matthillster
- Joined
- Jun 21, 2019
- Messages
- 16
Hi Everyone,
I recently bought a Magura MT5e HIGO Opener 3-Finger Hydraulic Disc Brake to use on my stealth bomber ebike.
When I attempted to fit it I noticed that it wouldn't fit on the frame and needed an adapter. I contacted Magura but they couldn't tell me which adapter I needed and wouldn't send me the dimensions of their adapters so I could work it out for myself.
Has anyone had a similar issue and found which adapter they need?
I'm currently using a 180mm rotor but I'm planning on upgrading to a magura rotor so happy to change the rotor size when I do that if it helps.
I also have the issue that the brake sensor cable that is attached to the lever is a two pin red Julet connector while the control has a three pin yellow connector. Does anyone know of an adapter or a way to solve that issue without cutting the cable open and doing some soldering?
Thanks!
Thanks!
