fechter said:
Next time add some commentary describing what the buttons do.
The meter is set up with four pages, each one may or may not have subpages. The pages are ride, measure, review, and set. The measure page has a subpage that shows volts, amps and watts, and a subpage that shows amp hours and watt hours. The review page has a subpage that shows voltage low and current high statistics, one that shows best amp hours and watt hours, and one that shows total amp hours used and battery cycles. You have the option to add amp hours to the total amp hours when you push the ride reset button on the ride page. The battery cycles are incremented if you are above 2 AH when you hit the ride reset button.
The buttons do the following.
1. Ride Page - Clears ride data (time, volts low, amps high, amp hours, and watt hours) after 2 seconds. You then have a Y/N screen that allows you the option to add your accumulated amp hours to your total amp hours. Battery cycles is incremented if you have exceeded 2 AH.
Set Page - Decrements values.
2. Ride Page - Clears all data after 5 seconds. Set Page - Increments values.
3. Toggles between subpages and moves the asterisk on the set page.
4. Changes between display pages.
