Anyone using BAFANG G062.1000 1000W geared hub motor?
pullin-gs
senlin said:
Hi TuomasK, I'm looking at getting one of these motors. I vented my DD hub motors and it works well, I was wandering if there are issues with dirt getting into the gears after venting a geared hub motor? I won't be using mine off road.
Epoxy a screen over the holes. That will at least keep out the larger more damaging stuff.
PS: I run sustained 1500W. No heat issues.
banshee28
Wondering how much better this 1000W would be vs my current 750W setup? On a Fat tire bike with 35A KT controller and 52V batt.
Also, I removed the internals of my original 350W motor, and replaced with the 750W motor internals, which worked great. Would I be able to do the same with this 1000W?
1boris
pullin-gs said:
Observation: I have not been able to find a source for G062 replacement gears.
https://www.greenbikekit.com/bafang-8fun-spare-parts/front-rear-hub-motor-repair-parts/rm-g06-snowbike-fatbike-swx02-motor-clutch.html
Deafcat
City of Bridges (in the Canada Rectangle)
s3ss1on said:
Hi, excuse me if I get in the way, but I would like to ask you a question, can I install this motor on a 190mm rear frame?
Actually yes. I have one myself, fit fine, typical to use some spacers to get it just right.
I'm running it with Grin Baserunner, peak wattage 1500W, in a commuter bike with torque sensing BB. G60/G62 are great hub motors, very reliable, I've got over 5000km on one of these hubs. The internal freewheel and reduction gears are well made, Have also welded up one of these freewheels for other applications with G60, regen and electronic freewheel are easily implemented with correct controller (although regen I would be careful with, since it will result in bi-directional loads on the plastic reduction gearing, which could degrade them if you're using high output and/or regen wattages).
Difference between G60 and G62: a half-kilo weight reduction in the newer part number. Not bad! Otherwise, I'm not aware of any other changes, though a direct comparison of internal parts would be nice (I haven't gotten around to it).
pullin-gs
Still looking....link is for sub-750W G06 (not 1000W G062) motors.
concretefeet
100 µW
San Diego
Ohm_slaw said:
I bought a couple of bikes with these motors. I like them, very torquey (but not particularly fast) which is what I was looking for.
It’s on a 20” fat tire bike. The controller is a KT rated for 15A with 30A peak. 48V battery rated for 30A continuous.
I did have a problem with the setup when I took it up a steep hill but I don’t think it’s motor related. The wiring harness melted, but just at the point there the controller hooks to the motor harness. Maybe a bad crimp or maybe the bullet connectors couldn’t take the current. Anyway it melted right at that point and some of the wires shorted. The seller sent a new motor and a new controller but I’m still in the middle of replacing things.
I took the motor apart thinking I would need to upgrade the wiring inside but the wiring in the motor is fine. It was just that one point that melted.
While I was at I decided to add a PhaseRunner, CA3 and a bottom bracket torque sensor. Lotsa wires.
The gears inside are nylon with a metal core.
That’s a 750w dude. Sorry.
Dan Rogers
May be available in 190mm this year .
Snacks
1 W
So I purchased a g062 1000w but mine says 750 inside like theirs too
Don’t know what to think
TuomasK
1 W
Normal. Same Gear Set on both G062 series motors (750&1000).
TuomasK
1 W
This is how my vented G062.1000.DC motor looks after I cleaned most of the old SHC100 grease off. Approx 1 year and 3000w peak power usage. Everything looks good 🙂
Upgraded motor wiring and installed temp sensor and bluetooth logging device to work with app.
In couple of weeks I will upgrade the controller to ~60A (60v still).
Snacks
1 W
Wow that’s nice work! What did you upgrade the motor wiring with? I’m trying to replace mine with the grin motor cable currently but it’s been tough
TuomasK
1 W
Thanks. The G062.1000.DC (6) motor originally came with L10 with thinner phase wires and without thermistor wiring. The thicker L10 with 4mm2 phase wires won't go through the axle. Therefore I used size between those just to go throught the axle. You can see the difference in wire thickness in one of the picture above.
Fishing the cable through is always bit if a task.
Grin has made pretty good video on this subject. I think they used Mac as example motor.
This is the cable I used:
https://www.e-bike-technologies.de/index.php/en/connectors/connectors-motor/higo-l1019-series/higo-l1019-m-s-detail
concretefeet
100 µW
San Diego
I take back what I said about it being a 750. I took mine apart as well and it says the same damn thing. (I have a 750w and a 1000w) Here’s the kicker, it looks like the windings are the same as a 750w BUT I DO NOT KNOW unless I rip out the wiring which I do not plan on doing until I smoke it or break it. The only difference I can see making the motors a 1000w is a larger wiring gauge. Bafang has been known to LIE about what their motors can actually do and ratings and such. I am sorry for jumping to a conclusion when I don’t have all the evidence.Ha. Not really funny but annoying. I hope you find some comfort in knowing that I was wrong though! Love the pictures and your in depth disassembly. Keep it up. Ride on.
TuomasK
1 W
Haven't inspected the G062.750 so hard to tell if there are real differences. What I do know Bafang typically uses multistrand winding technique, so for example 6 turn motor may have either 6 or 8 strands doing 6 turns. This way one wire gauge can be used for different copper fill.
Psyrecx
I just got the G062.1000w 20in 6T motor... My controller isn't a big fan, because it uses a different pin arrangement, I guess. It is a controller from my old C&N/Leili motor. Oddly enough, a Voilamart motor worked just find with the controller, other than not having a temp sensor.
The bafang seems to have the white wire noted as an 'spd' wire. So, my controller can't display this motor's WH, Amp, or Temp correctly. Some of them just flash a number every once in a while, but nothing in that regard seems to work properly.
https://www.youtube.com/watch?v=3ygQSn2HldE
amberwolf
Administrator
Staff member
Phoenix, AZ, USA, Earth, Sol, Local Bubble, Orion
FWIW, the motor doesnt' have a Wh (Watthours). The battery does; it's a measure of capacity. If instead you mean W (watts), well, see the below about motor amps--it applies to watts as well because watts is not read directly, it's calculated from amps x volts.
Unless the controller has phase current sensors (like FOC controllers do), then it doesn't know what the motor's A (amps, phase currents) are, either. Most of them only sense battery current (battery A(mps)), so for most systems there isn't a motor amp reading regardless of what motor is attached to the controller.
Temperature, well, it needs a compatible sensor to do that. There are a lot of different kinds. Most motors use simple resistive sensors, like NTC 10k of one beta or another, but to get a reading accurate across the whole range it has to be the same beta that the controller supports (a common one is 3900, but there are many).
Note that if you have the speed sensor output wire connected to the temperature sensor input, then depending on the controller design the speed signal pulses may be screwing with the software (or hardware) and causing it to fail to operate normally / correctly.
Psyrecx
Yes, the battery does. But my system tells how much capacity it is draining, based on amps and volts being used. It just lists it as WH on the display. I'm guessing it's showing it as watts per hour. Probably not the best way to say it, but it works. Also, it lists how many amps, and average amps you've been using. This is the only motor so far that it doesn't show that information for. My other motor still shows that information when connected.
I've disconnected the speed wire, as it's not correct for my controller. I only connected it for the video.
*EDIT*
Interesting predicament... Was out testing the motor, and wheel after finally getting my 9g spokes, and getting the wheel assembled. Rode for a couple miles, and on the way back, the WH and everything else, started reading, again. Temp doesn't, but that's as to be expected without a temp chip. I think my controller might be a bit... odd.
ERP
Lake Okeechobee, Florida
Hey guys and gals, just trying to find an answer to a simple question. Does anyone know if the guts of a bafang G062 rear hub motor will fit in a G060 rear hub motor casing? Just bought a juiced bikes ripcurrent with a bafang G060 750 watt motor and want to change it to the 1000 watt version and was hoping to make it easy. Any help would be much appreciated.
ERP
Does anyone know if the guts out of a G062 will fit in a G060 case? The G060 is the 750 watt version of the bafang rear hub motor. I am looking to change my 750 watt to a 1000 watt and hopefully I can do it without respoking my wheel but I think that would be way too easy. Any help would be much appreciated.
TuomasK
1 W
Does not work as motors have different design. Cores are fitted from opposite sides.
Picture attached is G062 motor cable on brake rotor side.
