Question about battery for Ebike
Vikingimike01   100 mW
Re: Question about battery for Ebike
Post by Vikingimike01 » Apr 03 2019 12:25pm
Thank you!
Post by Vikingimike01 » Aug 18 2019 3:52am
MadRhino wrote:
Mar 31 2019 8:02pm
Vikingimike01 wrote:
Mar 31 2019 1:57pm
I am not planning on needing all that 5kw.
Nope. You are planning to need much more. You just don’t know yet.
Hey you were right I have my 5kw and it goes 50km/h lol, I got my drivers license and I can use it as a motorcycle now. The guy sent a 100Amp one instead of teh 120amp one in the kit!!!! Kinda mad!! Not sure if that would increase max speed... 20+ amps
MadRhino   100 GW
Post by MadRhino » Aug 18 2019 6:58am
You need lots of power to benefit full advantage of a big hub motor. If I was building with that motor, the battery would be suitable to feed 500A. This means that using low C rate cheap cells, you will have to carry them in a trailer after your bike is filled with all it can hold.
Stop buying cheap batteries, or replace your big motor with a smaller one. Compare with combustion engine performance: if you build with a 1000 hp motor, you must plan high octane gas and a big fuel tank.
Current bikes
Street: https://s20.postimg.org/ewrvugywt/Session_04_2015.jpg
Dirt: https://s20.postimg.org/lbqwr55ml/IMG_0157.jpg
