This - "upper pulley"
BTW, impressive work; every household should have a CNC machine in the wardrobe.
In my case, I will implement that only as a non-tensioner, down movement limiter (as I mentioned before).
I also have made 600+ Km, and had an incident where in a sudden situation, I had to by a reflex quickly grab the bike so
the throttle got activated, pushing the front HARD against a wall.
Luckily nothing visibly broke, but it adds up to my and the general wear.
"The manufacturer made a software update regarding the throttle, now i can use it only if I put some force on the pedals,
so the motor won’t see instant torque from a standstill situation (both with the bike moving or not),
it will only spin the motor if some torque is sensed through the pedal torque sensor"
I think we would like to have this generally available for both safety and mechanical and body longevity reasons,
but suggested with the following twist
DEFAULT SETTING:
Pedal use + Throttle = unrestricted
Only Throttle = power and speed limited (6 Km/h ?),
but just enough power to haul a loaded bike uphill
while walking along.
OPTIONAL MODE:
Unrestricted Throttle Use -
for like in an emergency and hurt and unable to
use by pedaling.
Regarding limited current -
For the (14s)2p molicel type with 13mΩ internal res.
35/2P Amp would add 3.9 W of heat to each cell,
while (not specific to molicel) the general IDEAL recommendation is < 5W/cell,
if there is no active (liquid/fan) cooling system.
So there is limited margin for hot weather.
