Hi Guys,
New to the forum, I am Thomas form Belgium and I have just started building my own Li-ion packs mainly for use in big RC planes.
I am now planning on building 2 pieces of 6s2p molicel p45 packs. I don’t like soldering on those things so I have bought a sequre sq-sw1 mini spot welder a couple of weeks ago.
So 2x 6s2p will be used in series to power a 6000w brushless engine. Currently I use normal lipo’s on 45v, this gives me an amp draw of 45A in cruise, when performing aerobatics It peaks to 90A.
As I assume just using 0.15 or 0.2 nickel strips will cause to much loss to heat so I am looking for alternatives to spot weld.
- I read about copper sandwich but I am afraid my spotwelder is not strong enough?
- I thought about just spot welding the parallel connections and then solder on 10awg wire on the nickel strips for series connections?
- Maybe I could use Braided wire as a solution for serie connections?
