Hi Folks. I hope someone can sort me out.
I took a 350w Bionx motor and removed the internal controller. It is now just a plain direct drive motor 3 stator wires and the 3 hall leads plus power and ground.
I ordered a KT controller from aliexpress. Thinking bigger is better I ordered the 50a model. I have tried all combinations of the hall sense wires and stator wires and I get the wheel to go either superfast/high amps, super slow low amps, or clunky. No sweet spot.
I mentioned this to the aliexpress store and he said the controller I bought was for a 2000 watt motor and that I needed a 17 amp controller.
So, can this 50 amp controller be made to work , or do I purchase the 17amp controller and see if that works?
Here is the link to the controllers
