ebike4healthandfitness
- Joined
- May 19, 2012
- Messages
- 1,283
The only way they can contribute to in-plane stiffness is to resist the rim's tendency to deflect outward on either side of the loaded section (those couple of spokes in the diagram above that show positive values around 40 on the scale), when that's only a tiny fraction of the deflection that's happening.
Chalo, that diagram your are referring to comes from an article (post #14) where the results were obtained by computer simulation. The computer simulation fails to properly account for the fact that the tire is a pneumatic device. When a tire encounters a load the pressure in the tire increases distributing the load throughout the wheel. This distribution of load throughout the entire wheel (via increasing air pressure) is why the tensioned structure of a wheel is able to increase radial stiffness by increasing spoke count.
The way he did the simulation is way too simplistic with way too much force concentrating in way too small of an area.....as if the bike was riding directly on the rim without even an inflated tire present.
