Suzuki kei truck at 50kph flat ground
Electric cars, trucks, ATVs, NEVs - things bigger than a motorcycle.
Overclocker   10 kW
Post by Overclocker » Apr 11 2019 12:36am
660cc engine (to be removed)
700kg (ish) curb weight
i just need it to cruise at 50kph on flat roads. what's the smallest motor that could do this? a golden motor 5000w watercooled would do it?
Chalo   100 GW
Re: Suzuki kei truck at 50kph flat ground
Post by Chalo » Apr 11 2019 12:40am
Why the smallest motor? Why not the most dependable, most efficient, or most cost effective?
You're already opting for 700kg of relatively useless pig iron, after all.
If you want to use the smallest motor, figure out the power requirement at 50kph and use an RC airplane motor that delivers that much. (Or don't, because that would be regrettable.)
Overclocker   10 kW
Post by Overclocker » Apr 11 2019 12:46am
Chalo wrote:
Apr 11 2019 12:40am
LOL
a local guy's selling a Golden Motor 5k, that's why. i could either use it for an off-road go kart, or to convert a kei truck. take out another carbureted 660cc from the streets can't be bad right. why so much hate
Chalo   100 GW
Post by Chalo » Apr 11 2019 1:50am
"Will this motor work?" is a different question than the one you asked.
If 5kW is all that motor will deliver, my guess is that it would be weak, but might sustain 50kph in favorable conditions. If 5kW is nominal, that's a little more feasible.
A lifetime of being forced to coexist with cars is why so much hate. It's not OK.
Overclocker   10 kW
Post by Overclocker » Apr 11 2019 6:07am
thanks chalo very helpful :roll:
https://www.diyelectriccar.com/forums/s ... hp?t=15508
i found this formula:
The POWER requirements of your car at a particular speed is:
Power in Watts = ((Mass in kg) (9.8m/s²) (Velocity in m/s) (Rolling Resistance)) + ((0.6465) (Coefficient of Drag) (Area in m²) (Velocity^3))
lemme see...
Mass in kg = 700 (assuming small battery pack)
Velocity in m/s = 13.8 (which is 50kph)
Rolling Resistance = 0.02 (street tires on asphalt)
Coefficient of Drag = 0.4 (this truck is a box)
Area in m² = 2 (it's a tiny truck so maybe even less?)
Velocity^3 = 13.8^3 = 2628
Power in Watts = 3253
the watercooled Golden Motor HPM5000B is rated 5KW continuous? my BHT motor is rated 1000w and i do 4000w bursts all the time. the HPM5000B is starting to look like a viable motor...
grindz145   100 MW
Post by grindz145 » Apr 11 2019 12:31pm
Subscribed, photos or it didn't happen ;)
SlowCo   100 kW
Post by SlowCo » Apr 11 2019 12:47pm
I would love to see how you'll convert it so I'm going to follow your build. Good luck and success!
fechter   100 GW
Post by fechter » Apr 11 2019 12:52pm
That's not much bigger than most golf cars.
You might consider some kind of transmission in case you hit a hill. 2 speeds would likely be enough.
SlowCo   100 kW
Post by SlowCo » Apr 11 2019 2:01pm
fechter wrote:
Apr 11 2019 12:52pm
Maybe only remove the ICE engine and mount the electric motor to the gearbox? That way you can choose the gear ratio as needed and are even able to carry/move more serious weight.
Chalo   100 GW
Post by Chalo » Apr 11 2019 2:47pm
Overclocker wrote:
Apr 11 2019 6:07am
Yes, this truck is a box. Most trucks have Cd of greater than 0.6. (0.4 was the Cd of the Jaguar XJS.)
If you use faulty assumptions, your calculated guess winds up being less worthwhile than an uncalculated rough estimate based on real world experience.
Ribfeast   100 mW
Post by Ribfeast » Apr 15 2019 12:25am
My kart is pretty much a golf kart, I think it has a 5kW motor and I've peaked it at around 15kW in spikes. For something with that weight I'd recommend more like 20kW nominal, or more. Unless it is just for use around a private property?
Or look into one of these and convert it to lithium?
http://pickman.com.au/listings/pickman-kw4wh1/
GeriatricGeoffrey   10 mW
Post by GeriatricGeoffrey » Jun 23 2019 9:15pm
let us know how it goes!
Overclocker   10 kW
Post by Overclocker » Jun 24 2019 2:38am
i'm still going ahead w/ this project. i just need to build another bike first (vector light frame). then i need to sell one of my cars to have garage space for this project :lol:
cheapcookie   100 W
Post by cheapcookie » Aug 19 2019 10:26pm
Went to see this guy today, he sold the car. And only had lead acid so very short range and battery life span. But still he claims 100Kmh +
https://www.youtube.com/watch?v=Kf4QvVyoe0E
cheapcookie   100 W
Post by cheapcookie » Oct 04 2019 3:46pm
Hey overclocker, the might-e truck from canev, the guys that make a bunch of adapter plates for various car models is awfully close to what you are trying to do.
check it out https://canev.com/might-e-truck/, they specify 72v motor.
