Crystalyte 72v 50Amp controller 1.volt to throttle problem
Trelos   10 mW
Post by Trelos » Mar 20 2019 11:21am
Hi guys
Any help would be appreciated because the online shop that I bought the controller from won't answer my calls or return messages!
The speedy worked for a 5km ride then next time I turned it on no throttle.
Ive checked voltage to throttle , cruise control , and hall sensors ,they all read about 1.0 volt .
Ive replaced the 78L05 5volt regulator still no change in voltage output
Any ideas?
Stealth bombers , fighter , turbo levo , its a lifestyle !
TommyCat   1 kW
Re: Crystalyte 72v 50Amp controller 1.volt to throttle problem
Post by TommyCat » Mar 20 2019 11:56am
Disconnect the devices that use the 5vdc regulated power to see if any are shorting out or dragging down the output perhaps. Checking harness/wiring for damage.
See my completed Magic Pie V5 rear hub E-Bike build Here!
Tommm   10 kW
Post by Tommm » Mar 20 2019 11:58am
Trelos wrote:
Mar 20 2019 11:21am
Hi guys
Any ideas?
Do you have an on off wire or switch? Lot of controllers only work if you connect the power switch wire to pack voltage.
Trelos   10 mW
Post by Trelos » Mar 20 2019 10:00pm
Hi Tomm
There is a switch at the end of the controller with a red light ,It lights up when switched on .
Trelos   10 mW
Post by Trelos » Mar 20 2019 10:05pm
Thanks Tomcat
Ive disconnected throttle , motor etc still only 1.0v
When I get home ill check for any shorts near the board .
I don't think there are but ill double check anyway.
cheers
Trelos   10 mW
Post by Trelos » Mar 22 2019 12:23am
No obvious shorts on the board or in the wiring.
TommyCat   1 kW
Post by TommyCat » Mar 22 2019 8:26am
Are you getting the correct voltage input to the 78L05 chip?
Trelos   10 mW
Post by Trelos » Mar 22 2019 9:15am
1.1volts going into the 5 volt regulator.
TommyCat   1 kW
Post by TommyCat » Mar 22 2019 4:42pm
I feel this would be a good thread for you to review...
https://endless-sphere.com/forums/viewt ... 5#p1403338
Best of luck,
T.C.
