?
Post by amberwolf » Mar 16 2019 3:14am
What time period does each site give for "peak"?
Without knowing how they tested it, you can't directly compare the data.
Note that while none of those places may acutally be doing this: places that sell cells may overrate them simply because they want to sell more, and figure they won't actually get used at those rates, but people who don't even need that good a cell would still buy them just because they look better. :/
If you found this advice helpful, supporting contributions are accepted here. Presently on unpaid medical leave of indeterminate length.
See here for Details: Beginning of a New Life
flippy   10 MW
Post by flippy » Mar 16 2019 9:43am
i dont buy those numbers. pulling those currents from that type of cell will kill it on short fashion.
if you think you will hit anywere near those currents you need a different appoach in the DIY world. increase voltages so you can lower currents is the first thing i would look at.
The bitterness of low quality remains long after the sweetness of low price is forgotten
garolittle   1 kW
Post by garolittle » Mar 16 2019 10:03am
Good feedback. I would only be pulling 250 - 300 amps on my current set up so I will be no where near 500. It's best not to tempt fate. : - ) Thanks for the quick responses. Gary VenomKarts.com
Volt_Ampere   10 W
Post by Volt_Ampere » Mar 16 2019 10:17am
54AH is way down from what they are new. Unfortunately, most of the Leaf modules available are well used. I got some almost new ones 3 years ago for my golf cart but they are hard to find since they are all salvaged from crashed cars or from packs turned in because they have dropped in capacity too much.
garolittle   1 kW
Post by garolittle » Mar 16 2019 10:23am
Good point. It is a shame that these packs are not more readily available with higher capacity. The "modular" nature of Leaf batteries make them ideal for achieving whatever voltage you need for your project. Thanks for the good feedback. We are using them only for a prototype. VenomKarts.com
spinningmagnets   100 GW
Post by spinningmagnets » Mar 16 2019 11:01am
Add 100-psi compression on the flat sides, and also add a temp sensor to the inner cells. 140F temps or more are a no-go, warm is good, hot is bad.
Extraordinary claims require extraordinary evidence.
garolittle   1 kW
Post by garolittle » Mar 16 2019 11:53am
spinningmagnets wrote:
Mar 16 2019 11:01am
Thanks sir. I hope you’ve been doing well. I really appreciate your response. Gary
John in CR   100 GW
Post by John in CR » Mar 16 2019 12:34pm
>500A...LOL. I have most of a Leaf pack and used a big car battery tester to load test 2 modules in series. I wouldn't pull over 200A peak and 100A continuous through mine to avoid heat problems. They're sag city (ie relatively high resistance) compared to the other electric car batteries I have. Mine won't go in a traction battery, so they'll get used as a home based electric storage system.
garolittle   1 kW
Post by garolittle » Mar 16 2019 12:56pm
Thanks John. Good feedback. I appreciate it. Gary VenomKarts.com
999zip999   100 GW
Post by 999zip999 » Mar 16 2019 1:20pm
Checked out your website you look like spinning magnets little brother. What's up with that ? Ceramic over didn't know we're having a spinning magnets look-alike contest.
garolittle   1 kW
Post by garolittle » Mar 16 2019 2:07pm
999zip999 wrote:
Mar 16 2019 1:20pm
Lol! He and I have the same awesome haircut. I only wish I knew as much about battery technology as he does. He is the King! :-)
Volt_Ampere   10 W
Post by Volt_Ampere » Mar 16 2019 2:40pm
Leaf modules work great in my golf cart. Much better than the FLA batteries I replaced with them. I have 14 modules which means they are two in parallel so they easily do 300 Amps burst which is all I need. I have 120AH capacity at 58V nominal. The pack weighs 110 pounds which is 250 pounds less than the 48V FLA pack it replaced.
garolittle   1 kW
Post by garolittle » Mar 17 2019 1:08am
Volt_Ampere wrote:
Mar 16 2019 2:40pm
I have half of that (7 modules connected in series) so I will be a little more cautious when above 200-amps. Our prototype is really for testing purposes only since the production version will likely use 18650 cells. Thanks for the feedback. Gary VenomKarts.com
Hillhater   100 GW
Post by Hillhater » Mar 17 2019 1:27am
Some background reading, and test data...
viewtopic.php?f=14&t=52162&hilit=Nissan ... odule+test
Plenty of evidence for that 540A peak.
But be aware of the various versions of these cells and modules.
garolittle   1 kW
Post by garolittle » Mar 17 2019 8:31am
Hillhater wrote:
Mar 17 2019 1:27am
Thanks for the link. I need to read it carefully but I did notice the following quote..... :shock: maybe these cells can handle the high current “
Assuming the 80kw is peak power draw and voltage sags to the nominal voltage Nissan uses, 360V, then it's 222A drawn through the 2p modules. At 66ah that's 3.4C . I think it's reasonable to assume that's a near continuous rating, since relatively long climbs can be expected.”
garolittle   1 kW
Post by garolittle » Mar 18 2019 4:25pm
https://evbatterycenter.com/HAC4/index. ... Itemid=631
So they make an interesting case for why Leaf modules may handle higher current. I will do some testing and post the results.
garolittle   1 kW
Post by garolittle » Mar 18 2019 4:27pm
“According US Department of ENERGY study* these batteries can provide up to 240A continuous or over 540A short time on pulse (time is not specified).”
I have not found this particular report on the web yet but I will post a link if I do.
Hillhater   100 GW
Post by Hillhater » Mar 18 2019 5:13pm
Maybe this is the one refered to..
http://media3.ev-tv.me/DOEleaftest.pdf
It reports a pack test peak discharge of 201 kW which would imply over 500amps
garolittle   1 kW
Post by garolittle » Mar 18 2019 5:24pm
Hillhater wrote:
Mar 18 2019 5:13pm
Very interesting stuff. Thanks for sharing this thread. It looks like several people have claimed to have reached 500 amps (max current).
